Espritmodel.com Heli Air
Old Jan 28, 2012, 11:20 AM
Wonderfully Wicked
The Don's Avatar
Willoughby, Ohio
Joined Jan 2002
Mounting the Wicked EDF motor into the HET 6404 64mm EDF Fan unit
Here is my quick "how to" on how to mount the Wicked 4000 Plus EDF motor into the HET 6404 64mm fan unit.
Here is the test data I got:
Wicked 4000 Plus Motor: 4S 2200mah 40C Skylipo: 830 watts, 60.9 amps, 13.63 volts
Note: These rotors are dynamically balanced by HET. The one I assembled for this photo sequence was vibrating a little at lower throttle (but smooth at higher throttle) so I loosened the rotor screw and rotated the rotor a 1/8 turn or so and tried again. After a few tries I found a spot where it ran smooth at low rpm as well as high rpm.
The Don is offline Find More Posts by The Don
Cool HET 64mm fan 6404 SteveC68 Foamy EDFs 8 Apr 06, 2012 05:35 AM
Sold Cyclone 64mm EDF fan unit and Chagesun 70mm EDF fan unit The Don Aircraft - Electric - Jets (FS/W) 2 Jan 25, 2012 04:14 PM
Found WTB: Wicked Plus EDF Motor 4000kV and/or 64mm Fan cutty01 Aircraft - Electric - Jets (FS/W) 7 Sep 26, 2011 01:25 PM
Mini-HowTo Mounting a Wicked EDF motor into the EDO 64mm fan units The Don Don's RC 0 Jun 19, 2010 09:14 AM
Mini-HowTo Installing the Wicked EDF motor into the Wicked EDF fan unit The Don Don's RC 3 Jun 30, 2009 08:09 PM
