Old Jan 29, 2012, 11:00 PM
jofro is online now
Find More Posts by jofro
Joined Jan 2010
"TWIN WIDOW" largest twin edf foamy jet- latest update
Last couple of years I was hoping someone would come up with large 7th-5th size ARF foamy jet that could sell like a hot cake with all the 90-120+mm power units available nowdays.
Unfortunatelly no such luck so I decided to build my own. Using my favored 6mm sheets of foam I started laying out my new frame, 2.6m long with 1.5m w/span. Twin 90mm, EDF's with 7-9Kwatt output will power the Delta/Elevon controls only model. After my preliminary airframe completion and finding out apx. full flying weight I will decide if I go for 8-10 or 12S power system. Nothing beats the sound of multy power plants, that's one of the reasons I took up this new challenge so back to work, Joe.
jofro is online now Find More Posts by jofro
Old Jan 30, 2012, 12:47 AM
Paul5910 is offline
Find More Posts by Paul5910
Paul5910's Avatar
USA, TX, Houston
Joined Jul 2002
Looking forward to seeing your new creation Joe! What are the details?
Paul
Paul5910 is offline Find More Posts by Paul5910
Old Jan 30, 2012, 01:15 AM
houstonderk is offline
Find More Posts by houstonderk
United States, MD, Clinton
Joined Oct 2010
I had bought the twin 70mm f22 and it fit just right in the back of my bmw wagon, but I was kind of upset when I got the mig version and it would not... :/ Hopefully you either have a big vehicle or make a have a detachable wing...
houstonderk is offline Find More Posts by houstonderk
Old Jan 30, 2012, 03:26 AM
GeorgeStyriaII is online now
Find More Posts by GeorgeStyriaII
Österreich, Stmk., Graz-Umgebung
Joined Sep 2011
Hi Joe,
what´s about the "Tetris" MiG29 ?? 2,1m long, 1,5m w.sp and good for 2x 90mm high power edf or 2x 120mm edf...
http://www.google.com/translate?u=ht...9&langpair.y=7
Regards
George
GeorgeStyriaII is online now Find More Posts by GeorgeStyriaII
Old Jan 30, 2012, 03:35 AM
jofro is online now
Joined Jan 2010
No details yet, only cut out my upper foam lyer today to finalise the air frame shape. It is huge, having only 5mm clearance to fit it in my van w/span wise. To keep it simple it has to be made in one piece which takes little bit of handling for one person. My target is to keep AUW under 7.5kg so I don't need MOP permit.
No pics yet, as my main PC went finito in this wet wheather we are currently experiencing. Will take me while to work out this little laptop with new system, thick as a brick when it comes to PCs but love computer TXs, Joe.
Old Jan 30, 2012, 03:42 AM
jofro is online now
Joined Jan 2010
Originally Posted by GeorgeStyriaII View Post
Hi Joe,
Regards
George
Sorry, not big enough, this thing will be just under 9feet long and while being Delta shape it will have different presents in size, Joe.
Old Jan 30, 2012, 06:49 AM
space 1 is offline
Find More Posts by space 1
USA
Joined Apr 2007
SOUND'S nice can't wait. ps i build 10'ft bird 70mm fan fly's nice
space 1 is offline Find More Posts by space 1
Old Feb 01, 2012, 12:37 AM
rubenhak is offline
Find More Posts by rubenhak
Joined May 2009
Also interested in this project. Thinking about similar twin 90mm edf jet project.
Do you have any ideas around the electronics to be used?
rubenhak is offline Find More Posts by rubenhak
Old Feb 01, 2012, 05:50 PM
jofro is online now
Joined Jan 2010
Slightly behind with my build, waiting for some C/F tubes. Regarding electronics, only two 10kgMG servos to operate ch.2&3 Elevon mix. 0ne 120Amp ESC for each 90mm power unit, still not sure which 'kv' motors I use, I might go up to 12S subj. to weight of my completed air frame, Joe.
Old Feb 02, 2012, 06:31 AM
space 1 is offline
USA
Joined Apr 2007
Looking good jo
Old Feb 04, 2012, 04:30 PM
jofro is online now
Joined Jan 2010
Well on my way with the build, the main frame is fully laminated and bottom half completed so today starting on the top of the fuselage. I can't wait to hear the sound of this twin on full stick, Joe.
Old Feb 05, 2012, 01:32 AM
erh7771 is offline
Find More Posts by erh7771
Joined Nov 2005
What servos do you use?
Also how do you do your hinges and horns for your controls on these?
Thx in advance
erh7771 is offline Find More Posts by erh7771
Old Feb 05, 2012, 02:04 AM
jofro is online now
Joined Jan 2010
Thx in advance
Hi 777, any MG 8-10kg servo will do for this one, I use 5, 50mm pin hinges on each control epoxied into the 6mm balsa insert between depron layers. Horns will be screwed into the ply formers bonded to the foam. Joe,
Old Feb 05, 2012, 02:12 AM
jofro is online now
Joined Jan 2010
Quite a size to compare with twin 90mm FF/Mig but the wing loading will be probably less then half despite projected 7kg AUW, Joe.
Discussion Guanli A10 twin EDF Foamy ESC control mixing with a Futaba 9C tdrnmartin Foamy EDFs 1 Jan 17, 2012 12:45 PM
Video Banana hobby MIG-29 twin 55mmThrust Vectoring EDF JET Westwood Electric Plane Talk 0 Oct 10, 2011 05:30 PM
New Product New Pro Jet A-10 Twin 70mm EDF RC Jet RaidenTech Electric Ducted Fan Jet Talk 22 Sep 14, 2011 12:28 PM
Mini-Review Delta Twin 456MB from HPI Racing - 2 EDF Jet Foamy! Vicarious Foamy EDFs 37 Mar 28, 2011 06:10 PM
