Old Feb 16, 2012, 01:53 AM
Joined Nov 2005
Originally Posted by jofro View Post
Installation and hook up of ESCs is fully complete, throttle calibration and some reprograming was performed followed by first run to check that all works well. Impressive sound and thrust on full stick and I can say it's not only the largest but most likely the most powerfull twin EDF foamy built. Next job will be static thrust test using scale just to give me an idea what it pulls, Joe.
Looks great, was reading the first post in the thread are you still thinking of doing twin 10s?
erh7771 is offline Find More Posts by erh7771
Old Feb 16, 2012, 05:18 PM
Joined Jan 2010
Hi 777, I can easilly upgrade this set up to 10-12S by only changing motors. Firstly I have to find out its performance on 8S, unfortunatelly I finished little over 7kg AUW, with all little bits and pieces I have installed and using larger cap. and higher C rated batteries but its still bellow MOP limit. Just taking it out to do more tests and range check, field still too wet to maiden it, Joe.
jofro is offline Find More Posts by jofro
Old Feb 16, 2012, 08:58 PM
Joined Jan 2010
Back from the field doing the range check and static thrust, better then expected while sitting on soft wheels it pulled 8.3kg dropping down to 8.1kg. It shows how much more efficient are multi powered models. No point going to heavier 10 or 12 cells when I get this power from 8S, Joe.
VID_0001.mp4 (1 min 39 sec)
Old Feb 16, 2012, 09:09 PM
Joined Nov 2005
http://youtu.be/bHUFIq2na0s
Joe, I think you're right on dual setups vs a single one.
For some planes dual 90mm setups come out less than expensive than a single 120 - 127 also.
Old Feb 17, 2012, 12:38 AM
Joined Jan 2010
Well, it seem to have almost 2kg more pull then both of my 12S, 127mm single set ups, tho they are both brilliant performers. Mind you I'm using 120a ESCs, heavy gauge leads and 45C paks which obviously improves performance. I'm under severe stress, hoping my CofG is close as this is totally new design and it could end up badly if its tail heavy as I did while ago with my 7.5Kw foamy monster, Joe.
Old Feb 17, 2012, 10:18 PM
Joined Jan 2010
It was smooth as a silk. I flew it today for some 100 meters along the empty beach only half a meter high but under full command in 90deg. cross wind, hoping the conditions will remain for full test flight at the club domany. Joe.
Old Feb 18, 2012, 11:11 PM
Joined Jan 2010
Magic jet fying today in almost perfect conditions, my maiden went better then expected using lighter set of batteries for the first flight and pushing them right down to my limit in less then 3min. flight time. Joe.
Old Feb 19, 2012, 03:00 AM
Joined Jan 2010
My maiden flight today, enjoy it Joe.
P1030199.mp4 (3 min 44 sec)
Old Feb 19, 2012, 07:36 AM
Joined Nov 2005
NICE!!!
This was done with no type of glassing?
What did your AUW end up to be?
Thx
Nice flying
Old Feb 19, 2012, 02:38 PM
Joined Aug 2011
Nice! You did an amazing job on this one... congrats on the successful maiden!
I guess hand launching is out though :-)
AgentSmith27 is offline Find More Posts by AgentSmith27
Old Feb 19, 2012, 04:08 PM
Joined Jan 2010
No f/glass at all, but leading and trial edging reinforced with balsa. It's all soft top! has to be handled accordinly. Video/maiden AUW was 7kg while using lighter only 30C, 4Ah packs not adequate for this set up. All 4 packs finished pretty warm over 40deg. cel. and right down to 3.7volts per cell. Next flights will be using 4.5Ah 45C and ordering new sets of 5Ah as ad on weight is no issue. It is a floater as you seen my landing, Joe.
Old Feb 25, 2012, 10:27 PM
Joined Jan 2010
Few more flights today with Twin Widow 'running-in' my latest heavier 5Ah packs. Must see the video I'll load later tomorrow of my landing. Just one foot short of the creek, perfect timing. Real challenge at our field to clear 20m trees just 70m short of the strip, then force the nose down building up more speed, the last thing you want on final, and then hope you got enough room to flare it and stop it short of the water at the end of the strip. I always prefer Southerly, Joe.
Old Feb 26, 2012, 09:13 PM
Joined Jan 2010
Twin Widow, here we go again with larger set of battreries, enjoy the footage, Joe.
P1030216.mp4 (3 min 28 sec)
Old Jul 10, 2012, 02:10 AM
Joined Jan 2010
Back again to rejuvenate this monster foamy build, couple of flights today in perfect calm conditions to "run in" larger set of batteries. I mounted vid cam to the nose, stay tuned for some spectacular footage. Joe.
Old Jul 10, 2012, 03:30 AM
Joined Jan 2010
Twin Widow on board video footage, enjoy it, Joe.
VID 0002 (4 min 59 sec)
Discussion Guanli A10 twin EDF Foamy ESC control mixing with a Futaba 9C tdrnmartin Foamy EDFs 1 Jan 17, 2012 12:45 PM
Video Banana hobby MIG-29 twin 55mmThrust Vectoring EDF JET Westwood Electric Plane Talk 0 Oct 10, 2011 05:30 PM
New Product New Pro Jet A-10 Twin 70mm EDF RC Jet RaidenTech Electric Ducted Fan Jet Talk 22 Sep 14, 2011 12:28 PM
Mini-Review Delta Twin 456MB from HPI Racing - 2 EDF Jet Foamy! Vicarious Foamy EDFs 37 Mar 28, 2011 06:10 PM
