Jan 28, 2012, 01:09 AM
United States, VT, Underhill
Joined Dec 2011
Eagletree "OSD not connected" error
hi bill,
it appears that i have a problem very similar to several others i've seen here recently.
have an osdpro, v4 datalogger, gps, and guardian, V10.04 Recorder Application, downloaded and installed tonight, on a win 7 x64 system.
all parts were purchased from Tower Hobbies and delivered on 12-28-11.
using 3s LiPo batteries at about 12V, fully charged. elogger V4 get slightly warm during testing.
1.280 Ghz video system arrived today and was first confirmed fully functional without any ET parts at all.
next, ET parts were added, and confirmed that ET splash screen is added to Vtx signal - at the top of the splash screen, message "menu input (s) not detected" appears.
elogger V4 when plugged into USB flashes 3x, and repeats. elogger V4 firmware updated properly to V1.15.
with elogger software, under hardware/firmware control/, only elogger V4 shows up as available for firmware update.
changed wiring configuration with Guardian connected directly to elogger V4 and osdpro disconnected per advice in similar thread here, but still only shows elogger V4 recognized in Firmware Control screen. guardian yellow LED shows rapid pulse when plugged into bus in elogger v4 directly or into osdpro, or between osdpro and elogger V4.
again under hardware/firmware control/"choose parameters to display on video osd" tries to initialize OSD board and finally fails with message "OSD board is not connected..."
all connectors were mated very carefully, noting polarity. no connections were made or broken with batteries connected.
all ET parts were left bagged until tonight, when video parts arrived. again, once video parts were confirmed functional, ET parts were added and powered, up to seeing splash screen and flashing elogger V4 firmware.
all procedures were followed from current manuals, and expected communication for video osd configuration, using current software and firmware, with other peripherals including osdpro and guardian was not accomplished.
what am i missing? please advise on proper course of action.
thanks,
bryan
