Old Jan 27, 2012, 12:31 AM
marksextra is offline
Find More Posts by marksextra
Once u go yak u never go back
marksextra's Avatar
Erie, PA
Joined Mar 2005
Deep Cycle batteries for charging
I need some help picking the best deep cycle batteries for charging. I currently own 2 306b chargers and plan to charge a lot of 6S5000 lipos at the field.
I found a ton of info here
http://www.windsun.com/Batteries/Battery_FAQ.htm
Opinions?
marksextra is offline Find More Posts by marksextra
Old Jan 27, 2012, 12:51 AM
typeRA is offline
Find More Posts by typeRA
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
You can also use LiFePO4 cells.
Four cells for approximately 12V, eight cells for approximately 24V.
They are a lot lighter and are supposedly good for more cycles.
typeRA is offline Find More Posts by typeRA
Old Jan 27, 2012, 12:53 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
more info that other people have said....
"make sure that they are Deep Cycle batteries, not Starting Batteries. DCs are rated in amp/hrs and SBs are rated in CCA (cold cranking amps). Walmart marine Maxx 125ah"
"I would recommend minimum 125Ah, group 29 or larger. While more expensive, I would recommend a true deep cycle over a marine starter or dual purpose battery as they will last a LOT longer. True deep cycles are available at most boating or RV supply stores"
"Starting batteries should not be discharged below 80 percent of full charge.
Deep cycle batteries should not be discharged below 50 percent of full charge.
After a battery is discharged it should be FULLY Recharged ASAP, the longer it is left discharged the more damage is done."
"Fully charge with a good Automatic or Smart charger. Every onboard charger I have seen is a good smart charger. Do not charge with a trickle charger unless your have the tool and the attention to shut it off at the proper time."
"I also suggest a Smart charger of at least 10 amps to help the battery recover quickly. If your charging 2 batteries then 10 amps per battery.
Many will say use a low amp charger as high amps will damage the deep cycle. I say just the oppsite as long as the charger is a smart charger the more amps the better. Charger will taper down and not over charge the battery."
Old Jan 27, 2012, 12:56 AM
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
I think you have it backwards.
--edit--
...unless you are talking about 20% DOD and 50% DOD.
Old Jan 27, 2012, 12:57 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
Walmat Everstart Maxx 29 has both good and not so good reviews for a cheap alternative.
Old Jan 27, 2012, 12:59 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
It wasn't me. It was just what someone else said. I don't know much about these....yet. But it depends on how you look at it. As you said. Deep cycle batteries are for their ability to be discharged more deeply and recharged more than starting batteries where their strong ability is just for the short duration of starting. I am wrong?
everydayflyer? mrforsyth?
Old Jan 27, 2012, 01:04 AM
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Discharging of batteries should be referenced by stating the DOD, or Depth Of Discharge, as a percentage of the battery's total capacity discharged.
I think what you said may have meant 80% remaining (20% DOD), and 50% remaining (50% DOD).
Old Jan 27, 2012, 01:05 AM
mrforsyth is online now
Find More Posts by mrforsyth
So. Cal.
I believe that may be Charles quote and it's correct.
For longest life, starting batteries should not be discharged below 80% of available capacity (20% DOD). For deep cycles, 50% is the recommended stopping point for maximum longevity.
Mark
mrforsyth is online now Find More Posts by mrforsyth
Old Jan 27, 2012, 01:15 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
Thanks for posting. That was fast!
much better looking battery...but hey. I don't know anything about this stuff.
http://www.theenergyconscious.com/sol3002.html
I'm getting the feeling that it going to cost me about $100 per 100ah of battery and doesn't matter where I buy it.
Old Jan 27, 2012, 01:17 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
Anyone care to recommend a good smart charger?
I think someone mentioned this one.
http://www.amazon.com/Schumacher-SEM.../dp/B0009IBJAS
BUT....it's 1.5amps. The poster above said to get a 10amp one.
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
115 lbs?
Old Jan 27, 2012, 01:24 AM
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
Are you just copying stuff from all over the internet and posting it here without any references of such activity?
Old Jan 27, 2012, 01:25 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
I"m young and strong? Oh wait.....no I"m not.
I do have an enclosed airplane trailer that I haul my stuff around in though. Weight shouldn't be an issue. Of course I say that now. Wait till I'm swearing up a storm because I have to clear out the trailer to haul something else.
Old Jan 27, 2012, 01:26 AM
marksextra's Avatar
Erie, PA
Joined Mar 2005
Ummm... I think so. I'm copying what others have said regarding deep cycles. There I just referenced my activity. Is that better?
Are you talking about copyright? or batteries?
Old Jan 27, 2012, 01:35 AM
typeRA is offline
Zero Expo
typeRA's Avatar
San Diego, CA
Joined Mar 2009
It's confusing and difficult to keep track of information. It would be a lot nicer if you posted quotes inside quote tags and posted a link to where you found the quoted material.
Here is an example:
Clean, durable and long-lasting, renewable energy users all over the globe know Trojan Deep Cycle batteries are the perfect addition to any solar/photovoltaic, small wind, and micro-hydro application, even in the harshest of environments. Trojan Battery - Dependable, Uninterrupted Power.
Discussion Deep Cycle Marine Battery for Field Charging turnerm Batteries and Chargers 12 Sep 22, 2011 11:27 AM
Help! Deep cycle batteries FLYING-HIGH Batteries and Chargers 6 May 24, 2011 09:35 PM
Discussion Deep Cycle Batteries keithy4129 Batteries and Chargers 12 Apr 27, 2011 10:08 AM
Discussion Deep cycle battery for charging Melnic Batteries and Chargers 13 Dec 21, 2010 07:25 PM
Discussion Charging 2 deep cycle batteries with triton? wolfcopter Batteries and Chargers 6 Jul 16, 2007 03:55 AM
