Old Mar 02, 2012, 02:04 AM
Modelholic is offline
Find More Posts by Modelholic
Modelholic's Avatar
Perth WA
Joined Feb 2007
Alright Antionette it is then. I won't make any dibs on the Swallow/Scooter. Let it go to anyone else that expresses an interest.
Modelholic is offline Find More Posts by Modelholic
Old Mar 06, 2012, 02:51 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Nothing really to add on the model front. Have just come back from a long weekend away with the family.
My order from Hobbyking has arrived and of course Peter is right that the chosen motor isn't going to work out for the Rex racer. Back to the drawing board on that one.
On the plus side found myself being given the opportunity to get 1.5 hours flight training in this.....
Old Mar 08, 2012, 03:49 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Something beginning to resemble an aeroplane.
Next job mount the servos and prepare for the control runs.
Old Mar 08, 2012, 05:46 AM
trumps is offline
Find More Posts by trumps
What's 3D?
trumps's Avatar
Australia, WA, Ellenbrook
Joined Feb 2008
Looking great mate, what's with the control line plan in the background, that stuff is no good for you, makes you dizzy and then fall down sober, never a good look bud!
Craig
trumps is offline Find More Posts by trumps
Old Mar 08, 2012, 06:05 AM
PETERRAKE is offline
Find More Posts by PETERRAKE
Norfolk, England
Joined Sep 2001
That looks rather nice. Is it just an effect of the photo, or is it a bit light on dihedral? I make it there should be around 3/4" under each extreme tip, but can't remember if I sent you the drawings with the revised F2A or the older one with the incorrect F2A - it didn't reach the spar slot and required a bit of packing.
Pete
PETERRAKE is offline Find More Posts by PETERRAKE
Old Mar 08, 2012, 10:57 PM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Thanks Craig, I think it will turn out OK.
The control line plan is explained here: http://www.rcgroups.com/forums/showthread.php?t=1569254
Not that it will be finished in time to take part officially in Funbuild 5. The plan on the wall is to the original 35" span and is just there for reference, inspiration and decoration!
Pete - just suffering a little bit of droop. Don't quote me on that! We'll get the dihedral sorted don't worry.
Simon
Old Mar 09, 2012, 03:58 AM
Norfolk, England
Joined Sep 2001
Phew, that's a relief. I had horrible visions of them being firmly glued in place. Just checking my files, I can see that I've modified the plans, but the pdf files are still the older version.
However, knowing how you research you models, no doubt you saw comments about this in the other thread.
Pete
Old Mar 09, 2012, 11:30 PM
Modelholic's Avatar
Perth WA
Joined Feb 2007
I realised if I installed the servos at this stage I would severely limit my access when it came to sew on the undercarriage. I want to paint the forward fuselage before I mount the undercarriage. So changed tack slightly.
Soldered up my connectors (2mm bullets) for the motor, ESC and battery. Spaced out the motor mount appropriate to the chosen motor. Needed 5/8th balsa packing. Note to self: Try harder to track down the motor shown on the plan! The kit supplied motor mount was bevelled as indicated on the plan to introduce down and side thrust and all checked for fit. Have made some attempt at representing the Gnome rotary. Very "cartoon scale" but better than nothing I suppose. I think I've still got room in the cowl for the ESC at this time.
Simon
Old Mar 09, 2012, 11:45 PM
trumps is offline
What's 3D?
trumps's Avatar
Joined Feb 2008
looks good mate.
Old Mar 13, 2012, 03:59 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Peter - what is your opinion on this for the Rex?
http://www.hobbyking.com/hobbyking/s...tor_100w_.html
I did find the XT but at 2.5 times the price!
http://www.hobbypartz.com/30brmo13rpm.html
Your thoughts sought please.
Simon.
Old Mar 13, 2012, 04:05 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Of course a different suggestion with link to same would also be appreciated!
Old Mar 13, 2012, 08:07 AM
Norfolk, England
Joined Sep 2001
That looks fine. Overkill on power and a little heavier than the XT but the weight won't go amiss in the Rex and throttle control takes care of the extra power.
Yes, the XT is a bit costly, but that's what I had to hand when I drew up these plans - and is what's in my 'motors' file.
Pete
Old Mar 15, 2012, 09:24 PM
Modelholic's Avatar
Perth WA
Joined Feb 2007
A little more.
Old Mar 16, 2012, 02:30 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
Managed to lay down some paint on the forward fuselage today. Tamiya Acrylic - semi gloss black.
Old Mar 16, 2012, 02:37 AM
Modelholic's Avatar
Perth WA
Joined Feb 2007
And assembled in the late afternoon....
Yippee! RC Karts : Who's going to Battlefield RC in Georgia for TERC kart races? CeriJonston Large Scale Cars 141 Feb 09, 2013 01:10 PM
Build Log Peter Rake's Morane Saulnier Racer pafusion Scale Kit/Scratch Built 35 Apr 06, 2012 10:06 AM
Build Log Peter Rakes's DFW-C.V 2nd prototype BaZsiX Scale Kit/Scratch Built 32 Sep 10, 2011 06:28 PM
Build Log Peter Rake, Rex Racer 65Chevelle Scale Kit/Scratch Built 44 Apr 12, 2009 06:03 PM
Peter Rakes "Sopwith Tri-Plane" Robert Hoffman Scale Kit/Scratch Built 465 Apr 01, 2005 07:03 PM
