View Poll Results: Who wants a Darth Smaul Kit?
Gotta have one now, where do I order 10 17.24%
Will buy one in the next several months 16 27.59%
On my long list 14 24.14%
I am not evil enough and therefore not worthy 18 31.03%
Voters: 58. You may not vote on this poll
Old Oct 10, 2003, 08:43 AM
jskrebs is offline
Find More Posts by jskrebs
Evil Plane Doer
jskrebs's Avatar
Westport, Pennsylvania, United States
Joined Dec 2002
Darth Smaul Beta Build Plus Poll
This is the spot where the 5 Darth Smaul Beta Testers will be posting their build comments and pictures.
They are:
Balsa Destroyer
Smash McCrash
4 Throttles
WJ Birmingham
Pork Tornado
Plus my factory build that will be usued for manual pictures and proof of design purposes.
Please weigh in on the Poll.
Littlebirdz is looking to estimate the potential Evil he will sustain from Darth Smaul kit orders. Dave at Littlebirdz has out done himself with the quality of the laser cutting on my Beta kit. Thanks Dave!
jskrebs is offline Find More Posts by jskrebs
Old Oct 11, 2003, 05:21 AM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
Dave has the CF tubes, is cutting them to length and will be sending out the beta kits soon!!
Old Oct 11, 2003, 12:34 PM
WJ Birmingham is offline
Find More Posts by WJ Birmingham
WJ Birmingham's Avatar
St. Louis Metro
Joined Apr 2003
Jeff,
Help us out here... What's the wing span of the craft and rib spacing?
WJ
WJ Birmingham is offline Find More Posts by WJ Birmingham
Old Oct 11, 2003, 02:19 PM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
Would you like a copy of the build manual?
Full rib spacing matches the notches in the training edge 1/2 ribs go in between
Old Oct 11, 2003, 02:31 PM
St. Louis Metro
Joined Apr 2003
Thanks for the manual! That will make things progress MUCH smoother.
Old Oct 11, 2003, 02:32 PM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
http://www.thewestportstore.com/Dart...y%20Manual.doc
Link for manual. It is still a work in progress. Word format.
Old Oct 11, 2003, 02:34 PM
jskrebs is offline
Evil Plane Doer
jskrebs's Avatar
Joined Dec 2002
Beta builders,
Please feel free to E-mail me sugestions for the manual.
I still need to add a section for landing gear and wheel assembly. Should only be a few days.
Old Oct 11, 2003, 06:12 PM
toofastdave is offline
Find More Posts by toofastdave
Littlebirdz
toofastdave's Avatar
Louisiana
Joined Jun 2002
Just a side note,
On some of the 1/4 inch wood, the laser didn't make it completely through. I don't want to turn the heat up any higher because it causes the tips to burn off of the really detailed pieces and increases the kerf that the laser burns away. The pieces can be easily removed with a VERY SHARP, NEW #11 X-Acto blade or similar blade. Do NOT use an old blade or you will crush the wood or break it and the pieces will not fit as they should. Just follow the laser cut on the top and go slow.
Take your time. You can even gently rock the wood back and forth until you get the piece out. Don't force anything or you will break it.
If you get a piece that you can't get out or break something send me an email and I will send out a new piece to you.
Happy building!
Regards,
Dave
toofastdave is offline Find More Posts by toofastdave
Old Oct 11, 2003, 08:15 PM
Jim Poor is offline
Find More Posts by Jim Poor
Closet Extrovert
Jim Poor's Avatar
In transit Los Angeles ->AZ, -> KY
Joined Aug 2003
I'm not on the Beta team, but can you put a few extra "stars" on there somewhere? I broke several of them.
Jim
Jim Poor is offline Find More Posts by Jim Poor
Old Oct 11, 2003, 09:03 PM
Littlebirdz
Louisiana
Joined Jun 2002
Sure thing Jim..
I'm experimenting with several different techniques, but the deal is that the laser's focus is on the surface of the wood, so the thicker the wood, the wider the beam gets at the bottom. That's what contributes to thicker kerfs and larger exit burns on the bottom. I try to keep the heat to a minimum when I burn, to just barely break through to the bottom and on wood that has inconsistent grain, sometimes you get a few spots that don't burn through all the way. I throw the really bad ones away, but at 15+ minutes burn time per 1/ 4 sheet, it gets old.
Like I said, if anyone has any issues with the wood let me know and I will send some new parts out. I'm here to please.
Regards,
Dave
Old Oct 11, 2003, 09:05 PM
Jim Poor is offline
Closet Extrovert
Jim Poor's Avatar
Joined Aug 2003
I didn't mean make any or send any to me. I just glued them back together around the spar after I built the rest of the wing.
Old Oct 11, 2003, 09:07 PM
Littlebirdz
Louisiana
Joined Jun 2002
Understood, you were asking me to put a few "extra" stars on the sheets.
D
Old Oct 11, 2003, 09:11 PM
Jim Poor is offline
Closet Extrovert
Jim Poor's Avatar
Joined Aug 2003
Yup
Old Oct 11, 2003, 09:30 PM
Tres Wright is offline
Find More Posts by Tres Wright
Live to ride... and fly!
Tres Wright's Avatar
Forney, TX
Joined Mar 2002
==but at 15+ minutes burn time per 1/ 4 sheet, it gets old.==
Holy cow!! Does it take that long on all sheets or just the 1/4" stuff? I had no idea it takes that long to cut parts, I figured you slapped it in there and had a cut sheet in about 5 minutes
Tres Wright is offline Find More Posts by Tres Wright
Old Oct 11, 2003, 10:21 PM
Littlebirdz
Louisiana
Joined Jun 2002
Originally posted by Tres Wright
[B
Holy cow!! Does it take that long on all sheets or just the 1/4" stuff? I had no idea it takes that long to cut parts, I figured you slapped it in there and had a cut sheet in about 5 minutes [/B]
Tres, These are cut times to the exact second.
Rib1: 11 min 35 seconds (2 sheets of 1/16 Balsa)
Rib 2: 6 min 19 seconds (2 Sheets, but I cut 6 sets at a time)
Plycut: 28 min 04 seconds (2 sheets)
Webcut: 15 minutes 55 seconds ( 2 sheets 1/4 in)
Equipbal: 12 min 44 sec (4 sets on 2 X 1/8 sheets)
Tailcut: 14 min 20 sec (2 X 3/16 $1.16 wood cost)
One kit takes 39 min 13 seconds to cut. The above figures are for cutting 2 sheets at a time, side by side. The laser cuts one sheet then moves up to the other sheet. They aren't cut at the same time. Then there is packing, hardware kits, carbon rod cutting, shipping, sorting the wood, cutting 48" sheets down to 24", swapping the wood in and out, printing packing slips..... on and on... etc..
There is no glory in being the laser guy... he he I need to expand.. he he I need another machine... Wish I had the work to support the one I have right now!
Dave
Blitz 400 Beta Build with Mega 16/15/4 gobigdale Foamies (Kits) 70 Apr 03, 2009 08:43 PM
Turbo Raven beta build Martin Hunter Parkflyers 131 Jan 06, 2006 04:19 AM
Beta build and fly of Steelheads Blitz 400 Don Sims Foamies (Kits) 97 Sep 14, 2003 10:45 PM
Old School RC Meridian 400 beta build! Martin Hunter Parkflyers 45 Mar 28, 2003 10:39 PM
Beta build- the Wasp Tres Wright Parkflyers 70 Mar 27, 2003 09:38 AM
