Old Feb 25, 2012, 12:19 PM
czirh is offline
Find More Posts by czirh
Use your imagination....
czirh's Avatar
Greece, Dafni
Joined Oct 2007
Nice project, subscribed.
Cem
czirh is offline Find More Posts by czirh
Old Feb 25, 2012, 04:57 PM
1stfoot is offline
Find More Posts by 1stfoot
New Zealand, Waikato, Hamilton
Joined Nov 2011
Hey Guys,
Thought I would post some pics of a bit of progress on my F22 based on the same plans Hover is using. I will be printing the rest of the ducts this week and re-joining them, hopefully they turn out alright.
Cheers,
Matt
1stfoot is offline Find More Posts by 1stfoot
Old Feb 25, 2012, 05:07 PM
Keenan smith is offline
Find More Posts by Keenan smith
was geht , müssen unten kommen
Keenan smith's Avatar
United Kingdom, London
Joined Dec 2010
where'd you get the plans ??
Keenan smith is offline Find More Posts by Keenan smith
Old Feb 25, 2012, 05:15 PM
1stfoot is offline
Joined Nov 2011
Hey,
They are Beta plans from an rcg member here is the link:
http://www.rcgroups.com/forums/showthread.php?t=805557
Considering they are beta plans I am modifying them slightly in a few area's such as hatches, battery box, ESC/Rx mounts and I will also be changing the way the elevons mount as I don't like the current mount for them.
Cheers,
Matt
Old Feb 25, 2012, 05:29 PM
Joined Dec 2010
what page are the actual plans on ?
Old Feb 25, 2012, 07:25 PM
1stfoot is offline
Joined Nov 2011
Plans on page 9 or here: http://www.rcgroups.com/forums/showt...=805557&page=9
Cheers,
Matt
Old Feb 25, 2012, 07:44 PM
Hover or die is offline
Find More Posts by Hover or die
it wasn't me flying that plane
Hover or die's Avatar
United States, NC, Wilmington
Joined Mar 2011
K.Smith,
I posted it in the first post lol...You have to download the 30 day trial of autocad to see the plans..It is pretty straight foreward but I ran into a few issues being comp illiterate lol..I just blew the plans up to my desired size and traced out the individual parts..Since I had to cut mine by hand i used thin ply and did not cutout all the material like Matt did..(he obviously has access to a laser cutter as well)
There are no plans per say,just all the parts to put together the airframe..You have to do a lot of the thinking for servo placement, control surface activation,ect....
Matt,
It looks killer!!What size ply did you use?I thought cutting out the 1/8" was pushing it but it looks like you used 1/4",which makes sense to use the cutout and it `looks great..I'm actually not far behind you i just need to take some pics...
Thanks for posting up the pics,,gives me incentive...
Take care.............................................. CC
Hover or die is offline Find More Posts by Hover or die
Old Feb 25, 2012, 07:54 PM
1stfoot is offline
Joined Nov 2011
Hey,
I found a laser cutter in Australia that was willing to do the job in fact everything is cut from 1/8th ply. At this stage mine won't have retracts unless I can find a decent set that won't look to out of place. What are you going to cover your fuse and wings with? I was thinking of a thin balsa layer then a layer or so of glass over the top of that.
Cheers,
Matt
Old Feb 25, 2012, 10:14 PM
Joined Mar 2011
Wow it surelook,s thicker. Cool you found someone to cut for you..i amskinning mine in 3mil depron and eitherglassing or just using the 2part hard shell for foam..take care....chris
Old Feb 25, 2012, 10:31 PM
ATIS is offline
Find More Posts by ATIS
Member 120mph Club
ATIS's Avatar
New Bern, North Carolina, United States
Looking good guys!
ATIS is offline Find More Posts by ATIS
Old Feb 26, 2012, 06:18 AM
mrshea is offline
Find More Posts by mrshea
michigan jet guy
mrshea's Avatar
USA, MI, Caledonia
Joined Jul 2007
that looks awesome. I have these plans and been thinking about twin 90's maybe sometime starting next winter. Good looking build. Phil
mrshea is offline Find More Posts by mrshea
Old Feb 26, 2012, 08:22 AM
Waltjg is offline
Find More Posts by Waltjg
Waltjg's Avatar
Crystal River Fl.
Joined Jul 2008
Chris, looking good keep up the pics on those ducts construction,one of my weaker areas of building,,,, I feel your pain on learning the ne tablet,, got a Ipad2 for Christmas, most of it is really easy, but a couple of things are pretty different and a learning curve for me,,, been using PCs since they come into existence but I love this iPad! Keep up the great work! W.
Waltjg is offline Find More Posts by Waltjg
Old Feb 26, 2012, 12:58 PM
Joined Dec 2010
I'm gonna build mine with 3mm depron
Old Mar 01, 2012, 02:37 AM
1stfoot is offline
Joined Nov 2011
Hey Guys,
I have had quite a bit of luck with 3D printing my ducts however I just bought the last set home this evening and somewhere something went wrong and the exhaust duct that I sectioned into two pieces doesn't fit together, meaning I will have to reprint it hopefully this will happen tomorrow.
I have attached a few images of the intake ducting which is all done and just needs joining.
Cheers,
Matt
Old Mar 01, 2012, 06:38 AM
Joined Mar 2011
Matt,
Wht are you building your intakes out of?Is that foam?
It will probably need reinforcing if it's foam..I'm not sure what you are powering your bird with..I ordered my motors last night for my jetfan 80's..
went with the HET 700 series motors (39mm)2250 kv..
I should see close to 7 lbs per side..
I put the bottom of my battery box in lst night and loaded it up with batteries to decide on 6 or 8 cells..Going to go with 6 per side for now to keep weight down..
I will post some pics of my progress today...
Sold Hanger 9 F-22 Raptor PTS fruitguy Aircraft - Fuel - Airplanes (FS/W) 7 Nov 09, 2011 10:18 PM
Wanted Hangar 9 F-22 Raptor Wing Droops banzi28 Aircraft - General - Miscellaneous (FS/W) 0 Oct 06, 2011 12:00 PM
Sold Texas Pickup - Customized F-22 Raptor, Receiver Ready - Mint! Roswalt Aircraft - Electric - Jets (FS/W) 6 Sep 27, 2011 02:50 PM
Sold Sapac F-22 Raptor - Dual EDF - Lowered Price!!! omster Aircraft - Electric - Jets (FS/W) 3 Sep 26, 2011 02:58 PM
For Sale Starmax F-22 Raptor Jcopter Aircraft - Electric - Airplanes (FS/W) 2 Sep 16, 2011 08:02 PM
