Old Jan 29, 2012, 04:49 PM
Cleared2Engage is offline
Find More Posts by Cleared2Engage
Happiness is a belt fed weapon
Cleared2Engage's Avatar
Ventura, CA
Joined Oct 2009
Question
A50 12 L V2 timing
On the manual it says Hacker recommends 20-25 degrees of timing. I'm set for 5 degrees on a Castle ICE 100 (using a 6s 5000mAh and 20x10 prop) and temps are low and everything is good. My ESC will also only go up to 20 degrees for timing. Is this a typo or should I bump up the timing. Of course I'd hook it up to a watt meter and check temps before putting it in the air. Thanks.
Rob
Cleared2Engage is offline Find More Posts by Cleared2Engage
Old Feb 03, 2012, 01:13 PM
FL62 is offline
Find More Posts by FL62
Average Joe 2 Semi-Pro n Back!
FL62's Avatar
United States, AZ, Queen Creek
Joined Feb 2004
Hi Rob,
Acutally, the "Timing" number on a castle ESC is kind of a mis-nomer. It does not reflect actual timing in degrees like ours and other controllers.
The Castle ESC's have a really good "Auto-Timing" algorithim. They detect the motor's inductance when first powered on, and set a "Nominal" timing amount based on that inductance.
The setting you see displayed there is simply a timing "Range" that the ESC can move within from whatever nominal setting it chose.
For example:
Upon powering up, the castle ESC determines that the inductance of the Hacker motor should run at 20 degrees. If you set the Timing to "Low - 0", then the ESC will keep the timing at 20 degrees. However, if you were to set it to "Normal - 5", then the ESC may adjust timing (based on RPM) as low as 17 degrees, or as high as 22 degrees. This MIGHT allow better efficiency depending on how the motor is designed electrically.
With many motors, this is an excellent feature and helps produce more RPM with less input power.
Occasionally, this feature is not compatible with a certain motor, so we simply have it set to "Low - 0" for best results.
In your application, setting it to "Normal - 5" should be fine.
Please feel free to give me a call at the office at (480) 726-7519, or shoot me a PM over the weekend if you need anything!
FL62 is offline Find More Posts by FL62
Old Feb 04, 2012, 12:12 AM
Ventura, CA
Joined Oct 2009
Very good info. Thanks for the reply, Mike
Wanted Hacker A50-16S V2 or 14S V2 bigmark61 Aircraft - Electric - Power Systems (FS/W) 0 Jan 27, 2012 09:34 AM
Sold Hacker A50-16S V2 glegee Aircraft - Electric - Power Systems (FS/W) 4 Nov 19, 2011 04:39 PM
Sold Hacker A50-12L V2 w/X-110 ESC bruff Aircraft - Electric - Power Systems (FS/W) 6 Sep 30, 2011 02:37 PM
Wanted Hacker, A40-14s V2 & A50-14xs vienquach Aircraft - Electric - Power Systems (FS/W) 0 Sep 11, 2011 10:32 AM
Wanted Scorpion 4025-12 or Reaper GR60XL or Hacker A50-12L or A50-16S litespeed Aircraft - Electric - Power Systems (FS/W) 2 Dec 17, 2010 09:59 PM
