One thing I can say, even if there is not yet any video of it, (cussen-fussen-mussen-russen no aim key chain cam), it does rotate up and out nicely on launch. I was real happy about that. Mark |
Nice job Quick ! Seriously, the little green winch would be perfect for this. A lot safer and easier then a high start. Just a no stress tap,tap,tap and up she'll go! If things go haywire, just stop taping, thats all! A high start keeps pulling until it wants to stop.
Blue Skies........................Tim |
Thanks again for going into details about that little winch, and thanks for the kind words. Mark |
At 24 oz. that equals about 4.8 oz/s.f......THAT'S LIGHT !
I looks like you have adequate control, at least enough to graduate up to the real flying site where you can get a higher launch, enough airtime to get trimmed and have a bigger landing zone. As I recall from my only plank, an Alula, you can only get a good hyperstall when the CG is too far forward. The Alula was 5.78 oz./s.f. at 34" wing span and it flew well. The BLEED is going to kick it up a notch. Kent |
radio has no expo to set. I am hoping to fix that little set back sooner rather than later and take a small step up to a Turnigy 9X as it will bind with all of my receivers I have now. And for what you get, especially after loading something like the er9x firmware, it's hard to beat the price.Quote:
Started in on the new tail fin. I'll get a few pics up of what I did with it once I get it in my high tech press. (book / board with 5 gal. water for weight) ![]() Mark |
Here goes my attempt to build a better tail fin. First off, took Herk's advice and ran a strip of wood,(1"), cross grain on top and bottom. Then printed out a set of patterns of the fin to set up the CF disser on. Stripped off ~1k CF from my spool of 12K tow and ran it around on both patterns. Then spread out a very light coat of GG on one side of the fin and laid it on the disser. Pulled the pins, spread a layer on the other side, trimmed the wax paper and placed the fin on the other CF layout. Trimmed that side up, laid it into a standard fair "wax paper bagging" setup and added the weight. Will know in a bit how it turned out.
Mark |
Alright, tail fin done. Came out nice, and a bit over 10g lighter and that's always a plus. All that is left to do is get it back on and get it square.
In a perfict world, I would of used regular GG but I either lost what I had or used it all up on some other project. The white came out well enough though so I'll run with it.Mark
![]() Mark |
It has been a few days sense i last typed into this thread. I've ended up being busy with stuff like hanging new screen on the back porch, and that should be done tomorrow, then it will be back to flying. To give a short update, I took the wing out to the big yard and set up to fly... and it looked like the wind was up enough to try the little slope. That slope has been the death of more than a couple of my planes and this one was no exception! Seemed like it was flying a bit nose heavy first time off and with full up, got it down to the bottom in almost one piece. Ground looped it and broke off the rear skid. OK, no problem, a quick fix and she was good to go. Took some nose weight off and gave it another toss of the edge and she went out, I turned and went right, but when I turned back around to come back up the ridge, she went nose up, then nose down, straight into the ground. Split the nose, top and bottom of the fuse. So my next entry will be the building of a new fuse. There are a few things I will do differently with this one so there is some good that will come out of it. So I'll be back in a couple of days.
In other good news, it looks like the cam mount for the sunglasses is going to work well. Got video of the short flight, but I'm not going to put that up. To much editing in the audio to be worth while, and I'm just to embarrassed to show it... ![]() Mark |
I do need to get it back in the air, just been procrastinating a bit on it. Maybe somewhere in the back of my mind I'm punishing it for smacking up the way it did, even though it was my fault. Thanks for posting Kent, and putting this to the forefront. I really should let it out of it's corner now. Maybe I'll get to it tomorrow. ![]() Mark |
| Thread Tools | |
| Discussion Tarno Carb. Working Adjustable Air Bleed For TD's | astronomer1 | 1/2A Planes | 8 | Jan 28, 2012 05:58 AM |
| Paint bleed under tape - How do you avoid | edkoz | Scale Fuel Planes | 9 | Apr 11, 2004 05:24 PM |
