Old Jan 28, 2012, 12:54 PM
dodgeboy222 is offline
Find More Posts by dodgeboy222
SLIDELL, LA.
United States, LA, Slidell
Joined Jan 2012
more tail issues.. please help out
ok yesterday i had a slow CW drift. i found my tail housing wasnt perfectly straight. so today i loaded up the soft 3d preset(was beginner) and off to the field to give her a test.
im running a ice lite 50 with the gov. set to 2800 rpms. now the issue im having is while appling pos. collective the tail kicks to the right pretty good. the servo and linkage is at 90 and slider is center. so i adjusted yaw gain to 70 and that helped a ton, but the tail still kicks to the right when applying pos. collective.please tell me there is something in the control unit to adjust to fix this. yesterday it was not doing this while i did a test hover to verify my vibes were gone. the only thing it did yesterday was drift slowly CW.
one more question i have, is the housing supposed to be level with the frame or is the tail blades supposed to be in line with the main shaft ?
dodgeboy222 is offline Find More Posts by dodgeboy222
Old Jan 28, 2012, 01:02 PM
ridge_racer is offline
Find More Posts by ridge_racer
United States, NY, New York
Joined Nov 2010
If you have the USB programmer use the advance setting under tail tuning called collective compensation. It applies some extra tail pitch based on the amount of collective used. Start with 3 or 6 then work your way up. Also make sure the grub screw on the tail hub is snug and not slipping.
ridge_racer is offline Find More Posts by ridge_racer
Old Jan 28, 2012, 01:29 PM
SLIDELL, LA.
Joined Jan 2012
cool. waiting for battery to charge then i'll test and report back
Discussion het f18 build issues please help!!! knightcharger Electric Ducted Fan Jet Talk 2 Dec 03, 2011 06:51 AM
Help! Please help with ESC issues milo12 Power Systems 7 Jun 11, 2011 12:51 AM
Discussion PLEASE HELP! Saito 82 issues buechelr Engines 28 Mar 27, 2011 04:58 PM
Discussion fpv issues help me please hollywoodjoe67 FPV Talk 14 Mar 19, 2011 09:57 AM
Discussion blade cp tail issues! help please GReddy Micro Helis 4 Feb 07, 2007 08:01 PM
