Old Oct 10, 2003, 03:36 PM
Racebelly is offline
Find More Posts by Racebelly
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
Drawing planel lines...
I have a Flying Styro F-16 that I would like to add a little realism to. The panes lines are all molded into the foam. However, I've seen many people draw their own or highlight exisiting planel lines. What's the best method to do this? I've seen people use black markers but I don't want it too pronounced. It's a bit overdone then.
Mark
Racebelly is offline Find More Posts by Racebelly
Old Oct 11, 2003, 02:39 AM
vintage1 is offline
Find More Posts by vintage1
vintage1's Avatar
East Anglia, UK
Joined Sep 2002
I have used a silver marker pen over dark surfaces - and light. Doesn't work too well over chrome of course
Heres a picture of a couple of models done this way - they don't show up that well, but thats probably what you want anyway
Old Oct 11, 2003, 07:25 AM
St. Martin is offline
Find More Posts by St. Martin
Big gov never Works
St. Martin's Avatar
Skunk Water, Rhode Island
Joined Jul 2002
Re: Drawing planel lines...
Mark
The only thing needed for the FS F-16 is high-lighting. This can be accomplished with chalk pastels. This will require a clear coat.
(one that will not melt foam)
The other way is to use a airbrush, spaying very lightly. This takes a little practice, but will not require a clear coat, which will keep the plane lighter. A definet requirement for this plane. I use a piece of card-stock to keep the hard edge of the high-lighting to the front of the plane, or to the left or right.
As in anything in modeling, people can provide you with guidance, but you will be your ultimate teacher, through, just doing it.
Steve
St. Martin is offline Find More Posts by St. Martin
Old Oct 11, 2003, 08:32 AM
dottney is offline
Find More Posts by dottney
dottney's Avatar
United States, NY, Fairport
Joined Jun 2000
I've used a permanent ultra fine line Sharpie pen for panel lines. See my Rittinger Tony.
Dave
dottney is offline Find More Posts by dottney
Old Oct 11, 2003, 09:15 AM
leccyflyer is offline
Find More Posts by leccyflyer
Sloping off....
leccyflyer's Avatar
United Kingdom, Aberdeen
Joined Sep 2000
I use a propelling pencil on painted surfaces. The pencil line comes out silvery grey and fairly unobtrusive. On foam it has the added benefit of slightly indenting the foam and if done with a light touch it looks quite effective.
Once saw a Leicester Model Centre Harrier where the panel lines had been put on with a black marker pen and it looked like Spiderman's personal aircraft- very much over the top.
Brian
leccyflyer is offline Find More Posts by leccyflyer
Old Oct 11, 2003, 09:38 AM
Richard ll is offline
Find More Posts by Richard ll
Fe Fi Fo Fum
Richard ll's Avatar
Useless Loop, Australia
Joined Apr 2001
Mark
Chris Golds-A prolific UK aeromodelor uses black and white markers to give "highlights and lowlights"(my words)-when used subtly it looks great...
I saw it mentioned on another thread here recently-If you're interested try a search on his name (not as a user name).
Rich
Richard ll is offline Find More Posts by Richard ll
Old Oct 11, 2003, 01:03 PM
mario alvarez is online now
Find More Posts by mario alvarez
Fight On!
mario alvarez's Avatar
San Salvador, El Salvador
Joined May 2001
Do you own an airbrush? If so, mask everything but the panel line you want to highlight. Spray the panel a dark color. I usually mask only one side and spray the dark color in the direction of the airflow. Tedious, but it does work and it gives the panel line a nice feathered edge.
I prefer this technique than actually drawing the panel line in.
mario alvarez is online now Find More Posts by mario alvarez
Old Oct 11, 2003, 09:04 PM
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
Thanks for the tips everyone. I do own an airbrush. I will do some experimenting with the highlighting technique. What's a good mix for color? I'm guessing a grayish blackish something.
I also like the idea of the pencil.
-Mark
Old Oct 12, 2003, 01:17 PM
gbruce is offline
Find More Posts by gbruce
gbruce's Avatar
Canada, AB, Airdrie
Joined Oct 2001
Pencil!
Fine Drafting pencil is EXCELLENT, easy to use , realistic,and weathers really nicely by wiping your finger in the direction of the airflow.
Bruce
gbruce is offline Find More Posts by gbruce
Old Oct 13, 2003, 01:32 AM
Vault-Tech Approved
Racebelly's Avatar
Simi Valley, CA
Joined Apr 2003
Bruce,
I like that effect you get with the drafting pencil. Good idea.
I'll have to try that out.
-Mark
Panel Lines Spinner Scale Kit/Scratch Built 13 Jan 24, 2003 07:41 AM
What's your favorite way to do panel lines?? Jim Walker Scale Kit/Scratch Built 9 Nov 21, 2002 12:41 PM
Panel lines? megawatt Scale Kit/Scratch Built 10 Aug 08, 2002 12:04 AM
Panel Lines ? LJH Scale Kit/Scratch Built 5 Dec 17, 2001 11:05 PM
Recessed panel lines? Slope Nut Scale Kit/Scratch Built 28 Oct 30, 2001 01:25 PM
