Old Jan 18, 2013, 07:49 AM
DoubleTrouble
Florida
Joined May 2009
+1 they don't take as much time to release nor recharge power.
Double Trouble
DoubleTrouble is offline Find More Posts by DoubleTrouble
Old Jan 19, 2013, 05:18 PM
number6
Alabama / Arab Al
Joined Apr 2009
Is Carl using it for his rec or esc? He only needs one for his rec but esc I'd run more than one or a bank of caps like everyone suggested. I have a feeling its for his esc. If it is try to find a low ESR (equivalent series resistance). Also a cap with a high voltage rating would be perfect to avoid damage when braking. I may have a couple in my box if he wants specific numbers or brands to buy.
6
Number6 is offline Find More Posts by Number6
Old Jan 19, 2013, 08:02 PM
DoubleTrouble
Florida
Joined May 2009
Im not sure I guess he raced in IL this past weekend.
Double Trouble
Old Jan 20, 2013, 12:41 PM
MightyDog
DigDug's Avatar
Southern state of Alabama
Joined Jan 2010
He didn't race due to a electronic problem is what he told us. His table was behind ours. I never found out where he was from. A couple of drivers tried to help him but he pulled out from the race. My bets are on the esc.
DigDug
DigDug is offline Find More Posts by DigDug
Old Jan 22, 2013, 09:21 AM
Me Toby You?
Toby Warren's Avatar
Jacksonville FL
Joined Jan 2011
Most change their esc and rec before the cap goes bad. Caps go week then end up blowing. It's one of those items in racing where people forget to monitor.
Toby
Toby Warren is offline Find More Posts by Toby Warren
Old Jan 24, 2013, 11:27 AM
DoubleTrouble
Florida
Joined May 2009
I use a bank that I bought off Emay.
Double Trouble
Old Jan 26, 2013, 03:47 PM
Elfie
Joined Feb 2012
What type of bank? I have one cap and thats all I see.
Elfie is offline Find More Posts by Elfie
Old Jan 28, 2013, 07:49 PM
number6
Alabama / Arab Al
Joined Apr 2009
Has anyone tried out that Tacon?
6
Old Jan 29, 2013, 09:48 AM
Joined Aug 2009
Most add capacitor banks to the ESC or reciever to help smooth the voltage sag that circuits see when under a heavy amp draw. The capacitor acts as a reservior to store current under lighter loads and then release current under heavier loads to even out voltage sag. Brownouts from sudden acceleration can actually cause some recievers to reset. This can cause a blackout in reception and a loss of control. Capacitor banks can fix this problem. Didn't your esc come with a cap or bank?
Cart Miester
Cart Miester is offline Find More Posts by Cart Miester
Old Jan 31, 2013, 07:32 PM
djskiptonic's Avatar
Out side of Destin FL.
Joined Sep 2009
Banks with three or more will work best.
JB
djskiptonic is offline Find More Posts by djskiptonic
Old Feb 03, 2013, 03:10 PM
Hairless Monkey
HairlessMonkey's Avatar
GA
Joined Apr 2010
6 what are you trying to compare it to? The standard modified motor?
Hairless Monkey
HairlessMonkey is offline Find More Posts by HairlessMonkey
Old Feb 05, 2013, 01:42 PM
number6
Alabama / Arab Al
Joined Apr 2009
To use in modified HM what else?
6
Old Feb 06, 2013, 03:57 PM
Team Edge
Team Edge RC's Avatar
Joined Oct 2011
We never tested them because they weren't out when we started modified brushless class. I can see if we can pull specs up online or if someone wants to post it. They do make a 5200 which make them legal.
Robert
Team Edge RC is offline Find More Posts by Team Edge RC
Old Feb 06, 2013, 05:11 PM
Always were your sun glasses!
Leadhauler's Avatar
Joined Oct 2010
Here you go my friends
5200KKv
Net Weight (g)50
Watts130
Outer Diameter?mm)20
Length (mm)30
Stator15MM
No of cells (lipo)2
max efficiency (%)85%-89%
max efficiency current 12
no load current (A)/7.4V1.2
Internal Resistance (mohm)0.0733
Shaft Diameter (mm)2.00
Shaft Length (mm)10
KV (RPM/VOLT)5200
Turns (for cars)Poles18T/2POLES
Max Voltage8.4
Wire Size0.28
Bullet ConnectorsYES
Bullet Connector Size3.5MM
Leadhauler is offline Find More Posts by Leadhauler
Old Feb 07, 2013, 07:03 PM
number6
Alabama / Arab Al
Joined Apr 2009
Whatcha think Lead thats it.
6
Yippee! Team Edge RC Kart racing hitting Nashville Tennessee. Team Edge RC Large Scale Cars 697 Apr 08, 2013 06:45 AM
Question Team Edge RC indoor Kart racing? Team Edge RC Large Scale Cars 244 Mar 27, 2013 08:42 PM
Question Team Edge RC Karts in Dothan. Possible race in Spring? P.ODell Large Scale Cars 153 Feb 17, 2013 11:42 AM
Discussion Team Edge RC member only tech chat tonight! From 830 to ? Team Edge RC Large Scale Cars 22 Dec 28, 2011 09:42 AM
