Old Dec 31, 2012, 01:03 AM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
I find the Sabre easy to fly inverted but others have said it isn't . Try it and see what you think.
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 31, 2012, 02:15 PM
Wamp is offline
Find More Posts by Wamp
Wamp's Avatar
Joined Mar 2012
Soon as decent weather comes this way!
Inverted flight helps me adjust the cog.
Naturally some planes, like poly dihedral units, just do not like it.
Saber with 30 beeps of down trim may not like being inverted at all either.
Good to know it will do it, thanks Chris
Wamp is offline Find More Posts by Wamp
Old Dec 31, 2012, 07:34 PM
emeraldc is offline
Find More Posts by emeraldc
west coast flyer
emeraldc's Avatar
Joined May 2012
Beauty day here so I got 2 more flights. Only did one battery on the maiden cause I forgot the wire to recharge the anylink bat. 3 minutes is bang on, 20-25% left in stock battery. Really have to throw it downwards on hand launching, or it will pitch up & stall. Put elevator sub trim back to zero, fly's good, but when I tried inverted she headed for the ground, had full elevator on before I had to spin her upright and get back up. Won't be flying inverted. Keep some speed on the turns, and it's great fun to fly, & looks very cool....
emeraldc is offline Find More Posts by emeraldc
Old Dec 31, 2012, 08:48 PM
knighttwister is offline
Find More Posts by knighttwister
end user
knighttwister's Avatar
USA, WI, Neenah
Joined Feb 2006
sounds nose heavy
knighttwister is offline Find More Posts by knighttwister
Old Jan 01, 2013, 11:04 AM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Originally Posted by knighttwister View Post
sounds nose heavy
Yes, seeing Nitrocharge's inverted flight report, he must have the cog
Spot on.
Looks like he does lateral and fore and aft at the same time!
Ugly weather here. Chris
Old Jan 04, 2013, 11:06 PM
jon.moab is offline
Find More Posts by jon.moab
United States, UT, Farmington
Joined Oct 2012
I flew my son's Sabre today and have a question for you. About 30 seconds after take off, the motor pulses, as if it has detected low voltage. The battery was freshly balanced. I flew the plane 2 1/2 minutes and landed. The cells still have 3.8 volts in them. The motor continued to pulse every 30 or so seconds during the flight. I flew it on 4 different batteries and all did the same thing. Any ideas what causes this?
jon.moab is offline Find More Posts by jon.moab
Old Jan 05, 2013, 02:01 AM
PAPE is online now
Find More Posts by PAPE
Joined Jun 2012
That is that your loosing signal. Its not the LVC. Try a better antenna position for the anylink and also the RX antenna take it and point it up, there is a grove on the canopy, the pilots seat where it can be bent into.
PAPE is online now Find More Posts by PAPE
Old Jan 05, 2013, 06:25 AM
end user
USA, WI, Neenah
Joined Feb 2006
mine does that sometimes in a hard banking turn. it's like it loses signal for a split second, but recovers before it has any effect on flight surfaces. only throtlr is affected.
if you are in cold weather, that may cause it also.
Old Jan 05, 2013, 09:04 AM
jon.moab is offline
Joined Oct 2012
Thanks for the info. I will give this a try. I was flying in 15 degree temps, so yeah, it was cold!
Old Jan 10, 2013, 01:59 PM
TcCobra13 is offline
Find More Posts by TcCobra13
TcCobra13's Avatar
Seymour,TN
Joined Feb 2010
what is the best battery for this plane and where can u get them for the best price?
TcCobra13 is offline Find More Posts by TcCobra13
Old Jan 10, 2013, 06:27 PM
Wamp is offline
Wamp's Avatar
Joined Mar 2012
Ditto question.
Still looking for good air. Chris
Old Jan 10, 2013, 07:35 PM
eltreato is offline
Find More Posts by eltreato
"Unappreciative tosser"
eltreato's Avatar
Canada, BC, Vancouver
Joined Oct 2011
Originally Posted by Wamp View Post
Ditto question.
Here's one I like these days, l also use it with my 32" foamy profile plane and my 130x. It requires an adapter for the lousy micro deans plug. rc-connectors.com sells an adapter or you can make one yourself.
http://www.hobbyking.com/hobbyking/s...mpatible_.html
eltreato is offline Find More Posts by eltreato
Old Jan 10, 2013, 09:38 PM
Tyler83 is offline
Find More Posts by Tyler83
United States, TX, Katy
Joined Dec 2010
Never mind guys, did some swapping on the ex and got her fixed up
Hey guys just picked up one of these at the hobby shop for $59 with anylink. It was to cheap, I couldn't pass it up even though my th9x isn't compatible with it. Thought they maybe a good excuse to start looking for a good dx6i Ive been wanting any way. Well I got home and was reading the manual and saw that the rtf version comes with the same exact transmitter I have that came with my 3 channel flyzone micro super cub. So that was a nice coincidence for I guess. I got it abound and all the channels working but It has the throttle ailerons on the left stick and the rudder and elevator on the right stick. Is there anyway to change this so it is a regular mode 2 set up?
Tyler83 is offline Find More Posts by Tyler83
Old Jan 10, 2013, 10:19 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Your TX may be compatible after all. http://www.rcuniverse.com/forum/m_10...m.htm#11009889
gulio is offline Find More Posts by gulio
Old Jan 12, 2013, 05:03 PM
Team30 Micro EDF
Adelaide, Australia
Joined Apr 2004
For a really direct lipo swap out - the nanotech 260mah lipo is perfect for the job.
New Product Great Planes 30mm Brushless Micro EDF F-86 Sabre! NitroCharged Micro EDF Jets and Power Systems 2807 Dec 11, 2015 02:07 AM
Article FIRST SIGHTING: Great Planes F-86 Micro Sabre at the Arizona Electric Festival Michael Heer Micro Ready-to-Fly 31 Jan 09, 2013 06:49 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
