Crank drive advantages:
- .................................................. ............................................ - You can change the angle of incidence and control the flight direction. - .................................................. ............................................ |
Joined Sep 2003
George |
Joined Sep 2003
You promote others to do your work at their expense. One successful application of fanning is the Venus fly trap. George |
Joined Aug 2011
Doesn't active wing twist and the fan effect in your wiggle drive produce more thrust than what a crank drive can do with its symmetrical movements Kjell?
The thing I'm most interested in is if the wiggle drive can perform all of the basic necessities as a crank drive in terms of flying at altitude and turns. Also why would Jarno Smeets choose a wiggle drive if it wasn't capable of performing just as good or better than a crank drive? Thank you for your posts! |
| Thread Tools | |
| Help! Belt Drive vs Shaft-Drive | kingofking1 | On-road Cars | 17 | Jan 20, 2012 07:52 AM |
| Discussion Shaft Drive vs. Belt Drive Help! | johnnyrocco123 | On-road Cars | 8 | Jul 27, 2011 08:39 PM |
| Discussion New Wiggle-Drive. | KJELL | Ornithopters | 177 | Nov 15, 2010 04:05 PM |
| Discussion Wiggle Twin Drive. | KJELL | Ornithopters | 3 | Jul 13, 2010 02:30 PM |
| Discussion The Wiggle-Drive. | KJELL | Ornithopters | 0 | Oct 18, 2009 04:16 AM |
