Old Jan 30, 2012, 08:37 PM
brianshell is offline
Find More Posts by brianshell
brianshell's Avatar
United States, UT, Ogden
Joined Nov 2011
What do I buy to put these props on this motor?
I know this is a dumb question (you guys have been ridiculously patient answering my dumb questions)... But I ordered some Graupner props to put on my XAircraft Hexa w/ the XA motors.
What prop adapter do I buy so make this work?
These props: http://www.mikrokopter.us/shop/index...product_id=245
These motors: http://www.cnchelicopter.com/servlet...s-P1001/Detail
Or will they just fit? The XA has an odd-shaped fit, which is why I'm asking. =)
brianshell is offline Find More Posts by brianshell
Old Jan 30, 2012, 11:12 PM
SeismicCWave is offline
Find More Posts by SeismicCWave
AMA 46133
Hawaii
Joined Feb 2003
The shaft on the motor looks really hard to find a proper adapter. The shaft is 4 mm but the hub on the Graupner prop is 8 mm. So you need to get a prop adapter that will fit on a 4 mm shaft with a 8 mm shaft for the propeller. You probably have to cut the shaft on the motor so the prop adapter won't be so high. If you have a machine shop near by I will just get the shaft changed.
SeismicCWave is offline Find More Posts by SeismicCWave
Old Jan 31, 2012, 01:19 PM
Morphin is offline
Find More Posts by Morphin
Schweiz, BE, Münchenbuchsee
Joined Jun 2011
Any more sugesstions?
Morphin is offline Find More Posts by Morphin
Old Jan 31, 2012, 01:31 PM
AMA 46133
Hawaii
Joined Feb 2003
Put together a machine shop and make your own adapter! How many suggestions do you want?
Make a 4mm ID and 8mm OD sleeve and put the prop on the existing shaft.
Get creative!
Old Jan 31, 2012, 01:43 PM
Morphin is offline
Joined Jun 2011
I hope to buy something finished:
Would any of these adpater works?
http://www.electricwingman.com/product.aspx?product=696
http://www.electricwingman.com/product.aspx?product=684
http://www.electricwingman.com/product.aspx?product=688
http://www.electricwingman.com/product.aspx?product=705
Thank's
Andy
Old Jan 31, 2012, 06:57 PM
AMA 46133
Hawaii
Joined Feb 2003
Yes but the issue will be the threaded area on the shaft. If you use the prop adapter with set screw the set screw will bite into the threaded area and damage the thread. If you use the prop adapter that uses a collet the collet may not have enough surface area to hold. Then again the threaded area may deform the inside wall of the collet making a good contact.
I cannot tell since I have never put a prop adapter on a threaded shaft. I have enough machine at my workshop I just change the shaft to some drill rod blank.
Old Jan 31, 2012, 07:11 PM
n3m1s1s is offline
Find More Posts by n3m1s1s
UK, Buckinghamshire, High Wycombe
Joined Feb 2007
maybe try a couple of sizes of fuel tube? sound stupid i know but it flew a quad i built today
By n3m1s1s at 2012-01-31
n3m1s1s is offline Find More Posts by n3m1s1s
Reply With Quote  (Disabled)
Old Jan 31, 2012, 07:12 PM
mr.incredible is offline
Find More Posts by mr.incredible
An ordinary sort of incredible
mr.incredible's Avatar
United States, TN, Knoxville
Joined Dec 2004
The motor shafts are threaded. All you should need is a 4mm to 8mm spacer. The slow-fly props usually come with adapters. After you bolt on the prop you will want to dremel off the excess shaft. Wrap the motor in a plastic bag so the filings don't end up in the windings and magnets. Leave a couple mm above the prop too.
You may not get the performance you hope to out of the E-props. They are usually a little heavier than a good slow-fly prop. The extra weight translates into sluggish changes in motor speed. Since we are relying on the change in motor speed to control the attitude it will mean sluggish response. Most people have gone back to APC slow-fly props. They seem to be the best in endurance and the best trade-off for weight versus stiffness.
mr.incredible is offline Find More Posts by mr.incredible
Old Jan 31, 2012, 07:54 PM
thewz is offline
Find More Posts by thewz
"It's a Quad" :O
thewz's Avatar
Temecula
Joined Jul 2004
Blueskyrc sent 4mm adapters along with the props last time I ordered some. Might want to check with Dave and see if he can send you some.
thewz is offline Find More Posts by thewz
Discussion So I've got these two motors, what should I put them in? stgdz Electric Plane Talk 3 Oct 10, 2011 01:27 PM
Question What's the strongest motor you can put on an AR6400L? cwolfe Electric Plane Talk 4 Sep 15, 2011 05:05 PM
Discussion what plane can I put this on six series eflite motor and 54amp speed control? sherlockshah Power Systems 10 Jul 17, 2009 10:02 AM
Discussion Can I put a prop on this motor? What size? CClark Glow to Electric Conversions 4 Oct 07, 2008 04:41 PM
If I buy a astro 020 motor do I have to do anything if I put it in a pusher thor4944 Power Systems 4 Jan 01, 2003 03:01 PM
