Leeds, UK
Joined Dec 2003
I've got used to that, rudder and throttle.
Mine does tend to pull quite strongly even if I bring the motor to idle, I've even got about 5mm left rudder as neutral. Looking last night I noticed the motor isn't straight, its facing slightly right when looking from above. |
New Zealand, Auckland
Joined Dec 2008
old prop just pulls off best upgrade is a brushless motor. edit: actually this is the best upgrade :-) http://www.hobbyking.com/hobbyking/s...dProduct=18473 |
+1 for the Vector 850. Heaps better than the Atom but the Atom is still fun once upgraded to a brushless set up and ailerons and better at slower speeds so can be flown in tighter spots. However, once you have added a brushless esc you have probably spent more than the Vector
Andy |
I guess I just ruined my ESC. Yesterday when I arrived my flying site I realized that my receiver was not bound to TX. I made a wrong decision - I used a car key to short the ground and signal on receiver to enter the "BIND" mode. As you may imagine, I accidently shorted the signal and positive pole which made my ESC stop working. I checked the servos and motor and they are fine. The receiver is also good. Now I am looking for an ESC that can be used in this little guy.
Anyone has any clue what ESC I can use here? Thanks in advance! btw, I saw a guy selling his Multiplex Permax 400 motor and X-16 Speed Control. Does it work with my motor? http://www.rcgroups.com/forums/showthread.php?t=1806946 |
Here's a new one that's somewhat heavy, but it's cheaper than the combo you linked. Rotsa Ruck. |
| Thread Tools | |
| Discussion Hobby King Pearl EPO Glider Thread | tomcor | Foamies (Kits) | 14 | Aug 19, 2012 07:39 AM |
| For Sale hobby king ventus glider with retract wheel | ED3 | Aircraft - Electric - Airplanes (FS/W) | 2 | Jun 17, 2011 02:10 PM |
| Discussion hobby king Phoenix 2000 EPO Composite R/C Glider | doomracing | Electric Sailplanes | 3 | May 31, 2011 10:09 PM |
| Discussion Hobby King ASK21Mi Glider | DavidWalker | Australia | 7 | May 10, 2011 04:09 AM |
