Old Jan 28, 2012, 11:16 AM
ausf is online now
Find More Posts by ausf
ausf's Avatar
United States, NY, CENTRAL VLY
Joined May 2011
Peck Polymers P-nut P-51
Here's my first Free Flight attempt.
As is, it weighs in at 3.7 grams. I plan on leaving the gear off, I don't think it would survive, at least until I get my head wrapped around the whole process. I built the horizontal stab so I can trim it about 3/32 of a inch either way. I'm happy about the squareness, although it took some fine tuning with a sanding block.
The last two photos show the left wing wash-in, right wing wash-out recommended on the plans (1/16). That really freaked me out at first when checking for square, since at first glance they look uneven. I'm a bit concerned about tip stall, but I'll give it a go as is, again, to figure out this hands off flying stuff.
I'm covering with kit tissue using glue stick. I tested out the tissue on a few square frames I made and a mist of 70% iso alcohol to shrink and a sealing coat of Tamiya Clear (ether based) thinned 50% with iso worked best.
It'll be interesting to see if I can keep warps out.
If you see anything or have any suggestions, I'd love to hear them.
ausf is online now Find More Posts by ausf
Old Jan 29, 2012, 04:46 AM
Yak 52 is offline
Find More Posts by Yak 52
Yak 52's Avatar
UK
Joined Jan 2009
Looks good ausf.
I find the finished model comes out at roughly double the weight of the bones stage - so your on track for a good flier!
Jon
Yak 52 is offline Find More Posts by Yak 52
Old Jan 29, 2012, 09:29 AM
ausf is online now
ausf's Avatar
Joined May 2011
Thanks Jon,
I'll be carefully weighing it every step to get an idea of how things add on..covering, sealer, decals, etc.
Old Jan 30, 2012, 03:54 PM
ausf is online now
ausf's Avatar
Joined May 2011
Got it covered, kit supplied tissue and Ehlmer's gluestick. Weighs in at 6.6 grams. 9.2 with the nose.
I had this brilliant idea of using the airbrush to shrink. I sprayed the iso, then blew it with straight air to dry, only to get even more brilliant and turn the PSI to 20 from the 8 or so I was using. Wet tissue and 20 PsI of air through a detail airbrush makes nice holes.
So I learned a bit about patching too.
Old Feb 01, 2012, 07:58 PM
aeronca52 is offline
Find More Posts by aeronca52
Culper Junior
eastern pa
Joined Feb 2007
ausf,
Nice looking P-51.
Is the framework in the front of the canopy painted on or is it tissue strips?
aeronca52 is offline Find More Posts by aeronca52
Old Feb 01, 2012, 09:56 PM
ausf is online now
ausf's Avatar
Joined May 2011
Originally Posted by aeronca52 View Post
ausf,
Nice looking P-51.
Thanks.
It's tissue. Since this was kind of a test, I wasn't sure of what I would do in terms of paint, etc. as well as not knowing how I was going to even attach the canopy.
I tried the gluestick bond, tissue to canopy and canopy to wood and it was solid, so that's how I attached it, I figured frame it too.
Old Feb 02, 2012, 12:08 PM
Work in Progress is offline
Find More Posts by Work in Progress
Light and floaty does it
Work in Progress's Avatar
Cambridge, Great Britain (UK)
Joined Sep 2004
That looks very good indeed - both the design, which is surprisingly Mustang-like considering the small amount of wood in it - and your building of it.
Work in Progress is offline Find More Posts by Work in Progress
Old Feb 02, 2012, 02:34 PM
ausf is online now
ausf's Avatar
Joined May 2011
I completely agree. This was my first kit of this type and I'm amazed that it not only is pretty sturdy with such little structure, it really does get the basics of the P-51 in order.
The leading edge is 1/20" square stock that I sanded to shape afterwards. I didn't expect it to survive my clumsy covering technique, but not only did it make it through all of that, it holds it's shape beautifully.
Thanks for your kind words.
Old Feb 04, 2012, 12:14 AM
SRWitt is offline
Find More Posts by SRWitt
Joined Jan 2011
Wow the Peck Peanut p51 was the first free flight plane I ever built, way back in 96/97. Built it as a project for an aviation class in Jr. High. It got an A, it was the only project that was an actual plane, that flew. Everybody else stuck to boring reports on the physics of flight, I actually demonstrated.
Nice job on the plane. The way I covered mine, I used elmers white glue thinned with water, and a glue stick. I stuck the tissue to the frame with the stick, shrunk with water, then sprayed the water/elmers mix over the tissue as a "dope" to make the tissue firm.
SRWitt is offline Find More Posts by SRWitt
Discussion Peck Polymers J-3 Cub Question 356Jim Scratchbuilt Indoor and Micro Models 5 Jul 05, 2011 12:36 PM
Peck-Polymers Genesis Flying Wing DaleM Electric Sailplanes 5 Feb 19, 2007 04:06 PM
Peck-Polymers Genesis Flying Wing Up&Away Electric Sailplanes 3 Feb 12, 2003 10:36 AM
Peck Polymers "Mini Bell" conversion? CharleyRexom Electric Plane Talk 5 Dec 28, 2001 10:17 AM
