This thread is privately moderated by MetroGTi, who may elect to delete unwanted replies.
Old Jan 30, 2012, 10:07 PM
MetroGTi is offline
Find More Posts by MetroGTi
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
Blu-F-O Part 2
I just finished this version and am waiting for a chance to maiden it. It's a 1/2 scale version of the Blu-F-O made from 3mm & 1mm Depron. ALW came in at 62gr. I hope it flies as well as the larger version.
Update:
Maidened this little bugger the other day. It was very sensitive in the roll axis and I doinked it because I lost orientation. It was better on the second flight after I dialed the ailerons down to about 70% travel, but I still over corrected and rolled it into the ground. Before the next flight I'm going to taper the elevons a bit so they are a bit narrower at the tips. Hopefully that will lower the roll rate a tad without losing the thrust vector effect at low speed. I'll probably add some color to help with orientation too. Other than that, it has plenty of power and really scoots.
MetroGTi is offline Find More Posts by MetroGTi
Old Mar 24, 2012, 05:13 PM
MetroGTi is offline
Mexia Izonfia
MetroGTi's Avatar
Monticello, MN
Joined Oct 2003
I successfully flew the Mini Blu-F-O today. Since the earlier flights, I've added some small wing tips and they seem to have helped tame the roll rate. It was a bit overcast and made it difficult to see the plane, but I was happy with the performance and the handling. I just need to get some lighter/brighter colors on the plane so I can see it better.
Old Aug 01, 2015, 10:01 PM
George63 is offline
Find More Posts by George63
George63
United States, MS, West Point
Joined Jul 2015
BluFO
I saw your you tube and my BluFO doesn't fly anywhere near that well. Please help me out. I built from the kit, have a Emax 2812, apc 9x5 prop.
Thanks, your flying was great!!!!!
George63 is offline Find More Posts by George63
I.F.O. as O.F.O. kennypinkerton Parkflyers 0 Apr 20, 2003 11:11 PM
F-18 construction- part 2!! gbruce Electric Ducted Fan Jet Talk 192 Feb 12, 2003 11:54 AM
