Old Jan 29, 2012, 07:48 PM
JOHN SCALE BOAT is offline
Find More Posts by JOHN SCALE BOAT
JOHN SCALE BOAT's Avatar
United States, PA, Slatington
Joined Feb 2007
Build Log
1/32 Truckable Tug
Decided it was time to build a small pool Truckable Tug. Working off a photo from the Springer Forum. The Tug measuring 9 1/4" x 4 1/8". The entire hull is 0.080" Styrene. The cabin is constructed from 0.040" Styrene I did not a 1 1/8" prop lying around so thought I would give a try of scratch building one. Started with piece of 5/32" tubing and a sheet of 0.020 brass. Lots of hand trimming and filing. Then soldered in place with mechanical solder.
JOHN SCALE BOAT is offline Find More Posts by JOHN SCALE BOAT
Old Jan 29, 2012, 07:58 PM
BOZINATOR is offline
Find More Posts by BOZINATOR
In The Sorrano Triangle
BOZINATOR's Avatar
El Dorado Hills, Calif
Joined Mar 2005
Most excellent job A build with pictures I hope
jim
BOZINATOR is offline Find More Posts by BOZINATOR
Old Jan 29, 2012, 09:28 PM
boater_dave is offline
Find More Posts by boater_dave
Big Boats Rule!
boater_dave's Avatar
Wisconsin
Joined Jun 2007
Nice job. The more I modify plastic kits the more I like working with styrene (sintra, ABS, etc). It is so fast, and in my opinion, represents steel so much better than using wood. What glue did you use? And did you add any internal structure, like ribs or gussets?
Dave
boater_dave is offline Find More Posts by boater_dave
Old Jan 29, 2012, 09:33 PM
6789boat is offline
Find More Posts by 6789boat
Model trains, Rc Boats, Rc air
United States, CA, SF
Joined Mar 2009
Great job
6789boat is offline Find More Posts by 6789boat
Old Jan 29, 2012, 10:08 PM
xx29l9 is offline
Find More Posts by xx29l9
Mopar Musclecar fanatic
xx29l9's Avatar
Oregon
Joined Oct 2008
That is awesome. Nice work!
xx29l9 is offline Find More Posts by xx29l9
Old Jan 30, 2012, 12:14 AM
CaptCB is offline
Find More Posts by CaptCB
CaptCB's Avatar
United States, CA, Orange County
Joined Aug 2011
Nice Job!
Good photo's too, thanks. CB
CaptCB is offline Find More Posts by CaptCB
Old Jan 30, 2012, 08:24 AM
Jerome Morris is offline
Find More Posts by Jerome Morris
Jerome Morris's Avatar
Union, Maine
Joined Jul 2006
Very nice. I too also use a fair amount of plastic and love it.
Jerome Morris is offline Find More Posts by Jerome Morris
Old Jan 30, 2012, 07:44 PM
Joined Feb 2007
Installed a surplus RS385 5pole motor, old Novack ESC cover removed for weight, micro servo, and receiver. The battery is 7.4v Li-ion 2ah should provide 3+ hrs of run time.
Old Jan 30, 2012, 09:01 PM
redlined_b16a is offline
Find More Posts by redlined_b16a
Joined Jun 2008
That prop is pimp
redlined_b16a is offline Find More Posts by redlined_b16a
Old Jan 31, 2012, 06:33 AM
CaptCB is offline
CaptCB's Avatar
Joined Aug 2011
Any interest?
Not trying to hijack his thread, but I have been considering building a similar project for about a year or more. If I had a mold made, to make a similar size hull, is there any interest? Otherwise, I will do a one off. Seeing his boat, makes me want to get it off the IDEA BOARD, and in the water. CB
Old Jan 31, 2012, 12:34 PM
BOZINATOR's Avatar
Joined Mar 2005
How are you going to seal the deck JOHN? Will you be adding lights? I think you will be able to fill the slight gaps with the marine 5200 chalk.
jim
CaptCB,
What I have found in building these little guys is that with a little tweaking of the dimensions it makes for an easier install of the propulsion and electrics. I.E. the length is 8 1/2 - 9 ish while the width is 5 1/2" ...accommodates the 5000 NIMH 4.8v
batts...also the freeboard is taller by 3/8 ". The promaxx 180 geared or 400 geared fit the same foot print and drive a 1" three bladed prop without effort....I have however adjusted the arc and height to accomodate up to a 32mm plastic.
If you build the fiberglass hulls you need to consider not everyone has 40+ years of junk drawers to pool from. So be ready with an off the shelf parts list and their source for the entry level captain.
jim
Old Jan 31, 2012, 02:20 PM
GILL RC is offline
Find More Posts by GILL RC
GILL
GILL RC's Avatar
United States, NJ, Hopatcong
Joined Aug 2005
Very nice job John. At 9 inches you have to at lest add lights.
May be you could make to the WRAM ( Feb 24-26) show in Jersey and we could run together indoors.
I’ll bring my 2 truckables. 25 inch and 4.5 inch.
I think it would be a blast to do a run down the pond in formation.
GILL RC is offline Find More Posts by GILL RC
Old Jan 31, 2012, 02:49 PM
Joined Feb 2007
[QUOTE=BOZINATOR;20595647]How are you going to seal the deck JOHN? Will you be adding lights? I think you will be able to fill the slight gaps with the marine 5200 chalk.
jim
The deck will be seal with removable sealant. There is a lip under the deck that slides into the hull. A thin layer will be applied befor painting. During normal use, charging, and servicing the cabin opening will be used. If the servo or rudder need serviced only then will the deck will be unsealed.
Old Jan 31, 2012, 03:35 PM
CurtisP40 is offline
Find More Posts by CurtisP40
CurtisP40's Avatar
Joined Oct 2011
Neat tug!
CurtisP40 is offline Find More Posts by CurtisP40
Old Jan 31, 2012, 03:49 PM
Prins Willem is offline
Find More Posts by Prins Willem
Old wreck in Milwaukee
Prins Willem's Avatar
United States, WI, West Allis
Joined May 2007
It looks great. You do know what the next step is, right?
One of our club members came to own a truckable built by another member who has passed away. A couple of years ago while driving south on I 94 he stopped at a truck stop on the WI/IL border. He spotted this RC Ford Semi in the store. What's a truckable with out a truck? It came with a van trailer so he had to scratch build the flat bed. IIRC the truck was about $70.
Prins Willem is offline Find More Posts by Prins Willem
Build Log Tug Victory 1/32 scale Tregurtha1013 Scale Boats 108 Jul 15, 2014 07:33 PM
Build Log Buster 2 Truckable Tug JOHN SCALE BOAT Scale Boats 17 Oct 26, 2013 08:59 PM
Gallery 1/48 Fleet Tug in MS 32 camo mariner02 Scale Boats 90 Nov 06, 2009 02:20 PM
Cool Microglass 1:32 scale 45' STL / YTL Tug Aerominded Scale Boats 23 Jan 28, 2009 12:29 AM
Build Log Scratch building the Erreka tug in 1:32 Capt_Christo Scale Boats 73 Jul 15, 2008 10:45 PM
