Old Feb 05, 2012, 08:47 AM
Joined Nov 2005
Originally Posted by jofro View Post
Hi 777, any MG 8-10kg servo will do for this one, I use 5, 50mm pin hinges on each control epoxied into the 6mm balsa insert between depron layers. Horns will be screwed into the ply formers bonded to the foam. Joe,
Great minds
I high hot glue my hinge wood into my A-4 wings, looks like overkill but it will hold the pin hinges well.
What do you think your AUW is going to be?
Your builds make me more confident in building larger scale EDFs with depron and pink foam.
Regards
erh7771 is offline Find More Posts by erh7771
Old Feb 07, 2012, 01:39 AM
Joined Jan 2010
Just about complete with my frame structure so next is building up support for both power units. Base prime colour will follow so all the imperfections and gaps in the depron joints can be filled in. This is when I start enjoying my build after all the hard work is done and the real progress can be seen, Joe.
jofro is offline Find More Posts by jofro
Old Feb 08, 2012, 12:19 AM
Joined Jan 2010
Using the hight strength bond and screws, shroud brackets were fitted to the units and while attached and aligned the whole asembly is well anchored to the air frame using slow cure epoxy, Joe.
Old Feb 09, 2012, 12:01 AM
Joined Jan 2010
First coat of primer applied, next filling up all dints and painting it over to finish off my build, Joe.
Old Feb 10, 2012, 03:29 PM
Joined Jan 2010
Great news, AUW will be well under 7kg, after my first scale check inc. four 4S4500/45C packs. Raining again so back to the build, Joe.
Old Feb 11, 2012, 12:10 AM
Joined Jan 2010
New thrust tubes made up and fitted to the power units so back to painting, Joe.
Old Feb 11, 2012, 05:56 AM
Joined Nov 2005
I'm really starting to consider twin 90s for twin fan scale model setups.
IIRC Knife did 180mph on his Falcon with twin wemotec 90s on 8s.
Old Feb 11, 2012, 05:58 AM
Joined Nov 2005
dupe
Old Feb 11, 2012, 03:50 PM
Joined Jan 2010
I don't expect this model to be faster then 90-100mph, being such a huge air frame, just about perfect speed for enjoyable flying. I love jets but speed is never my priority, Joe.
Old Feb 12, 2012, 12:05 AM
Joined Jan 2010
Finally made up Elevon controls by laminating layers of depron and balsa wood, more work done on Rudd. fins using my logo, Joe.
Old Feb 13, 2012, 01:04 AM
Joined Jan 2010
After few late nights it's finally starting to look like a model aero, it absolutely dwarfs my earlier 64mm twin design foamy that I used to consider one of my larger EDF, Joe.
Old Feb 13, 2012, 11:44 PM
Joined Jan 2010
Elevon controls fully assembled, ready for landing gear after second coat of paint on the belly. J.
Old Feb 15, 2012, 01:28 AM
Joined Jan 2010
I managed to make up and fit the landing gear today with the simple steering nose gear so it's only few things like ESC hook up and soon she'll be in the air, Joe.
Old Feb 15, 2012, 07:50 PM
Joined Jan 2010
Fully loaded up working out position of batteries to sort out my CofG, J.
Old Feb 16, 2012, 12:50 AM
Joined Jan 2010
Installation and hook up of ESCs is fully complete, throttle calibration and some reprograming was performed followed by first run to check that all works well. Impressive sound and thrust on full stick and I can say it's not only the largest but most likely the most powerfull twin EDF foamy built. Next job will be static thrust test using scale just to give me an idea what it pulls, Joe.
Discussion Guanli A10 twin EDF Foamy ESC control mixing with a Futaba 9C tdrnmartin Foamy EDFs 1 Jan 17, 2012 12:45 PM
Video Banana hobby MIG-29 twin 55mmThrust Vectoring EDF JET Westwood Electric Plane Talk 0 Oct 10, 2011 05:30 PM
New Product New Pro Jet A-10 Twin 70mm EDF RC Jet RaidenTech Electric Ducted Fan Jet Talk 22 Sep 14, 2011 12:28 PM
Mini-Review Delta Twin 456MB from HPI Racing - 2 EDF Jet Foamy! Vicarious Foamy EDFs 37 Mar 28, 2011 06:10 PM
