Old Jan 12, 2013, 09:46 PM
Audioguru is offline
Find More Posts by Audioguru
Canada, ON, Mississauga
Joined Oct 2011
Horizon Hobby replaced my bad Carbon Cub.
The new one has a new 2500kV motor that is quiet like the 2300kV motor in my original Carbon Cub but not noisy like the 2500kV motor in my Sbach. The new motor is very powerful with the weak E-Flite 180mAh battery and has more thrust than the weight of the airplane so it climbs like a rocket!
The first flight was PERFECT. It flies slow or fast. It rolls and loops.
I painted it with clear acrylic Varathane (satin) so now the styrofoam balls are joined together and the finish is very smooth. The coating increased the weight 3 grams but it is still drying so it will weigh less.
Audioguru is offline Find More Posts by Audioguru
Old Jan 12, 2013, 10:33 PM
Brian VT is offline
Find More Posts by Brian VT
Brian VT's Avatar
United States, VT, Rutland
Joined Dec 2011
Newb
I know this plane is not recommended for newbs, but I love it !
I wished I had floats, but it did fine with just plopping it down in the snow when it was time to come down.
I ran 3 lipos through it today and I wished I had more. I mostly just cruise around at 1/2 throttle.
I wonder if I'd do better with the T-28 as the recommended aileron trainer, but right now I don't care. I had a blast today with the CC.
Brian VT is offline Find More Posts by Brian VT
Old Jan 12, 2013, 10:41 PM
North_of_49 is offline
Find More Posts by North_of_49
Scout CX | mCX2 | mSR | 120SR
North_of_49's Avatar
Canada, AB, Edmonton
Joined Dec 2011
Have you seen the new Parkzone Archer? I think it might become the new recommended 4-channel trainer Watch Chuck's videos on it in its thread!
North_of_49 is offline Find More Posts by North_of_49
Old Jan 13, 2013, 05:00 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
Would this be good stuff for coating the floats to make them better for grass/snow?
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old Jan 13, 2013, 08:50 AM
Brian VT is offline
Brian VT's Avatar
Joined Dec 2011
Looks nice. I might could be talked into trading my Cub. You offering ?
Old Jan 13, 2013, 11:10 AM
JayY is offline
Find More Posts by JayY
Foam Temple Pilot
JayY's Avatar
United States, NC, Raleigh
Joined Sep 2012
If it's working for you I guess you didn't need the T-28.
I still have not flown the CC I got for Christmas, partly because I wanted to practice on the UM T-28 that was recommended by many of you on this thread, and partly because one of the aileron servos on my CC doesn't work. HH sent me a pair of new aileron servos for my CC, but I have not replaced them yet. I finally got my UM T-28 out for its maiden flight yesterday, and after it was trimmed it flew beautifully, I was able to fly and land it without trouble. I will maiden my CC after it is repaired and I have some more stick time on my T-28.
JayY is offline Find More Posts by JayY
Old Jan 13, 2013, 12:17 PM
SpaKack is offline
Find More Posts by SpaKack
SpaKack's Avatar
United States, CA, Brentwood
Joined Oct 2001
So I got the Cub back when it first came out as a gift. When people were reporting problems. I had a problem with mine just kinda going off on its own and finding the only tree. I had talked to horizon about sending it in and just never got around to it. I havent flown it since. Its a lot cooler now then it was when it had the problem and I doubt I can still send it in. So I was thinking of just going for it and trying to take her up again. I heard they put holes to cool it or something. where are the holes located?
SpaKack is offline Find More Posts by SpaKack
Old Jan 13, 2013, 12:32 PM
BigD1961 is offline
Find More Posts by BigD1961
Team OFG (Old Fat Guys)
BigD1961's Avatar
United States, KY, Leitchfield
Joined Jul 2008
Broken motor shaft?
In the two 30 second flights I got Friday, I broke off the propeller and it LOOKS like the shaft that holds it on? Am i screwed or what?
Is it just the part of the propeller shaft that's broken?
I have a couple of prop savers, if I can mount one, this would be a good time I think.
BigD1961 is offline Find More Posts by BigD1961
Old Jan 13, 2013, 12:50 PM
kelloggair is offline
Find More Posts by kelloggair
kelloggair's Avatar
centennial/aurora colorado
Joined Mar 2008
the shaft broke, the screw holds the prop on the shaft
kelloggair is offline Find More Posts by kelloggair
Old Jan 13, 2013, 01:48 PM
Joined Dec 2011
I don't have a CC
... but I post here when I think I might have relevant things to say on it... maybe mods I did to my Champ or something that would/could apply to the CC
Old Jan 13, 2013, 01:55 PM
Joined Dec 2011
When I get around to making my Champ's floats (trying 2 methods... modding CC floats and building from scratch from the plans floating around RCG somewhere) I'll be "glassing" the bottoms like I recently mentioned I did to the wing tips of my Super Cub...
I won't be using the much cheaper Varathane, but Deluxe Materials EZE Kote. I weighed before and after my second layer of cloth and Kote... a layer that would cover the area of maybe the bottom of one CC float and there was only 1g difference. That's with only a single brushing of EZE Kote. On my Champ's floats I'd ditch the cloth but do 2 or 3 sanded layers of the Kote.
Hell, I'll probably just put packing tape
Old Jan 13, 2013, 01:56 PM
Joined Oct 2011
It is thin and they recommend at least 3 coats. It takes one week to become very hard.
Old Jan 13, 2013, 02:00 PM
Joined Oct 2011
Your "propeller adapter" is broken. The propeller is screwed on to it and it is screwed onto the motor. Horizon and hobby stores sell the adapter and propeller.
Old Jan 13, 2013, 02:17 PM
Joined Oct 2011
Poor Americans, freezing with cold and snow in winter and frying with heat in summer (plus the tornados and hurricanes).
I am "way up north" in Canada. Yesterday and today the temperature was warm and the little bit of snow we had is gone.
Today there was NO WIND for a while so I flew 3 batteries in my new Carbon Cub and 3 cells in my UM J3 Cub. It was fun flying in formation with the ducks in the park. They fly fast.
Old Jan 13, 2013, 02:18 PM
BigD1961 is offline
BigD1961's Avatar
Joined Jul 2008
Oh, thank goodness. I appreciate it.
I bet I have one in my spares container, I always try to buy a few spares for all my ultra micros. Are the props the same as any of the other UM planes? I wonder how a 3 blade from a Mosquito would perform? Hmmmmm......
Build Log Scratchbuild (STOL) Carbon Cub SS - built with carbon fibre tubes Phaeton Scale Kit/Scratch Built 198 Jun 30, 2016 06:29 AM
Article Horizon Hobby E-flite UMX Sbach 342 BNF Review sun.flyer Micro Ready-to-Fly 47 Nov 09, 2013 05:41 AM
Alert BREAKING NEWS: Horizon Hobby Mig-15 UMX gp125racer Other Websites 2 Jan 17, 2012 02:08 PM
Sold Horizon hobby carbon-z- yak with extras matthew james Aircraft - Electric - Airplanes (FS/W) 10 Apr 11, 2011 06:33 AM
