Old Jan 26, 2012, 08:04 PM
electricrc68 is offline
Find More Posts by electricrc68
The Sweet Aroma of Fuel
electricrc68's Avatar
United States, PA, Downingtown
Joined May 2011
how do you tell when your battery is fully charged?
hey guys. in the manual for my planes, it says that with the stock parkzone chargers you need to wait until the LED blinks every 20 seconds and then you know that it is fully charged. is this correct? i have heard others say 10 seconds, 5 seconds, 3 seconds, and so on.
electricrc68 is offline Find More Posts by electricrc68
Old Jan 26, 2012, 08:29 PM
Champflyr is offline
Find More Posts by Champflyr
My Champ makes birds mad.
Champflyr's Avatar
Joined Nov 2011
From what I have heard, leave it in until it blinks no more.
Champflyr is offline Find More Posts by Champflyr
Old Jan 26, 2012, 08:37 PM
WheelzzzUp is offline
Find More Posts by WheelzzzUp
USA, North Alabama
Joined May 2007
Follow what the manual says. You'll be near or at full charge
WheelzzzUp is offline Find More Posts by WheelzzzUp
Old Jan 26, 2012, 09:30 PM
Joined May 2011
Okay thanks guys.
Old Jan 27, 2012, 07:22 AM
gulio is online now
Find More Posts by gulio
That's a funny word
NE Ohio
Joined Apr 2003
Ultimately the resting voltage is the tell-tale. Mostly we use 4.2 volts (resting) to describe a full cell.
It might be pretty cool to do a volt check at the 3 ,5 10 , and 20 second mark to see just how full the battery is at those various markers.
gulio is online now Find More Posts by gulio
Old Jan 27, 2012, 02:07 PM
Joined May 2011
yeah maybe i should do a voltage check. hard part is that i don't know how to check the voltage on such a small battery without shorting it out.
Old Jan 27, 2012, 04:27 PM
gulio is online now
That's a funny word
NE Ohio
Joined Apr 2003
You've hear of "walking on pins and needles"?
I usually use pins or needles. It's easy to short them out until you get the right adapter or connector. Now I can just plug it into the dvm.
Old Jan 27, 2012, 04:46 PM
Joined May 2011
okay thanks.
Old Jan 27, 2012, 05:57 PM
everydayflyer is offline
Southern Pride
everydayflyer's Avatar
Haralson County GA. USA
The charger that came with my Stryker 180 charges the E flite 200 mAh to 4.195 per cell.
Charles
Old Jan 27, 2012, 07:14 PM
Joined May 2011
okay cool thanks. but does it use the same concept as the one cell chargers?
Old Jan 27, 2012, 07:51 PM
Southern Pride
The 4 at a time one that came with my Blade m S/R charged the 1S 120 LiPolys to 4.18 to 4.20.
To many get hung up to much on wanting their LiPolys fully charged. 4.1.85 to 4.20 is fine and charging them to only around 4.15 would be better for them..
Charles
Old Jan 27, 2012, 08:09 PM
Joined May 2011
Charles
okay cool thanks.
Old Jan 28, 2012, 11:51 PM
RCITGuy is offline
Find More Posts by RCITGuy
RCITGuy's Avatar
United Kingdom, Croydon
Joined Feb 2010
Out of curiosity, have you tried following the manual, and did everything work out ok?
RCITGuy is offline Find More Posts by RCITGuy
Old Jan 29, 2012, 01:02 AM
Joined May 2011
Yep that's what I have been doing. Seems to work fine.
Old Jan 29, 2012, 02:07 PM
pugsam is offline
Find More Posts by pugsam
LiPo-Sucker & Airframe EMT
pugsam's Avatar
Charlottesville, Virginia, USA
Joined Aug 2010
Originally Posted by gulio View Post
.....It's easy to short them out until you get the right adapter or connector. Now I can just plug it into the dvm.
What kind of meter is good to use with 1S and 2S batteries?
Dave
pugsam is offline Find More Posts by pugsam
Discussion How can you tell when your car battery is worn out? Eddy Batteries and Chargers 39 Sep 12, 2011 11:58 PM
Question How do you tell when older glow fuel is no longer any good ??? shooboy Fuel Plane Talk 15 Aug 27, 2011 07:27 AM
Discussion How do you know when the battery is fully charged? chapped Batteries and Chargers 4 Jan 21, 2010 01:38 PM
Discussion How do you store your lipos once fully charged??? mtdoramike Batteries and Chargers 27 Apr 28, 2009 05:56 PM
Question How do you know when a battery is fully charged? Composer Dan Batteries and Chargers 6 Apr 11, 2004 01:54 PM
