Old Jan 31, 2012, 04:26 AM
might is offline
Find More Posts by might
Denmark, Region Zealand, Greve Strand
Joined Oct 2008
Help!
Super simple mini osd
Hi
I am new to fpv, i have bought the HK 900Mhz 800Mw fpv set.
And that works just fine I have not yet flown it (due to winter here)
In the waiting time i have bought the HK super simple mini osd,and i have a few questions that i hope some of you can help me with.
The wiring from the batteri i think is okay ? pic. 1 (plus/minus corectly soldered)
Now the fun starts, where on the fpv wiring should the osd in/out wires go ? pic 2
I hope you understand my question, i am okay at soldering,but a total newbie
on the electronic. So please if you have an answer keep it simple.
Hope someone out there can help - Thanks
Jan
might is offline Find More Posts by might
Old Jan 31, 2012, 06:00 AM
ZIPPER is offline
Find More Posts by ZIPPER
by ZIPPER
ZIPPER's Avatar
East Kurrajong Sydney Australia
Joined Aug 2004
If you follow this diagram it should help, just dismiss the second OSD.
ZIPPER is offline Find More Posts by ZIPPER
Old Jan 31, 2012, 06:46 AM
might is offline
Joined Oct 2008
Hi ZIPPER
Thanks for your answer, i have seen this schematic on HK homepage.
But i have 3 wires comming out of the camera (red,black,white)
Which 2 wires are the ones i need ?
Old Jan 31, 2012, 08:09 AM
jsxx is offline
Find More Posts by jsxx
jsxx's Avatar
Wielka Brytania, Anglia, Derbyshire
Joined Jan 2011
Just ground and siglan- black and yellow
jsxx is offline Find More Posts by jsxx
Old Jan 31, 2012, 08:12 AM
spitfire_Doug is offline
Find More Posts by spitfire_Doug
spitfire_Doug's Avatar
Australia, WA, Carlisle North
Joined Jul 2008
They are red/+12v, black/ground and white/signal. Now from the camera, hook up the white wire and the black wire to the osd's vid in and ground. Then connect the vid out and ground from the osd to the video transmitter. This should work for you.
Regards
Doug
spitfire_Doug is offline Find More Posts by spitfire_Doug
Old Feb 01, 2012, 02:15 AM
might is offline
Joined Oct 2008
Hi Doug and jsxx
Okay i think i got it. So if you look at the pic. it should look something like this ?
Thanks for your help :-) i will start soldering and looking forward to testing it
Jan
Old Feb 01, 2012, 02:21 AM
might is offline
Joined Oct 2008
ups pictures here
sorry pic should be here
Old Feb 02, 2012, 08:48 AM
Joined Jul 2008
Perfect mate, that should do the trick .
Regards
Doug
Old May 24, 2012, 10:16 PM
AeroHeadTW is offline
Find More Posts by AeroHeadTW
AeroHeadTW's Avatar
United States, NJ, Berkeley Heights
Joined Nov 2009
Hello,
I have the same osd and a similar wiring situation. Did the wiring shown in the photo/diagram work for you? I keep thinking it shouldn't work as the battery lead doesn't have a direct connection to the tx via the red lead.
Regards
AeroHeadTW is offline Find More Posts by AeroHeadTW
Old May 24, 2012, 10:51 PM
might is offline
Joined Oct 2008
Hi AeroHeadTW
If you follow the picture in post #7 that should work id did for me
Jan
Old May 24, 2012, 11:45 PM
nogas is offline
Find More Posts by nogas
Because gas is for BBQ's
nogas's Avatar
Australia, QLD, Brisbane
Joined Feb 2011
might - does it show your battery voltage connected like that? you haven't connected anything to the battery input so does it just show the timer?
Heres how i did mine. Remember if your using a 1 battery set up that you may need a LC filter (ferrite ring and Capacitor) to filter the 'noise' from the motor / esc.
nogas is offline Find More Posts by nogas
Old May 25, 2012, 08:54 AM
Ceros007 is offline
Find More Posts by Ceros007
Ceros007's Avatar
Montreal, Québec, Canada
Joined Apr 2010
+1 for might
Ceros007 is offline Find More Posts by Ceros007
Old May 31, 2012, 06:05 AM
might is offline
Joined Oct 2008
Hi Nogas
Sorry i havent answered before.
Its been a while since i used this osd (have bought a new - better one)
I am not sure i understand your question but i have modified my picture i hope this helps you - if not please ask again.
Jan
Old May 07, 2014, 10:40 PM
nige838 is offline
Find More Posts by nige838
United States, TX
Joined Oct 2009
Can't get this OSD to work. IT just blinks red fast. Anybody know what this means?
nige838 is offline Find More Posts by nige838
Old May 09, 2014, 06:00 PM
nige838 is offline
United States, TX
Joined Oct 2009
Ok, got it to work, now the text jumps around while my quad is powered. Wondering how to fix this...any help very appreciated.
Question HK G-OSD II Mini OSD System w/GPS Modul simplyfly FPV Talk 8 Nov 27, 2012 02:56 AM
Discussion HK simple OSD siim227 FPV Talk 55 Jan 12, 2012 04:10 PM
Sold (pics) Drotek 10DOF LLC + Arduino Pro Mini + Super Simple Shield (new) flyboygaac Aircraft - Electric - Multirotor (FS/W) 0 Dec 05, 2011 01:30 PM
Sold Simple OSD + GPS + 50A Curent sensor Coil FPV Equipment (FS/W) 2 May 13, 2011 12:04 PM
Alert Simple OSD - 2 voltages and timer - HK - $13 bob4432 Hot Online Deals 0 Mar 29, 2011 06:16 PM
