Old Dec 11, 2012, 04:22 PM
Freddie B is offline
Find More Posts by Freddie B
Addicted to building...
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Originally Posted by Mike20 View Post
Anyone have spare main wings and vertical/horizontal stabs they want to sell? I live in the US and I've been waiting patiently for them to get in stock at Tower Hobbies for about 3-4 months now. I'd really like to fly this amazing jet again.
Have you thought about cutting some of your own from foam stock to get her flying even if they aren't as scale looking as the originals?
Fred
Freddie B is offline Find More Posts by Freddie B
Old Dec 11, 2012, 05:49 PM
Mike20 is offline
Find More Posts by Mike20
Mike20's Avatar
Joined Sep 2012
Fred
No never thought of doing that. I really dont have the skills to form new wings from foam. I think it would be good to learn though, sure would save me alot of money.
Mike20 is offline Find More Posts by Mike20
Old Dec 11, 2012, 06:52 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Are you Stateside? Like in USA. There are options in most countries and it wouldn't be so hard.
Old Dec 11, 2012, 07:06 PM
Mike20 is offline
Mike20's Avatar
Joined Sep 2012
Yea I live in the states. Florida actually.
Old Dec 11, 2012, 07:15 PM
Freddie B's Avatar
Omaha Nebraska
Joined Feb 2006
Then probably easiest to find Dollar Tree Foam local for the wings, and probably a foam take-out container for the tail feathers. You can cold form the wing camber by rolling a 2" or so pipe/rolling pin over it on carpet or a firm couch! Make your templates off a pieced together broken section and use a sharp/new hobby knife to cut. Hinges can be clear tape or fancy as you want. Not too hard and you can cruise the scratch built foamies threads for specifics if needed.
Good luck!
Old Dec 11, 2012, 07:29 PM
tonytester is offline
Find More Posts by tonytester
Yo R Wee Too Lo
United States, OH, Cleveland
Joined Oct 2011
now I'm ashamed of my self
[QUOTE=BadLemon;21195871]I picked mine up yesterday and found 3 problem right out of the box that makes me want to return it.
Problem 1. Is cosmetic the nose cone was installed clock wise a few degrees not a big problem for me but a little bit of an eye sore. See pic's below.
yes the assembler must have been daydreaming about his Chinese girlfriend.
tonytester is offline Find More Posts by tonytester
Old Dec 12, 2012, 08:19 PM
Yo R Wee Too Lo
Joined Oct 2011
question
if the TX voltage is showing only 9.4 volts, would that cause the anylink not to turn on.
thanks
tonytester
Old Dec 12, 2012, 08:55 PM
gulio is offline
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Not sure what TX you use , but the voltage range for powering anylink is above and below that amount. I'm sure the max is higher than 12 volts and I THINK the minimum is less than 6. I'm still searching to find the doc I can't remember where it was. Your answer is NO.
I use the anylink on the 9x like you.
gulio is offline Find More Posts by gulio
Old Dec 14, 2012, 03:52 PM
Kevin Greene is offline
Find More Posts by Kevin Greene
United States, TN, Jackson
Joined Mar 2007
You can now get the entire plane for $59 with FREE AnyLink at Tower Hobbies...For that price I'll get another!!!---And sell the AnyLink cheaply to a guy that can use it...
Kevin
Kevin Greene is offline Find More Posts by Kevin Greene
Old Dec 14, 2012, 08:55 PM
Joined Mar 2007
I just got the plane with AnyLink for $59.95 SHIPPED!!!..I had a $5 credit at Tower Hobbies....For this price you can't really complain....I didn't like how fickle the plane was to launch correctly as compared to the HH AS3X MiG 15....But once the Sabre was in the air I liked how the plane flies...I can't hardly wait to try this Sabre on the new 3S 180mAh NanoTechs that I recently bought...
Kevin
Old Dec 15, 2012, 10:42 PM
Yo R Wee Too Lo
Joined Oct 2011
any link and 9x turnigy
I just flew my f86 with my turnigy 9x
step1 remove the module from it's socket and leave it out.
step2 open tx and move the positive wire (from the center lug charge jack ) to
the otherside of the diode from whence it came.
step 3 you can reverse the polarity if you wish but i left it standard.
step4 reassemble the tx.
step5 make a short wire using a male coaxial plug on one end , on the other end
install a size M female coaxial jack part 274-1577 (radio shack) WIRE IT IN REVERSE POLARITY
CENTER ON ONE END TO OUTSIDE ON THE OTHER END. the female plug
will be + on the outside and - on the inside. then follow the instructions for a jr tx. plug in trainer jack. screen should light up. then plug in power plug. anylink will light up.
plug in jet batt. hear beeps, arm esc, and check controll surfaces and off you go
now all i need to do is set up some parameter on the tx to match my ability.
like mlow rates any suggestions will help.
tonytester
will fly more tommorrow.
Old Dec 16, 2012, 12:37 PM
Yo R Wee Too Lo
Joined Oct 2011
turnigy 9x
did not mention to reverse throttle.
I need some input suggestion from you good flyers.
I set the end points at 100%, dr at 100 with -10 for high and 60 with -30 for low.
Iam only guessing with these numbers.
I want the jet to bank in the direction of the turn how do i set the mixing.i gues the rudder would be master and the aileron would be slave . but to what %. ?
tonytester.
Old Dec 19, 2012, 11:47 PM
daddydog is offline
Find More Posts by daddydog
Joined Mar 2011
Anyone know if the Great Planes ElectriFly LiPo 2S 7.4V 300mAh 20C battery will fit? The dimensions are 52 x 32 x 8mm (2.1 x 1.3 x .0.3")
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXTSR6
daddydog is offline Find More Posts by daddydog
Old Dec 20, 2012, 03:49 PM
NitroCharged is offline
Find More Posts by NitroCharged
Team30 Micro EDF
NitroCharged's Avatar
Adelaide, Australia
Joined Apr 2004
That will be too wide and long.
NitroCharged is offline Find More Posts by NitroCharged
Old Dec 20, 2012, 05:22 PM
daddydog is offline
Joined Mar 2011
Thanks for the info Nitrocharged.
New Product Great Planes 30mm Brushless Micro EDF F-86 Sabre! NitroCharged Micro EDF Jets and Power Systems 2807 Dec 11, 2015 02:07 AM
Article FIRST SIGHTING: Great Planes F-86 Micro Sabre at the Arizona Electric Festival Michael Heer Micro Ready-to-Fly 31 Jan 09, 2013 06:49 PM
Sold Eflite F-86 Sabre BNF EDF Jet NEVER FLOWN ready to fly!!!! thutt3430 Aircraft - Electric - Jets (FS/W) 1 Apr 17, 2011 10:34 PM
