Old Jan 31, 2012, 07:28 AM
njwxyz is offline
Find More Posts by njwxyz
Posted with DragonLink
Norway, Hordaland, Ask°y
Joined Jan 2012
Question
Are 35MHz TX of brand "X" compatible with 35MHz RX of brand "Y"?
...assuming using the same channel/freq. crystal?
I can get a good deal on a used RTF plane that I would like to crash a lot (I think others refer to it as "learning to fly" ;-), and it comes with cheap 4ch 35 MHz Zebra TX, but I really want to end up with the 35 MHz Robbe FX-18 TX. So I could get a good deal if the Robbe TX and Zebra RX are compatible.
My apologies if this is already covered in a thread somewhere... I couldn't find any discussion.
The reason I want to go with 35MHz on RC TX/RX is that in Norway, the most common bands used for FPV radios are prohibited- except for 2.4GHz, leaving me to chose between FM bands for RC. I'm trying to do my homework before getting too invensted in "inventory".
Thanks for any help/guidance/links to existing threads.
njwxyz is offline Find More Posts by njwxyz
Old Jan 31, 2012, 09:15 AM
slipstick is online now
Find More Posts by slipstick
Staffs, UK
Joined Nov 2003
All FM/PPM radios that I've ever seen or heard of on 35MHz are compatible but PCM radios are not. And of course AM and FM will not work together.
Unfortunately I don't know Robbe equipment well and I've never even heard of "Zebra" RC gear so I can't be certain about that particular combination.
Steve
slipstick is online now Find More Posts by slipstick
Old Jan 31, 2012, 01:01 PM
A.T. is offline
Find More Posts by A.T.
Joined Aug 2002
My apologies if this is already covered in a thread somewhere... I couldn't find any discussion.The reason I want to go with 35MHz on RC TX/RX is that in Norway, the most common bands used for FPV radios are prohibited- except for 2.4GHz, leaving me to chose between FM bands for RC. I'm trying to do my homework before getting too invensted in "inventory". Thanks for any help/guidance/links to existing threads.
Robbe (aka Futaba) FX18 Robbe (Futaba) FX-18 - Manual on 35 MHz PPM
(incompatible on PCM) is good to go with a Zebra 35Mhz Receiver provided
the receiver is fitted with the appropriate HITEC 35Mhz crystal
- do not use a Futaba RX crystal which is not cut to the same size, case size, nor same specifications.
Zebra Manuals: refer later to my webpage under "Manuals" as they will be uploaded to Dropbox within next hour.
Alan T.
Alan's Hobby, Model & RC FAQ Web Links (quick search = Ctrl+F)
A.T. is offline Find More Posts by A.T.
Old Jan 31, 2012, 01:33 PM
njwxyz is offline
Joined Jan 2012
Cheers, Steve. I think I'll play it safe and get matched TX/RX/crystals... I have quite enough variables right now, so need to add to the confusion. Thanks!
Old Jan 31, 2012, 01:43 PM
njwxyz is offline
Joined Jan 2012
Cheers, Alan. And thanks for the resource. I actually stumbled across your site not long ago looking for a manual for 35MHz Zebra TX. Bookmark .
So... if I understand correctly, as long as the (Futaba) crystal in the Robbe TX is the same channel as the (Hitec) crystal in the RX, I should be in business??? The more I read, the more I seem to get the impression that as long as the crystals match the technology they are installed installed in, 35MHz TX and RX are fairly compatible- as long as consider PPM/PCM. But I also believe the Robbe TX will work with both PPM and PCM FUTABA RX.
My head is spinning again.
Old Jan 31, 2012, 02:53 PM
A.T. is offline
Joined Aug 2002
Cheers, Alan. And thanks for the resource. I actually stumbled across your site not long ago looking for a manual for 35MHz Zebra TX. Bookmark.
But I also believe the Robbe TX will work with both PPM and PCM FUTABA RX. My head is spinning again.
You have it sorted, the Zebra manuals are now online (PDF), right click and "Save Target As":
Zebra RC systems - Zebra 4FM 1114 kb
Zebra RC systems - Zebra 3FM 1205 kb
Zebra RC systems - Zebra 2AM 1152 kb
Alan T.
Old Feb 01, 2012, 12:58 AM
njwxyz is offline
Joined Jan 2012
Alan T.
Good stuff, Alan. Thanks for uploading the manuals. :-)
Question Twister 3D Storm tx - What rx are compatible aussiecree Electric Heli Talk 0 Jan 10, 2012 04:12 PM
Discussion Are the flysky rx compatible with ppm tx? maurice076 Radios 4 Jan 05, 2012 10:42 PM
Sold Walkera Genius CP RX **Compatible with WK-2801 TX** Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Nov 28, 2011 02:04 AM
Sold Walkera Genius CP RX **Compatible with WK-2801 TX** Z06 Tony Aircraft - Electric - Helis (FS/W) 0 Nov 17, 2011 12:40 PM
Question Brand "X" crystal on Brand "Y" Rx ? Arthur_GA Radios 1 Mar 24, 2004 03:10 AM
