Old Jan 30, 2012, 06:48 PM
Fentonflyers is online now
Find More Posts by Fentonflyers
Fentonflyers's Avatar
United States, MO, Fenton
Joined Jan 2012
Question
FlySky- JR transmitter module compatability
I have done some searching and have not been able to arrive at a definitive answer. I purchased a FlySky module hoping to use it in my 9303 but the module gets warm and the voltage indicator on the screen behaves strangely. I have found some threads here that state incompatibility and reference to a mod but I can't seem to come up with anything. Can anyone offer advise or point me in the right direction?
Jay
Fentonflyers is online now Find More Posts by Fentonflyers
Old Jan 30, 2012, 08:50 PM
caseih is offline
Find More Posts by caseih
Joined May 2005
The FrSky module should work. I don't think the FlySky will, though, as one of the pins isn't the same.
caseih is offline Find More Posts by caseih
Old Jan 30, 2012, 09:48 PM
Daedalus66 is offline
Find More Posts by Daedalus66
60 years of RC flying
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
FrSky is fine.
But the FlySky module will damage the transmitter and probably itself unless suitably modified. DON'T USE IT.
Modification requires opening up the module, cutting the connection to pin 2 (counting from the top) to avoid shorting the JR voltage regulator (why your transmitter is heating up!). It also requires installing two resistors to lower the PPM voltage going to the module (JR uses about 8v, while FlySky needs less than 3v). Not a big job but be sure you know what you're doing.
Best solution with the JR is to go FrSky, which is a superior system with longer range and proper failsafe. Also telemetry if you want it. No problem as it's designed to be compatible with JR and others, while FlySky is not.
Most of the information is fairly old as people have generally given up on this combination, since the FrSky is superior and the FlySky can be used in the cheap 9x transmitter. Here's one, though.
http://www.hobbyking.com/hobbycity/f...az6f73a65c2f33
Daedalus66 is offline Find More Posts by Daedalus66
Old Jan 30, 2012, 11:54 PM
Joined Jan 2012
Originally Posted by Daedalus66 View Post
FrSky is fine.
Thanks!
I have several of the FlySky receivers and just want to make use of them for the park flyers. I have a Futaba 7C that I installed the FrSky hack module in and it is great. I will be ordering a module for the 9303 as well as more telemetry products. The FlySky is fine though for the cheapy foamies that I like to fool with.
Jay
Old Jan 31, 2012, 07:56 AM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
Originally Posted by Fentonflyers View Post
Thanks!
Jay
Just want to be sure you understand that you MUST NOT use the FlySky module with the JR 9303 transmitter unless you modify the module internally. Otherwise you will very likely damage both the transmitter and the module.
There is no problem using an FrSky module in the JR transmitter without modification.
I emphasize this because many people confuse FlySky with FrSky.
Old Jan 31, 2012, 08:56 AM
Joined Jan 2012
Understood. Going to do the mod. Thanks!
Old Jan 31, 2012, 12:28 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I thought you probably did but wanted to be quite sure, especially for anyone else reading the thread.
Old Dec 18, 2012, 05:48 PM
GiantScale is offline
Find More Posts by GiantScale
Iowa City Iowa
Joined Jun 2000
I was also told to look for a Flysky JR module for my 8103 so I could bind to a WLToys V911 instead of buying yet another cheap transmitter. Turnigy 9X
How inferior is the 9X to my XP8103 as far as mixing programming? Is the JR modification to the module difficult?
GiantScale is offline Find More Posts by GiantScale
Old Dec 18, 2012, 06:55 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
The modification to allow the FlySky module to be used should not be too difficult, though I haven't actually done it.
The 9x, even in stock form, is quite a capable transmitter, though it has some quirks and is poorly documented. If you do the conversion to install alternative firmware, it becomes more powerful than the JR as far as programming is concerned.
Old Dec 23, 2012, 12:39 PM
Iowa City Iowa
Joined Jun 2000
Could you walk me through the modifications for the flysky/JR module please?
Iv been reading about the 9X and learned the new 9XR will supersede it so Im going to wait.
Old Dec 23, 2012, 05:17 PM
JimO is offline
Find More Posts by JimO
Hacienda Heights, CA
Joined Sep 2000
Here's the link to mod the HK 2.4 (Flysky v.1) module for use in JR tx's:
http://www.rcgroups.com/forums/showthread.php?t=1087351
I don't know what the v.2 board looks like, but this may help.
Jim
JimO is offline Find More Posts by JimO
Old Dec 23, 2012, 10:01 PM
Daedalus66's Avatar
Canada, ON, Ottawa
Joined Feb 2006
I will take a look inside the V2 module and see what needs to be done. The same basic approach should work, but the board is different from the V1.
It might take a couple of days, as there are other priorities coming up! Enjoy the holidays.
Old Jan 21, 2013, 01:43 PM
Toad1 is offline
Find More Posts by Toad1
Joined Jul 2011
Got any info on v2 yet?
Toad1 is offline Find More Posts by Toad1
Discussion Frsky JR Module into Flysky 9X ?? aesmith Radios 7 Feb 06, 2012 11:23 AM
Discussion FlySky/Turnigy RF9X A7105 transmitter module RSSI rotaryboots Radios 1 Jan 23, 2012 03:40 AM
Wanted FlySky TH9X Transmitter Module scyzer Aircraft - General - Radio Equipment (FS/W) 4 Oct 01, 2011 10:46 PM
Sold New Flysky th9x/ turnigy 9x mode 2 V2 transmitter,module and 8 channel receiver jgpncll Aircraft - General - Radio Equipment (FS/W) 1 Mar 10, 2011 07:46 PM
Help! Finding a 72Mhz TX Module for Turnigy/FlySky/Eurgle 9x transmitter penpen Radios 13 Oct 29, 2010 01:38 AM
