Latest blog entry: Eflite UMX Sbach 3D on 3s - 2300Kv/5043...
Yup.....
And that's why I got out of the CC business... ![]() Just a lurker now.... ![]() Can't trust the darn things, no matter what "version" they are. If I can't trust 'em, then I can't fly it and enjoy it...Planted mine into the ground twice because of a faulty/binding elevator servo. First time, I had my suspicions; the second time I knew right away what it was. If I crunch styrofoam because of my thumbs, that's one thing. But if my plane turns into $169.00 worth of useless styrofoam because of faulty electronics, well that's something I expect from BH, or any of the "others"...not E-flite. Oh well, I'm still subbed so I can monitor the situation, but based on Joel's experience, it isn't getting any better. Too bad; what a wonderful little model. John |
Latest blog entry: 1st Annual Warbirds over Las Vegas - 4-6...
Fair Oaks, California
Joined Aug 2010
Received CC #4 from Horizon Hobby (third replacement since May... due to frozen servos and overheating of escs.. causing motor shut off). I also complained of poor movement of elevator, even with pushrod connected to inner hole of control horn. They have paid for shipping each time - CC 1, 2, and 3 - and asked me to send them a detailed list of problems with recommended improvements (e.g. I fixed esc overheating by cutting a small hole in windshield and cutting small air exhaust holes under back of fuselage).
Well wouldn't you know HH has made some significant design upgrades on CC shipped on Nov. 19 !!! 1) The new CC has an air ventilation hole on the front of the windshield. 2) The new CC has 3 air exit holes under back of fuselage. 3) The elevator of the new CC has much more upward travel (pushrod comes instled in 2nd from outer hole of control horn). Servo operation ok this time with rigorous bench testing, but will have to confirm in flight testing when weather clears up. Appears HH has finally taken some of our concerns and recommendations to heart in this new "ventilated November 2012 design upgrade". Excellent Customer Service has been tempered substantially by MUCH wasted customer time and money on this product with consistent repeated failures much greater than claimed and reported. We shall see if the CC performs better with the new November 19 release. More later. |
a lot to be said for bench and pre-flight checks.
Now that I have about 20 batteries for various planes and helis I'm worried about mixing up a uncharged battery and flying with it. I going to have to check voltages before I go out. Walkera helicopters were getting into telemetry when I came over to planes. Didn't see the need for checking my altitude or motor temp while in flight ,I can't even check to see if my shoe laces are untied without getting into trouble. Would be nice to check voltage on runway pre-flight though. I would imagine that E-flight is going to go with telemetry next. Mike |
I have owned over 30 UM aircraft, which is a total of 100+ linear servos. A couple are past the 1000-flight mark, a few are past the 500-flight mark, and most of the others are well-past 200 flights. I've had a grand total of four linear servos fail prematurely since I started flying UMs about four years ago. An aileron servo went nuts on one of my non-AS3X V1 Beasts during the maiden - right in the middle of a low WOT pass down the runway. (HH sent me a new plane.) The elevator servo on another one of my V1 Beasts died after 50 flights. As far as AS3X planes go - I had to replace a sluggish aileron servo on my first-run CC after 100 flights. (HH sent me a new servo.) And now the elevator servo crapped out on this one before the maiden. (LHS is exchanging the plane.)
It is common knowledge to those of us who follow these threads that HH had a bad batch of UM servos & bricks during the first CC run. Some of them also made it into the batch of Beast 3Ds that hit the shelves at about the same time. Since then, the servo failure reports & brick issues on the Beast thread have returned to being buried in the statistical noise. Once the feeding-frenzy is over with the updated CC, I expect that the same will happen - as has been the case so far with all of the other AS3X and non-AS3X 1s & 2s UM aircraft since the beginning. I have hundreds of extremely aggressive 3s flights on one of my one of my Beast 3Ds - mostly in 15-25 MPH winds. The servos still perform flawlessly - despite the extreme conditions. Aside from the bad batch back when the CC came out, I don't see a big problem with them. (But I still wish they'd switch to an enclosed UM-sized digital rotary!) Anyway.... I'm off to the LHS to pick up my replacement CC. Gotta remember to pick up some of those slippery adhesive-backed sheets they use on the bottom of RC car chassis to put on my floats for ROS. I don't think there's enough snow left in my yard for ROS, though. It's not often that I actually wish for the white stuff, but waking up to 4-5 inches of fresh powder on a calm 30-degree morning would pretty much have me grinning from ear-to-ear. My home "runway" would literally expand from 4' x 10' to 150' x 30' overnight! ![]() ![]() Joel |
Just got home with my replacement CC, but it's already a bit too dark for the maiden. I fired it up at the store & everything seemed to be in order - aside from a seriously out-of-balance prop. Hopefully, I can get a couple flights in tomorrow morning before the wind comes up too much. I'll also do a static RPM test & compare it to the original CC with the 2300Kv motor.
Joel |
Joel |
edit: I just read Joel's post after typing mine. I don't have much experience so the T-28 might be better. I assumed a high-wing plane would be easier so I went that route. I really like the CC so far. |
Also suggest the UM P-51 as I learned a lot on that, and probably the UM Spitfire which has AS3X the UM P-51 doesn't have. |
Just in case any of you are looking I have my ASK21 listed
http://www.rcgroups.com/forums/showthread.php?t=1779279 |
| Thread Tools | |
| Build Log Scratchbuild (STOL) Carbon Cub SS - built with carbon fibre tubes | Phaeton | Scale Electric Planes | 182 | May 08, 2013 09:53 AM |
| Article Horizon Hobby E-flite UMX Sbach 342 BNF Review | sun.flyer | Micro RTF | 46 | Apr 08, 2013 08:26 PM |
| Alert BREAKING NEWS: Horizon Hobby Mig-15 UMX | gp125racer | Other Websites | 2 | Jan 17, 2012 02:08 PM |
| Sold Horizon hobby carbon-z- yak with extras | matthew james | Aircraft - Electric - Airplanes (FS/W) | 10 | Apr 11, 2011 06:33 AM |
