Espritmodel.com Heli Air
Old Jan 31, 2012, 06:18 PM
United States, CA, Laguna Beach
Joined Dec 2009
Diagonal rolling lines...
Got a new 690tvl camera and today was first time flying it and I have lines rolling across my screen. Some times it gets worse they happen with motor on or off. I had to re solder things because my old camera was 5v and this one is 12v, I use 5v reg for vtx. Also MUTE SOUND, easier to see lines if full screen.
MUTE SOUND
fpv skywalker ezosd (5 min 44 sec)
Some times when lines are bad are at :30 1:05 2:40 and anything past 4:40 and it looks worse before I condense it for youtube.
ruffo is offline Find More Posts by ruffo
Old Jan 31, 2012, 08:19 PM
OSUFPV - KF7VFT
Corvallis, OR
Joined Apr 2010
MUTE SOUND
http://youtu.be/gkofs_WmDqU Some times when lines are bad are at :30 1:05 2:40 and anything past 4:40 and it looks worse before I condense it for youtube.
Do you use an LRS? Thats the kind of interference I'd get from having my unfiltered DL too close to the VRx. Are you flying on 1280vid/433control?
Also just something else I noticed is that there are smaller lines of distortion that crop up every now and again. Are you using an onboard mic? If you arn't make sure you ground the VTx audio wire.
Blues
Blueshy is offline Find More Posts by Blueshy
Old Jan 31, 2012, 09:00 PM
Joined Dec 2009
Blues
No LRS 2.4 video and 72mhz and no onboard mic
Old Jan 31, 2012, 10:11 PM
Daemon's Avatar
Lakewood, Colorado
Joined Aug 2002
Since it doesn't change with the motor it's probably switching noise from the 5v BEC
powering your video Tx. When it was powering both a 5v cam and 5v tx, everything was
at the same ground potential, and now it likely is not.
ian
Daemon is online now Find More Posts by Daemon
Latest blog entry: My 2012 FPV year in Review
Discussion diagonal lines when using motor with video battery [FIXED] nyc863 Video Piloting (FPV/RPV) 6 Dec 08, 2011 08:19 PM
Discussion Diagonal lines in the video htran Video Piloting (FPV/RPV) 7 Sep 10, 2011 03:19 AM
Discussion Image problem - diagonal lines DerKorb Video Piloting (FPV/RPV) 6 May 01, 2008 03:41 PM
Question Frustrating XRB diagonal flight problem roffey Coaxial Helicopters 42 Apr 25, 2006 02:30 AM
