Old Jan 30, 2012, 03:29 AM
MADLOO is offline
Find More Posts by MADLOO
Joined Jan 2012
Skyartec wasp v3
Hello ALL,
I am BRAND NEW to all of this, I have never been involved in Forums before and I am new to the RC Heli game as well. I am asking for some advise from anyone who can offer it to me. I have a SKYARTEC Wasp V3 6ch Heli. I got given this for Christmas from my wife. I took it out of the box, charged the battery up and plugged it in. WELL!!!! This is when the problems started. The throttle was on a little and it took off like nothing else inside the house.. I know, HAHA it's funny right?? Anyway to cut a long story short, after re-disigning the wall and roof the Heli came down and it had stripped the main gear and bent the boom. I have just put it back together but now the main gear spins when the motor is engaged but it is not rotating the shaft. I have tried to clamp the main gear and the belt drive cog as tight as I can with the sleeves with the grub screws in them but it is not making any difference, the main gear just spins on the drive shaft. I'm unsure what I have done wrong but I must have left something out that locks the main gear to the shaft. I hope this makes sence to someone out there and I appreciate any advise that you can give me.
Cheers...
MADLOO is offline Find More Posts by MADLOO
Old Jan 30, 2012, 07:26 AM
Balr14 is offline
Find More Posts by Balr14
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
That sounds like the main gear has been turned over. The one-way bearing is turning the wrong way.
Balr14 is offline Find More Posts by Balr14
Old Jan 30, 2012, 02:56 PM
andione1983 is offline
Find More Posts by andione1983
andione1983's Avatar
Australia, VIC, Melbourne
Joined Nov 2011
good luck with skyartec their customer service is nonexistent... i have had very bad experiences with the v4 which i got rid of after stripping the main gear and being told the part is no longer available
andione1983 is offline Find More Posts by andione1983
Old Jan 31, 2012, 06:58 AM
MADLOO is offline
Joined Jan 2012
Ok thanks heaps for your advise, I will try turning the bearing around I had no idea the bearing is a one-way bearing. Also andione, I hope I have better luck than you have with Skyartec as I'm just getting into heli's and I don't want to be put off by bad service.. What brand heli do you suggest???
Thanks again..
Old Jan 31, 2012, 07:42 AM
Balr14 is offline
Cranky old fart
Balr14's Avatar
Germantown, WI.
Joined Oct 2007
If you have no experience, you should be starting with something a lot easier. Your location will dictate your choices. Some brands are a lot more expensive in some parts of the world.
Old Feb 01, 2012, 05:55 AM
Joined Nov 2011
If you want to jump straight into collective I would suggest the blade mcpx.... Nearly indestructable... Cheap to repair good to learn the basics
Build Log My First CP Heli: WASP V3 by Skyartec bobepine Micro Helis 89 Dec 12, 2013 11:24 AM
Mini-HowTo Upgrading Skyartec Wasp V3 FP to V3 CCPM skyartec-usa Skyartec 0 Jun 27, 2009 03:40 PM
Sold Skyartec WASP V3 6CH PRO "kinda" RTF with spares 120deg CCPM w/ BROKEN TX HighNear90 Aircraft - Electric - Helis (FS/W) 23 Apr 28, 2008 03:11 PM
Discussion honey bee fp or skyartec wasp v3 fp with brushless and belt drive quadracer111 Micro Helis 3 Mar 17, 2008 04:10 AM
Discussion thinking of buying the skyartec wasp v3 HURON Electric Heli Talk 12 Dec 04, 2007 11:56 PM
