Old May 27, 2012, 09:56 PM
looking up down under
scruffy1's Avatar
Australia, NSW, Fairlight
Joined Feb 2008
looks like i need to do some static testing with the 18-11 2000 and the miniswifft prop, because my "bigger" option the 2211-1700 and the 8x4.5 folding prop seem heller big for the task, even though i can squeeze them in
16gm for the little one with prop, versus 46.5gm for the big one, due to the lovely but heavy aluminium spinner
losing an ounce to aid gliding versus going up faster is my aim
so, 3s lipo - 5.2amp max, drawing 50w might be a winner
scruffy1 is offline Find More Posts by scruffy1
Old May 27, 2012, 10:25 PM
Rotary~myPast,Present &Future!
SINGAPORE
Joined May 2006
Great work Harry, i won't be surprised that your atom is uniquely perfect after all that work you put in.
Mine was dented pretty bad after a series of nose dives due to my own silly mistakes of pulling down the elevator stick at hand launching it.
And subsequently more kamikazes into the ground when I installed the following FPV gear
1. 3grams 5.8ghz video transmitter
2. 12grams 3.3v regulator for the VTX
3. 5g clover leaf antenna
4. 16g 12v Sony pz0420 camera
5. 13g 3cell 120mah batt for the FPV
Total load is about 50g and the plane could not climb up with full throttle. It either did its kamikaze dive or glide a few cm above the ground at best.
I removed the 16g camera and the 13g battery and it flew like a dream again ...
Looks like this plane can only carry 25g or less.
5hrs spent on a sat to put in the FPV and what a disappointment !
terencechan is offline Find More Posts by terencechan
Old May 29, 2012, 07:08 AM
CPMBOY's Avatar
Malaysia, Sabah, Kuala Penyu
Joined Aug 2011
ready for maiden
waiting for a perfect weather tomorrow...dunno whether this bird can carry the hd wing camera or not?....btw..where is the CG for this little bird?........
CPMBOY is offline Find More Posts by CPMBOY
Old May 29, 2012, 08:31 AM
Space Coast
Space Coast
Joined Oct 2000
cg - in the middle of those holes under the spar.
http://www.rcgroups.com/forums/showp...0&postcount=20
hoppy is offline Find More Posts by hoppy
Old May 29, 2012, 12:46 PM
Joined May 2012
Hi everyone! I'm new to the hobby and this is my first plane and after a few days of flying I broke my propellers. Can anyone tell me where I can get cheap props that fit on the stock motor? Also, does the ESC have a lvc? Thank you!
mike662 is offline Find More Posts by mike662
Old May 29, 2012, 01:36 PM
Joined Mar 2011
Originally Posted by CPMBOY View Post
just sharing before its maiden......
thank you on tips. yah probably somewhat lower right side that always fly in a clockwise direction.
how thick wedge that you use?
alphaeyes is offline Find More Posts by alphaeyes
Old May 29, 2012, 05:38 PM
Space Coast
Space Coast
Joined Oct 2000
it has a LVC.
Old May 29, 2012, 08:22 PM
Since 1952
Edmonton, Alberta, Canada
6.0 volts LVC, on mine.
Harry D is offline Find More Posts by Harry D
Old May 29, 2012, 08:52 PM
CPMBOY's Avatar
Joined Aug 2011
abt 0.15 mm....depends on how much your right wing is been lowered. emm...does anybody had this deformation on your atom?...
Old May 30, 2012, 03:22 PM
Joined May 2012
Can anyone share where they buy props from for this plane or what props will work?
Old May 31, 2012, 04:03 AM
Joined Mar 2011
the stock prop is 11cm, you can use 5inch or 4inch prop. hmm how about prop adapter? 2mm prop adapter on brushed motor??
Old May 31, 2012, 11:28 AM
SINGAPORE
Joined May 2006
Have the same problem, and here is my fix
Old May 31, 2012, 03:51 PM
HoosierGuy's Avatar
Joined Jan 2012
I need a glider that is cheap and I can sacrifice. I want to start flying gliders over the river and fly over a big lake. If I lose it in the water I don't want to be out on too big an investment. This glider might fit my needs. Not sure if I want this glider or one of those Bixler or that AXN Floater Jet glider.
HoosierGuy is offline Find More Posts by HoosierGuy
Old May 31, 2012, 07:10 PM
CPMBOY's Avatar
Joined Aug 2011
if this little atom falls on water, it will surely go down bcoz of the air inlets on the fuse.....
Discussion Hobby King Pearl EPO Glider Thread tomcor Foamies (Kits) 14 Aug 19, 2012 07:39 AM
For Sale hobby king ventus glider with retract wheel ED3 Aircraft - Electric - Airplanes (FS/W) 2 Jun 17, 2011 02:10 PM
Discussion hobby king Phoenix 2000 EPO Composite R/C Glider doomracing Electric Sailplanes 3 May 31, 2011 10:09 PM
Discussion Hobby King ASK21Mi Glider DavidWalker Australia 7 May 10, 2011 04:09 AM
