Old Jan 26, 2012, 10:52 PM
Bob. is offline
Find More Posts by Bob.
Bob.'s Avatar
Australia, WA, Australind
Joined Aug 2011
Question
Nova OSD RTH with AAT My Fly Dream antenna tracker
I was after some help with the wiring on my AAT MFD tracker module (on board) and the Nova cyclops RTH, I'm having trouble with the GPS wiring into the GPS module, I need to connect a wire into the MFD tracking board from the GPS wiring harness. I have 1 red wire and 4 black wires on the GPS harness, thinking the red is volts and other blacks are signals in and out as well as ground, the question is, which black wire do I use to give the module of the MFD to track the plane
Bob. is offline Find More Posts by Bob.
Old Apr 07, 2012, 09:36 AM
aspranger is offline
Find More Posts by aspranger
Joined Mar 2012
Hi buddy, try this link. It has the pin layout...
http://www.rcgroups.com/forums/showt...sd+gps&page=91
Would be great, if someone could create a patch or upgrade, that would make the aat compatible to nova osd. I guess then sales would go through the roof
The aat rocks. Using 2 bords is troublesome though... And since there is no rth and mah expansion board available yet, I guess many people go with the cyclops aat combo.
Cheers
Andreas
aspranger is offline Find More Posts by aspranger
Discussion nova osd with rth mark the shark FPV Equipment 2241 Nov 07, 2015 09:57 AM
Discussion Range VIdeo OSD Gen.5 and Antenna Tracker IMEIV FPV Talk 25 Feb 24, 2012 11:01 AM
Discussion 3 steps to make Skylark Auto Antenna Tracker work with other OSD? skylarkfpv FPV Talk 0 Oct 31, 2011 09:41 PM
For Sale My entire FPV rig must go - Dragon link, fatshark, OSD, antenna tracker, etc billdsb FPV Equipment (FS/W) 12 Sep 10, 2011 05:09 PM
Discussion Pan/Tilt Antenna Tracker with OSD & Google Earth tracking IanJ FPV Talk 20 Dec 29, 2009 11:01 AM
