Old Jan 31, 2012, 11:46 PM
dwazzer is offline
Find More Posts by dwazzer
United Kingdom, Cumb
Joined Jan 2012
Help with my Gaui 500x with 330x power set, scorpion motor problem
Hi everyone, great forum I am in the uk and mainly fly fixed wing but I am just getting into Quadcopters and loving what they can do!
I had a gaui 330x-s kit for Christmas, the newer one with scorpion motors. While flying it a couple of weeks ago I lost control as it suddenly dived to the floor and crashed. As a new quad pilot I assumed it was my fault and went to inspect the wreckage :frown:
1 broken arm and 2 broken props.
I decided to take the opportunity to upgrade to the 500x airframe which seems to be a much easier design than the 330x and it folds for storage
The build went well, so I decided to take it to work to test fly in a larger garage (in my lunch break of course ) after about 2 minutes of trimming and hovering, the quad made a funny sqeeeek and tipped over, crashing to the floor :frown: when I picked it up it was un-damaged but one of the motors was much hotter than the others! I held it by the skids and applied throttle and after a few seconds the hot motor squeaked and stopped..!
So, I don't think it was pilot error that caused it to crash in the first place, and the original 330xs kit was new at Christmas.
Has anyone else had a problem with scorpion/gaui motors failing, and do you think I should seek a replacement from my LHS?
Cheers, Dave.
dwazzer is offline Find More Posts by dwazzer
Old Feb 01, 2012, 03:59 AM
Azrael82 is offline
Find More Posts by Azrael82
÷sterreich, O÷, Linz
Joined Oct 2011
Check Motorbearings, i had to change all of them because they went bad after 5 flights.
Check for broken motorcables, had those aswell on my 330X.
Markus
Azrael82 is offline Find More Posts by Azrael82
Old Feb 01, 2012, 10:06 AM
GotHeliRC is offline
Find More Posts by GotHeliRC
http://gothelirc.com/
GotHeliRC's Avatar
United States, AZ, Chandler
Joined Dec 2011
It could be your bearings, but check the magnet first make sure it didn't throw a magnet, if it squeek and crash seem more like it threw a magnet in flight.
If you need bearings, we have ABEC5 high quality bearings replacement here.
http://gothelirc.com/shopdisplayprod...2&cat=Bearings
GotHeliRC is offline Find More Posts by GotHeliRC
Site Sponsor
Old Feb 01, 2012, 10:18 AM
dwazzer is offline
Joined Jan 2012
Thanks for the replies guys,
I had the motor apart last night and it definitely hasn't thrown a magnet...they are all sat where they should be Also, I don't think the bearings are shot as the motor spins nice and freely in there....might be different after it has been running a few minutes though???
is there any other reason why this could happen, it seems strange that as soon as it does, if I drop the throttle it will work again almost straight away (it does fail again quickly though )
And my motor cable connector broke straight away during the build aswell...Pretty poor quality if you ask me as I am not heavy handed
Think I will contact the LHS, just don't want to sound like a winging customer, cos I am definitely not that!!!
Any more suggestions are very welcome
Cheers, Dave.
Old Feb 01, 2012, 02:48 PM
Jem3 is offline
Find More Posts by Jem3
United States, OR, Portland
Joined Aug 2011
gothelirc - THANKS! I've been looking for replacement bearings. Mine are noisier than I'd like, but keeping them well oiled has worked so far.....
dwazzer - I've used "Scorpion Motor Oil" with micro applicators. gothelirc also has oil
http://gothelirc.com/shopdisplayprod...ch=Yes&sppp=20
LOTS of help for 330X and 550 here
http://www.rcgroups.com/forums/showthread.php?t=1229089
In forum: Multi Rotor Helis
Jem3 is offline Find More Posts by Jem3
Sold Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC HeliPro5 Aircraft - Electric - Multirotor (FS/W) 0 Oct 23, 2011 09:29 PM
Discussion Gaui 500X upgraded from 330X throttle problem. lsjack Multirotor Talk 1 Sep 11, 2011 06:42 PM
For Sale RTF Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC. 3DTRYER Aircraft - Electric - Helis (FS/W) 3 Jan 11, 2011 02:41 PM
For Sale RTF Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC. 3DTRYER Aircraft - Electric - Helis (FS/W) 10 Oct 06, 2010 04:01 PM
For Sale RTF Gaui 330X-S QUAD FLYER KIT WITH SCORPION MOTOR AND ESC. 3DTRYER Aircraft - Electric - Helis (FS/W) 1 Sep 12, 2010 11:14 PM
