This thread is privately moderated by Garret H, who may elect to delete unwanted replies.
Old Jan 30, 2012, 11:21 PM
Garret H is offline
Find More Posts by Garret H
Garret H's Avatar
USA, CO, Fort Collins
Joined Sep 2007
Cool
Peak 480 (Suppo 2814) - perfect upgrade motor for ParkZone T-28 & More!
If you are looking to upgrade the stock motor on your Parkzone T-28 Trojan, Corsair, or other PZ model, check out the Peak 480 (Suppo 2814) motor from Altitude Hobbies! We've recently conducted testing using this motor in a PZ Trojan and were extremely happy with the results. Our Peak 480 is the same physical size as the stock 480 motor, weighs 7g LESS, but puts out over 100W MORE power! This makes for outstanding performance; even at just half-throttle, the plane is capable of spirited aerobatics and excellent vertical performance. This motor is also incredibly quiet and smooth. A minor modification to the stock motor mount is needed, however cowl spacing should not be affected. No CG modifications are needed, and you can even use the stock ESC.
Just $23.99!
http://www.altitudehobbies.com/index...&product_id=86
Garret H is offline Find More Posts by Garret H
Site Sponsor
Old Apr 22, 2012, 12:24 PM
copperbricks is offline
Find More Posts by copperbricks
You can't take the sky from me
copperbricks's Avatar
United States, OH, Cincinnati
Joined Aug 2011
Just out of interest, what sort of modification to the motor mount was required? thanks and does the bolt pattern on this, and the peak 15 match the parkzone bolt patterns?
copperbricks is offline Find More Posts by copperbricks
Old Apr 23, 2012, 12:42 PM
Garret H is offline
Garret H's Avatar
Joined Sep 2007
I replied to your PM. The mount holes do not line up exactly, but it is easy to modify the mount to allow the Suppo to fit. The length of the Suppo 2814 (Peak 480) is just right for cowl clearance.
Garret
Site Sponsor
Wanted Parkzone T-28/Corsair 480 motor housing Gravity Dodger Aircraft - Electric - Power Systems (FS/W) 0 Jan 14, 2012 05:59 PM
Sold Parkzone 480 Brushless motor (Corsair / T-28) TexasAggie Aircraft - Electric - Power Systems (FS/W) 2 Jan 01, 2012 07:39 PM
Wanted 480 size motor T-28 upgrade endeavor Aircraft - Electric - Power Systems (FS/W) 4 Dec 12, 2011 03:49 PM
For Sale Parkzone t-28 480 960Kv outrunner brushless motor patpatpatme Aircraft - Electric - Power Systems (FS/W) 2 Dec 02, 2011 03:26 PM
Sold Parkzone 480 motor with T-28 motor mount jetflyr Aircraft - Electric - Power Systems (FS/W) 3 Mar 20, 2011 03:59 PM
