Old May 28, 2012, 10:20 PM
WSEN is offline
Find More Posts by WSEN
McCarthy, Alaska
Joined Jun 2004
Originally Posted by grovey View Post
Hi all
I got a question about the cg on THIS plane. Should the nose of the plane be exactly level with the tail at perfect cg?
For this, the stock battery needs to be all the forward in the battery tray, the tray does not seem adequate if this is the case
That is a good question. I think the answer is yes, pretty much. Although I find that a space of maybe 3/8" between the battery and the aft bulkhead works out about right with a 180 to 210 mah battery. Mine doesn't need to be too far forward.
I was flying my CC with the battery too far back for some time. It surely flies much better with the CG at the proper location. Too far back exaggerates the "dropping out of the air" sensation. Proper CG is much more stable.
One thing I am finding with this airplane is that it requires quite a bit of stick time to get real comfortable with, at least for me. I am enjoying it more as time goes by.
WSEN is offline Find More Posts by WSEN
Old May 28, 2012, 10:24 PM
grovey is offline
Find More Posts by grovey
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Thanks WSEN, looks like I might struggle with CG because with the battery further aft it seems quite tail heavy.
Also for those who have BabbelBats, how are you getting them to fit secure?
grovey is offline Find More Posts by grovey
Old May 28, 2012, 10:25 PM
jimsp is offline
Find More Posts by jimsp
jimsp's Avatar
Sayre,PA
Joined Sep 2002
Originally Posted by Azrie View Post
Is anyone doing anything to strengthen the foam/control surfaces? They are a little flimsy and I'm wondering if adding tape or laminating film or anything to add stiffness or strength?
By far the best way to do this is with 1/2 or 3/4oz fiberglass applied with Minwax Polycrylic. It's very easy to do, lightweight, adds a lot strength and stiffness and is not all that noticable. Attached is a photo where I added a small strip of 1/2oz fiberglass to strengthen the fin.
jimsp is offline Find More Posts by jimsp
turboparker is online now
Find More Posts by turboparker
Gopher huntin' stick jockey
turboparker's Avatar
Joined Jul 2009
Hi all
Grovey,
When balancing, the pitch of the wing should be zero.
BTW - the battery tray extends forward of the main opening. Also, many of us use larger-capacity, higher-power packs in these planes, so it's good that the factory pack needs to be forward of center in the tray. Because of this, we can run packs as large as a Hyperion 320 & still get the CG right.
Regarding the Babbelbatts - I'm using Velcro to secure them, just like the factory pack.
Joel
turboparker is online now Find More Posts by turboparker
Old May 28, 2012, 10:29 PM
captdave221 is offline
Find More Posts by captdave221
220 221 Whatever it takes
captdave221's Avatar
USA, IL, Belleville
Joined Dec 2009
Sorry but these 66 yr old eyes can't see where you put on the cloth. That is really cool being so invisible but where did you put it (can you outline it for me please).
Capt. Dave
captdave221 is offline Find More Posts by captdave221
Old May 28, 2012, 10:37 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Originally Posted by turboparker View Post
Grovey,
Joel
Thanks Joel, I have the 240s and they seem a bit thick to place forward in the battery cavity.
Lemme grab the plane again and a Hyp 240
Old May 28, 2012, 10:48 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Ok so I placed the battery so that the edge of the battery is about 3/4" from aft in the tray and it "looks" ok, but to get the wing at zero pitch (level?) I would really need to move the battery forward. At that point, if the wing needs to be level, then the tail is really high above the wing.
Old May 28, 2012, 11:00 PM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
Here is a pic, with the edge of the battery about 3/4" forward in the tray, with cg being 27mm.
Old May 28, 2012, 11:06 PM
whirlcap is offline
Find More Posts by whirlcap
If it spins, wear it.
whirlcap's Avatar
Northern Nevada
Joined Jan 2011
I usually consider CG correct when the elevator is level? Am I wrong?
whirlcap is offline Find More Posts by whirlcap
Old May 29, 2012, 12:58 AM
Joined Jul 2009
Grovey,
That should be close enough for the maiden. The optimal CG location is determined by flight-testing.
Joel
Old May 29, 2012, 01:25 AM
jim350 is offline
Find More Posts by jim350
Joined Aug 2011
Capt. Dave
It would be the red outlined area
jim350 is offline Find More Posts by jim350
Old May 29, 2012, 03:00 AM
SilentPilot is online now
Find More Posts by SilentPilot
BMFA 190658
SilentPilot's Avatar
United Kingdom, Yeadon
Joined Mar 2007
That looks about right, maybe the tail a little higher to get the wing and tailplane level.
Taildraggers sit with the tail down on the rear wheel, when flying the wheel is quite high up
SilentPilot is online now Find More Posts by SilentPilot
Latest blog entry: Spitfire mk1a
Old May 29, 2012, 06:18 AM
RC-Tom is offline
Find More Posts by RC-Tom
Belgium
Joined Aug 2008
"Complete tail" question?
Hello,
Any "Complete Tail w/Accessories: UMX Carbon Cub
(EFLU1125)" owners out there who could post a picture of it?
I would like to know how complete is complete Do we need a decal sheet set for example in order to get it complete?
I'm making a list of spare parts i will probably need soon or later...
Thanks!
Tom.
RC-Tom is offline Find More Posts by RC-Tom
Old May 29, 2012, 06:53 AM
LyonNightroad is offline
Find More Posts by LyonNightroad
Lost Realist
United States, IL, Chicago
Joined Apr 2012
I'm starting to think the issue might be with the airframe itself, not the brick! My beast 3d brick was 'known good' with 25 good flights. Put it in the Carbon Cub and suddenly the rudder servo motor burns out after two flights. It acted like it was sticking but really the motor no longer had enough torque. Fine. Replaced the motor, working again. 3 more flights and now the elevator servo is getting stupid. Locks up at times and gets stuck stalling. Wont respond to down elevator. Did this a few times, only in flight, not on bench. Finally resulted in a fatal crash that made the plane unable to be recovered (landed on an inaccessible side of a large lake) very dissapointed...
LyonNightroad is offline Find More Posts by LyonNightroad
Old May 29, 2012, 07:02 AM
grovey is offline
Just wanna fly!
grovey's Avatar
United States, TX
Joined Apr 2008
I wonder if this is happening as a result of the control rods binding against the horizontal stab. Both rudder and elevator control rods. This coupled with surface hinges which could be a bit stiff.
Most of the failures seem to be elevator and or rudder servos.
Build Log Scratchbuild (STOL) Carbon Cub SS - built with carbon fibre tubes Phaeton Scale Kit/Scratch Built 197 May 10, 2016 02:21 AM
Article Horizon Hobby E-flite UMX Sbach 342 BNF Review sun.flyer Micro Ready-to-Fly 47 Nov 09, 2013 05:41 AM
Alert BREAKING NEWS: Horizon Hobby Mig-15 UMX gp125racer Other Websites 2 Jan 17, 2012 02:08 PM
Sold Horizon hobby carbon-z- yak with extras matthew james Aircraft - Electric - Airplanes (FS/W) 10 Apr 11, 2011 06:33 AM
