Old Feb 05, 2013, 09:55 PM
Cubcrazy is offline
Find More Posts by Cubcrazy
Scale Foam Flyer
Cubcrazy's Avatar
United States, AR, Cabot
Joined Oct 2007
Originally Posted by turboparker View Post
Cub,
LiPos are not supposed to be discharged deeper than 80%. Never fly to LVC with any of the UM or UMX aircraft, as it results in a 90-95% discharge. 318 mAh is 90% discharged. Doing that even once typically cause at least some irreversible cell damage.
Joel
I never fly to lvc. Just got carried away having too much fun.
Cubcrazy is offline Find More Posts by Cubcrazy
Old Feb 05, 2013, 10:27 PM
habitforming is offline
Find More Posts by habitforming
ΜΟΛΩΝ ΛΑΒΕ
habitforming's Avatar
USA, KY, Hebron
Joined Dec 2005
Originally Posted by kalmon View Post
Can you take some nice closeup images of the control surface alignment. Also try to get one from the front with the whole plane, and from the back that shows the enpennage alignement.
Bhoov might be on to something as well with the flaps being tweaked.
-Brian
Yes I'm happy to, but threw my back out this afternoon. Will post when able.
habitforming is offline Find More Posts by habitforming
Old Feb 05, 2013, 10:43 PM
bhoov128 is offline
Find More Posts by bhoov128
Genesis 50:20
bhoov128's Avatar
United States, FL, Davenport
Joined May 2012
See if you can dig through the garbage can to find it, before the garbage gets taken out to the curb.
Seriously though, Hope you feel better soon. Back issues are not fun.
bhoov128 is offline Find More Posts by bhoov128
Latest blog entry: Snice Slick
Old Feb 06, 2013, 06:31 AM
kalmon is offline
Find More Posts by kalmon
Parkzone junkie
kalmon's Avatar
United States, MI, Grand Traverse
Joined Oct 2008
Originally Posted by bhoov128 View Post
I would make a template rib of the undercamber, and instead of increasing the thickness of the wing, make a filler. Sand the 2mm depron to shape to an insert so it slots right in and doesn't increase the thickness of the airfoil, in otherwords. might also want to take the opportunity to embed a thin carbon flat into the filler. Could be awesome!
Yeah I though about that as well. I didn't want a solid wing for weight reasons, but then again even with 1mm depron there might not be enough under camber to allow for ribs and a bottom skin.
I also agree I don't want to increase the wing thickness.
The UM T-28 is the test bed for this as it has a much more aggressive undercamber and it's old and beat up.
-Brian
kalmon is offline Find More Posts by kalmon
Old Feb 06, 2013, 08:52 AM
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
OK. Just making sure, as a fair number of people who show up on these UM threads are not familiar with the 80% rule. Yeah - the CC is just so much fun to fly, it's easy to get carried away. That's why I usually fly with my TP 325 65c packs or my Hyp 400 & 500 35c packs. I call the Hyp 500 the 'bladder-buster'. I have yet to fly it to the 80% point.
Joel
turboparker is online now Find More Posts by turboparker
Old Feb 06, 2013, 10:32 AM
Cubcrazy is offline
Scale Foam Flyer
Cubcrazy's Avatar
Joined Oct 2007
Joel
I have been flying exclusively electric since 2006...many years of gas and slimer before that. Lipo batts can last a very long time if you treat them right. This cub had me grinning like the first time I put a Lipo /brushless setup in my HZ Super Cub years ago.
Cub
Old Feb 06, 2013, 11:05 AM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
-Brian
Try just a wrapping of packing tape then, it adds very very little weight. I don't know if you visit the scratchbuild forum (my home away from home ) but colored packing tape is a very popular way to "paint" an airplane and it adds something like 7g per square FOOT.
Old Feb 06, 2013, 11:46 AM
kalmon is offline
Parkzone junkie
kalmon's Avatar
Joined Oct 2008
That would work, I could still use depron to make ribs and then "cover" with packing tape. What is a good source for lightweight colored packing tape?
On the T-28 I'm aiming for a 23xxx shaped airfoil as I don't want a flat bottom.
Interestingly enough the real cub has a very slight undercamber to its wing.
-Brian
Old Feb 06, 2013, 12:08 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
-Brian
I know some people special-order colored packing tape from Staples.
Old Feb 06, 2013, 12:39 PM
ΜΟΛΩΝ ΛΑΒΕ
USA, KY, Hebron
Joined Dec 2005
This is super low tech, but could you just use a regular sheet of printer paper for your initail test? You'd still need the depron ribs, but this seems super quick & easy, not to mention easy to undo/redo
I thought about doing this several years back on a Citabria that I had, but never got around to it. The undercamber micros don't do well around here, as we always have some wind.
Old Feb 06, 2013, 04:18 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Guys, use trim sheet. That's what it's for (coloring, not structural). It won't weigh even close to 7g per foot.
http://www.greathobbies.com/search/r...g=0&srchcat=LT
Create brilliant designs and color schemes with Top Flite Trim Sheets. They’re adhesive backed for easy application and Top Flite offers a great selection of colors and effects including checkerboard! Colors match Top Flite MonoKote covering. Trim sheets are 5" x 36" and are sold individually.
North_of_49 is offline Find More Posts by North_of_49
Old Feb 06, 2013, 04:23 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
Seems like a good product, do you think it might flex too much, and just restore the undercamber to the wing? Packing tape is pretty tough stuff.
Old Feb 06, 2013, 04:26 PM
Joined Dec 2011
I thought you guys were just talking about coloring until I read on. It's not really for structural application like Monokote, Ultracote etc. It's super thin and light weight, though... basically sticky backed decal like the fake windows and striping on the Hobbyzone planes. But maybe you could apply it after taping (or before taping) and then you wouldn't have to worry about finding colored tape. The Topflite trim sheets are only 3 bucks (5" x 36" )... I just bought some more yesterday.
EDIT
or just use proper coverings like Monokote, Ultracote etc.
Old Feb 06, 2013, 04:49 PM
bhoov128 is offline
Genesis 50:20
bhoov128's Avatar
Joined May 2012
ultracote and monokote will need heat to activate the glue and apply... very very tricky with melty foam.
Now for some questions: 1. Is anyone else's CC out of the box pretty stinkin' tail heavy? I have mine flying pretty well and I'm really enjoying it but it's still tail heavy, only with my 300mAh nano-techs does it feel a little bit better. My elevator is even and not warped.
2. How much of a difference does the GWS 5030 make over the stock prop? I don't need to know thrust gram figures, just seat-of-the-pants reactions from those who have changed.
Old Feb 06, 2013, 04:54 PM
Joined Dec 2011
Here ya go...
9-Covering the Wing Top - Building HZ Super Cub from Scratch (9 min 32 sec)
8-Covering the Wing Bottom - Building HZ Super Cub from Scratch (9 min 33 sec)
Build Log Scratchbuild (STOL) Carbon Cub SS - built with carbon fibre tubes Phaeton Scale Kit/Scratch Built 198 Jun 30, 2016 06:29 AM
Article Horizon Hobby E-flite UMX Sbach 342 BNF Review sun.flyer Micro Ready-to-Fly 47 Nov 09, 2013 05:41 AM
Alert BREAKING NEWS: Horizon Hobby Mig-15 UMX gp125racer Other Websites 2 Jan 17, 2012 02:08 PM
Sold Horizon hobby carbon-z- yak with extras matthew james Aircraft - Electric - Airplanes (FS/W) 10 Apr 11, 2011 06:33 AM
