Old Sep 09, 2012, 03:32 PM
derk is offline
Find More Posts by derk
TheyreComingToTakeMeAway!
derk's Avatar
USA, ID, Coeur D'Alene
Joined Dec 2003
do cockroaches even swim? and aren't most longer than one inch?
i'm thinking of trying a scale boat, or at least semi scale that looks like a boat
derk is offline Find More Posts by derk
Old Sep 09, 2012, 03:52 PM
djdavies83 is offline
Find More Posts by djdavies83
We can rebuild it!
djdavies83's Avatar
United Kingdom, Wales, Swffryd
Joined Apr 2010
It was not long after I did that post I thought "maybe they are longer than an inch" I don't know if they float but with some foam glued to its belly the leg would be like little oars
What style of semi scale are you thinking, yaught, speed boat or cruise liner?
djdavies83 is offline Find More Posts by djdavies83
Old Sep 10, 2012, 12:08 PM
dave1993 is offline
Find More Posts by dave1993
RC beginner
New York
Joined Oct 2008
i am also jonesing to make a tiny scale boat. but first i got to beat derks "floating ice chest". lol! now that i know anything goes in the looks dept the current 1" design should be easy to beat (well.. maybe not THAT easy). in retrospect the actuator rudder on mine makes no sense. trimming 1/8" off made virtually no difference at all compared to derks 25mm. but stealing ideas from him and using one of my tiny .25 gram diy frsky rx it should be easy to get down there. and now i know how to upload to the rcgroups video gallery.
watch out! here i come!
dave1993 is offline Find More Posts by dave1993
Old Sep 10, 2012, 05:50 PM
We can rebuild it!
djdavies83's Avatar
Joined Apr 2010
I would love to see some info on that .25g RX Dave!
Old Sep 11, 2012, 10:04 AM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
thanks to the hard work of simonchanbers and kreature i was able to build rx that are cheaper and smaller than commercial units from info in this thread:
http://www.rcgroups.com/forums/showthread.php?t=1667453
i must say that getting size down there does come with a penalty. even though im considered a crack smd "whisperer" the dead bug construction of mlf package is challenging. also because im using a super tiny folded dipole w/o the fancy balun circuit or amp the range is less than off-the-shelf rxs. but good enough for my heli, quad, and micro parkflyers. and more than enough for a boat (i hope).
Old Dec 01, 2013, 09:46 PM
derk is offline
derk's Avatar
Joined Dec 2003
i know this boat will not be the smallest, or have the functions that were stated in the beginning of this thread, however i think it falls into this threads category.
i have been playing around with press molding a small boat hull the last few evenings and finally have something worth noting
its pulled from .020" styrene sheet, might see if i can get my hands on some thinner material. i have also been trying some other clear plastics with varying results, staying open to any options.
with all the equipment inside it weighs in at 1.6 grams, could be less once i get some smaller motors
i had to make the walls taller to keep the rim of the hull from getting the surface tension to crawl up to it when ballasted.
will post more as i get it. maybe i will make a few other hulls this way and see what comes of it.
Old Dec 04, 2013, 03:24 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
ono... just when flying season ends and i was dusting off my latest rx and 2.8mm pagers to beat your current world record. back to the drawing board!
Old Dec 04, 2013, 07:13 PM
derk is offline
derk's Avatar
Joined Dec 2003
dont worry dave, this one will likely end up longer than the last one. i just wanted to try out another receiver i have on hand, with one motor and an actuator.
the biggest limitation here as with micro airplanes is the physical size and weight of the battery. i could try and trim it down, but its not going to get a whole lot lighter or smaller.
hopefully i will be able to have a go at beating the last one soon, but not just yet
Old Dec 05, 2013, 07:06 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
I was thinking about building something small.. But designed and built more for speed like a rigger.
You guys think a pager motor could get a nano rigger up on plane? I don't see why one couldn't solder a wire drive on, tweak some props and race your buddies in the winter.
GiantScale is offline Find More Posts by GiantScale
Old Dec 06, 2013, 04:19 PM
dave1993 is offline
RC beginner
New York
Joined Oct 2008
for me it wasnt motor power but prop shape that limited speed. with my crummy cutouts from bubble pack plastic they barely crawl through the water. enough to turn and backup though which in this case is ultra important. otherwise you really cant consider it to be a boat in control.
personally i doubt youll ever get up on plane but it would be interesting to see what you do manage.
Old Dec 08, 2013, 04:45 AM
PeteSchug is offline
Find More Posts by PeteSchug
PeteSchug's Avatar
Elmhurst, NY (Queens in NYC)
Joined Apr 2004
The "I don't see why one couldn't solder a wire drive on, tweak some props and race your buddies in the winter." part is what interests me.
What props are you planning to tweak?
I think you're writing about something much bigger than what you're looking at.
When you get down to these sizes you'll find that you have to get fairly inventive and try five or six things before you have a solution that's acceptable. NOTE. I said acceptable, not great or fantastic.
Boredom Is Me has done some really cool small stuff but it's WAY bigger than what you see here and he's designing stuff that's being 3D printed by Shapeways. Why not go smaller? Because 3D printing has limited resolution and BIM is already pushing the limits.
Pete
PeteSchug is offline Find More Posts by PeteSchug
Old Dec 08, 2013, 08:29 AM
Iowa City Iowa
Joined Jun 2000
Pete
Yea, I will admit.. I was having a beer with my buddies at that moment. Staring outside wishing it was warmer..
But no, I understand the prop is carved from wood or suitable material and is around 5mm. And the boat is less than 3" long.
I envision a 8x12 pond made with 2x4's and plastic sheet and me and my friends having a blast with fast (for the size) boats in the winter.
I did it a few years ago with cars in the living room and track. It was huge and we had a blast, but everything gets old eventually..
Old Dec 10, 2013, 08:15 AM
Amp Abuser is online now
Find More Posts by Amp Abuser
Amp Abuser's Avatar
Joined Dec 2007
I've thought about using tin to make a surface prop for a sub 3in nano rigger producing a rooster tail in a 4 ft indoor plastic pool. I would like to try a tether rigger with copper winding wire sending the power to the motor and a rheostat throttle. You would only need enough hull to hold the motor and drive line.
Amp Abuser is online now Find More Posts by Amp Abuser
Old Dec 10, 2013, 08:22 AM
coriolan is online now
Find More Posts by coriolan
"Unnecessary Necessity"
coriolan's Avatar
Canada
Joined Sep 2006
That would be an interesting boat version of RTP flying!
coriolan is online now Find More Posts by coriolan
Old Dec 10, 2013, 01:01 PM
Amp Abuser's Avatar
Joined Dec 2007
Yes nano boats have their place as any sort of boating indoors during the cold nasty winter weather season is a plus. Would be a great way to test tin micro props for performance and tweaking bending in pitch, rake, cupping tin would be a sinch. You could just time the laps even monitor amp draw at the rheostat then set up the driveline in a nano RC boat once you find the best set up.
Discussion World's Smallest FPV-Camera for RC Airplane, RC Helicopter, RC Cars! hobbypartz HobbyPartz.com 13 Aug 02, 2014 06:41 AM
Article Pro Boat RC Retrieval Decoy Review: Great for a Child's First RC Boat Michael Heer Dock Talk 36 Jan 14, 2014 09:09 PM
Sold Rc boat brushless nitro custom trailer whitebone pro boat aquacraft kyosho reddyrightnow Boats (FS/W) 2 Oct 19, 2011 02:27 AM
Discussion Micro Boat need help finding smallest... jocappy Micro and Sub-Micro Boats 13 Aug 01, 2011 10:53 PM
