Old Jul 06, 2012, 08:52 PM
TK421 is offline
Find More Posts by TK421
Plainfield, IN
Joined Sep 2004
That is great news!! I really hope they go for it ;-)
Lou
TK421 is offline Find More Posts by TK421
Old Jul 06, 2012, 09:03 PM
Clintstone is offline
Find More Posts by Clintstone
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
Yeah, it is working very well and Mr Mel has great videos up. Right now the Hobby Wing Sensor works well I am told and Castle will have our sensor out soon... Testing the final version next week if all goes well...
Clintstone is offline Find More Posts by Clintstone
Old Jul 06, 2012, 10:30 PM
HiroboFreak is offline
Find More Posts by HiroboFreak
Australia, NSW
Joined Mar 2011
Will you please release some recommended ESC settings for Align 750MX motors prior to the firmware/sensor release?
HiroboFreak is offline Find More Posts by HiroboFreak
Old Jul 06, 2012, 11:00 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
http://www.castlecreations.com/suppo...0mx-530kv.html
I have not run the motor nor do I have one... I was told the 700 MX settings work just fine...
You need to enter 12t pinion and 112t main as it has a helical main gear.
I would probably run the following Head Speeds...
1850
1950
2150
Old Jul 07, 2012, 12:42 AM
OnTheSnap is offline
Find More Posts by OnTheSnap
OnTheSnap's Avatar
Santa Clara. Ca
Joined Dec 2008
Clinstone, please kick them in the nuts and get this firmware out already!
OnTheSnap is offline Find More Posts by OnTheSnap
Site Sponsor
Old Jul 07, 2012, 03:19 AM
baui2000 is offline
Find More Posts by baui2000
baui2000's Avatar
Česká republika, Jihomoravský, Brno
Joined May 2011
+1, thanks
Good to know there's some progress.
baui2000 is offline Find More Posts by baui2000
Old Jul 07, 2012, 11:05 AM
TK421 is offline
Plainfield, IN
Joined Sep 2004
So... I flew again this morning. I tried several gains and ended at 30 and still have a slight chatter. At this point, I think it is the low resolution issue that MrMel talked about in his last video.
Clint,
What numbers are you getting for your limits? I am at -66 and 66... On the up side, it seems that the head overspeeds and doesn't droop at all.
I'm really looking forward to this new firmware. I really hope it fixes my issue..
Lou
Old Jul 07, 2012, 11:27 AM
OnTheSnap's Avatar
Santa Clara. Ca
Joined Dec 2008
Clint,
Lou
My limits are -68/68.
I get some chatter only in piro maneuvers. I assumed it was something Goblin or tail servo related but perhaps it's somehow gov related. Outside of piro maneuvers no chatter at 37 gain.
Site Sponsor
Old Jul 07, 2012, 01:12 PM
TK421 is offline
Plainfield, IN
Joined Sep 2004
VBar 5.2 Episode 20 - Governor Electric Remake (23 min 4 sec)
I think this is the latest video as far as GOV set-up. on here he talks about too low a number on the v-bar limits will cause a tail wag. I get mine when I load the head and the gov overspeeds and then settles back to a consistent RPM. It did get better with the lower gains but it is still there. While flying smooth big sky style stuff, the HS is locked in and super smooth. When I start to spank on it a little like tic-tocs and fast flips it will chatter. Piro's feel same as any other V-bar tail and no issues noticed there either.
Lou
Old Jul 07, 2012, 05:57 PM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
My limits are -124 and +98 with the new firmware -68/68 will get broader...
I used the Castle Calibration technic with the ESC plugged in to set the limits and I got the tone for 100% and I got the arming Tone when I reached -0- throttle... It was pretty simple to Apply that to Mr Mel's video.
You will have soft start and the auto rotation idle mode and setting the castle to auto enabled and setting the HS change rate to the desired recovery ( I use 18 ) will be a plug and play solution to stop the motor and use Castle Auto-Rotation recovery.
Results are simple setup that you can test on the bench... I am still testing today with another setup to check gains with a different motor... KDE 700 XF on an E7... And Torque servos... The Futaba S-Bus system works great on the VBar with default channels... I am using the Gyro function for Bank switching and if needed I can change the gain for the GOV with this function also.
When gain is to High it sounds like a rattle... 2 points can take the sound away... by using the bank switching it was easy to set the gain and test small differences.
Old Jul 07, 2012, 06:08 PM
TK421 is offline
Plainfield, IN
Joined Sep 2004
Sweet sweet sweet. I so can not wait for this. I really think it will fix my issues and really make it worth having waited for so long...
Lou
Old Jul 08, 2012, 05:04 AM
RC Man is online now
Find More Posts by RC Man
A man with too many toys
United States
Joined Feb 2001
I would really like to get one of those new CC Phase Sensors to test with my new Skookum SK540 flybarless controller. There are a lot of CC customers that fly other brands of external governors and I hope that CC tests more than just V-Bar before they market the hardware/software package.
RC Man is online now Find More Posts by RC Man
Old Jul 08, 2012, 08:24 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
We have talked with Art at Skookum as he is working on firmware... The sensor is pretty cool and takes about 2 minutes to install.
We worked with Mikado to protect both the Esc and the vbar to ensure they worked well together. We have also sent info to Skookum.
Old Jul 08, 2012, 10:30 AM
United States
Joined Feb 2001
Sounds like you are real close to having an excellent product. I hope it’s not too long before I can purchase a sensor.
Keep up the good work,
RC
Old Jul 08, 2012, 10:50 AM
Castle Support
Clintstone's Avatar
USA, GA, Statesboro
Joined Oct 2007
RC
I am told the Hobby Wing sensor works... I am trying to find one to give it a try...
*****SCORE***** Found one... on order... looks like the install will not be as neat but I want to try one.
Discussion Cant use update client or firmware update jaysbay Hoverfly Technologies 6 Nov 07, 2011 10:19 PM
Sold SOLD-F/S Blue Mini V-Bar V 5.0 ---Like New-SOLD ptflyer Aircraft - Electric - Helis (FS/W) 1 Nov 06, 2011 04:22 PM
Sold BNF T-Rex 500 ESP Mikado V-Bar dawhale Aircraft - Electric - Helis (FS/W) 2 Apr 11, 2011 04:16 PM
Help! Where can I get\download a firmware update for schulze isl 6-330 v 8.50? eitanro High Performance 1 Oct 04, 2010 04:12 AM
