Old Jan 31, 2012, 10:44 AM
willy007 is offline
Find More Posts by willy007
Joined Jan 2012
Seaking 120a help
I have seaking esc in a ul1 and geico. on the bench they work great. the minute i put them in water. I can run them from half to 3\4 throtle. the second i hit full they fail and go to half throtle. I have read the instructions over and over. and have tried everthing i can think of to no luck. I have a stiletto with a turnigy 120 witch is the same as seaking. and i have no problems. it runs great. Am i doing something wrong or are they just junk? Help Willy.
willy007 is offline Find More Posts by willy007
Old Jan 31, 2012, 11:16 AM
scorpion1 is offline
Find More Posts by scorpion1
I feel the need for speed!
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Next time you hook it up, reptogram it to 3.0 LVC and take it off autoselect for cell count.
scorpion1 is offline Find More Posts by scorpion1
Old Jan 31, 2012, 12:57 PM
69zandar is offline
Find More Posts by 69zandar
Joined Nov 2011
Ditto ^^^^^
My dads did the same thing the lipo cutoff was set too high , He reset it to 3.0 and all was good .
69zandar is offline Find More Posts by 69zandar
Old Jan 31, 2012, 04:54 PM
willy007 is offline
Joined Jan 2012
I'll try it
Old Jan 31, 2012, 05:09 PM
willy007 is offline
Joined Jan 2012
120 esc
I checked my stiletto and it is set on 3.0 and my other ones are 3.2. So you are saying if i reset progam to 3.0 Ill have full throtle and they wont fail to half throtle when i excelerate? Also lipos are done at 3.0 am i at risk of battery damage set that low, And will they have enough power to return to shore? Please reply, Thanx for the help. WILLY
Old Jan 31, 2012, 06:42 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Sometimes the Turnigy ES'sC revert back to intial settings, i have to do it occasionally on my T180's. Dont know if its a "for sure" fix, but thats all i can think of other than a radio issue. 3v cutoff is fine as it is under load then, when it comes in the resting voltage will be right around 3.7v which is full depletion. You will have enough left to get it to shore, it cuts down to around 20-30% power.
Old Jan 31, 2012, 09:26 PM
willy007 is offline
Joined Jan 2012
Esc 120
I dont think its my radios, becouse the ul1 and geico both do it and they are set 0n 3.2, the stiletto is on 3.0 and it works good Im also runing on 5s but i dont think that matters, or does it? One more question. is the tutnigy a half way decent esc, and will it last awhile? or do i have to look foward to buying a couple of expensive castle esc 120. Please reply. it sounds like you know your what your talking about. thanx, Willy
Old Feb 01, 2012, 06:00 PM
Fast Guy is offline
Find More Posts by Fast Guy
Canada, ON, Thunder Bay District
Joined Apr 2007
I think the Turnigy and the HobbyWing SeaKing are the the same esc. Both made by HobbyWing. As far as your hitting LVC you may be over proped or your batteries may be sagging in voltage too much under full throttle.
Fast Guy is offline Find More Posts by Fast Guy
Old Feb 01, 2012, 06:27 PM
bill34207 is offline
Find More Posts by bill34207
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
That same thought on battery sag under load crossed my mind too.
bill34207 is offline Find More Posts by bill34207
Latest blog entry: Freewing F-5N Tiger 80 mm EDF
Old Feb 01, 2012, 06:41 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Apparently its happening with his 5000 50c batts as well.............hmmmm
Old Feb 01, 2012, 07:17 PM
Redneck Injuneer
bill34207's Avatar
Bradenton, Florida
Joined Aug 2007
You must be getting pm's from him. There's no mention af any ma or c rating in the thread. (or my vision is even worse than I realised)
Old Feb 01, 2012, 07:47 PM
scorpion1's Avatar
Southern U.S.
Joined Jun 2008
Phone call.............
Discussion Help for Turnigy Marine 120A ESC Taki_bg Racing Boats - Electric 12 Apr 07, 2011 04:21 AM
Sold Seaking 120 A-R RTR version titan29 Boats (FS/W) 3 Mar 12, 2011 10:42 PM
Discussion Hobbywing HV 120a/TURNIGY K-Force 120A-HV OPTO 5-12S Brushless ESC Samjet Electric Ducted Fan Jet Talk 11 Feb 17, 2011 12:46 PM
Wanted WTB Seaking 120A ESC V2 syncronized Boats (FS/W) 2 Sep 09, 2010 10:10 AM
Wanted Seaking 120A ESC MarcRacer18 Boats (FS/W) 1 Oct 21, 2009 01:34 PM
