Old Feb 17, 2012, 06:06 PM
R Hudson is offline
Find More Posts by R Hudson
R Hudson's Avatar
United States, CO, Denver
Joined Dec 2002
I guess I misunderstood. I didn't know that you had lifted the D200 already. If your question is about the DJI frame itself, I have no doubt that the frame will handle the weight. It is very rigid.
R Hudson is offline Find More Posts by R Hudson
Old Feb 17, 2012, 06:12 PM
liteglow is offline
Find More Posts by liteglow
Joined May 2005
That`s okay
I have taken many photos with the D200 in the air.
But you are totally correct that is to heavy, so when I manage to find a solution for the NEX5 i will use that for photo also.
But the main question was if the DJI frame can lift 3-4kg if needed (worst case) .
My usually lift weight will be around 2-3kg included the nex5n.
But I guess I will find out.
Today I did order the 550 frame :-)
liteglow is offline Find More Posts by liteglow
Old Feb 20, 2012, 10:45 AM
Steph280 is offline
Find More Posts by Steph280
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Originally Posted by liteglow View Post
Motors I did use was RC-timers, but to much vibration so I have replaced them with iPower motors.
I am running their newer version of motor that does not have protruding motor shafts. It comes with the bolt on prop mount base. Much smoother. I'd suspect on the motor most vibration are coming from both the long shaft and the crappy prop collets.
Steph280 is offline Find More Posts by Steph280
Old Feb 20, 2012, 12:14 PM
Laddy McMurry is online now
Find More Posts by Laddy McMurry
Laddy McMurry's Avatar
United States, TX, Midland
Joined Apr 2003
Steph280 wonder when Align will start making these multi-rotors?
Laddy McMurry is online now Find More Posts by Laddy McMurry
Old Feb 20, 2012, 08:39 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
I certainly hope they will. They have the capabilities so it certainly makes sense.
Old Feb 20, 2012, 08:46 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
align really does not do electronics or firmware. they are great at injection molding and manufacturing though. If Align does jump into this market, I would guess that they will use existing controller via OEM. would be interesting.
askman is offline Find More Posts by askman
Old Feb 20, 2012, 10:22 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
They have a team dedicated to flight stabilization system R&D. They demoed their heli GPS stabilization system during last year's fun fly. It actually has functional position hold and come home feature. It shouldn't be difficult to implement a multicopter version. But I think their emphasis is still competition helicopters.
Askman how are the gimbals coming along? Got those servos yet?
Old Feb 20, 2012, 10:45 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I did not realize align already had Heli GPS. Then they are probably waiting for the market to develop a bit and become mainstream.
Gary has the gimbals and he is waiting for the servos before releasing them. he is also doing some final tuning and packaging. as well as instruction. I am taking feedbacks from testers on improvement that could be made. most of the suggestion has been regarding aesthetics like using button head screws. we will take all suggestions from buyers as well. I've also started building second lot of gimbals. I am sure initial lot will go fairly quick once gary and robert put them up. biggest bottleneck is going to be availability of certain parts initially until I can gauge and keep adequate supplies on hand.
Old Feb 21, 2012, 05:51 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
well, this is proto of bolt on pan unit. I did not have correct length shoulder bolt for main shaft, so I have to order them. otherwise, it is almost ready to mount. It will add 1.5" to the height. otherwise, it is pretty simple and very smooth. multiple bearing makes for slop free pan. when I get the new shaft, I will send them out for testing.
I am also doing a polecam adapter for these gimbals as well.
Old Feb 21, 2012, 05:54 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Everytime I talk myself into waiting on the gimbal, someone posts in this thread and I turn into a 12 year old girl at a Justin Beiber concert...
MCrites is offline Find More Posts by MCrites
Old Feb 21, 2012, 08:11 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Askman, I haven't seen one of Gary's in person yet so I am not familiar with how it attaches to the DJI copters. Any issue to mount these under the Mikrokopter battery mounting cage? There are 9 bolts which can be used to mount.
http://www.mikrokopter.de/ucwiki/en/LiPo-Holder
Old Feb 21, 2012, 08:29 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
if I can get a dimension of the mounting holes. it would be easy to make a adapter plate for MK
basically, it will attach to the DJI frame using spacer in existing slot. both pan and none pan shares same dimension. (about 2.4x3.8" dimension I believe) it is very easily adaptable though. I am really taking advantage of the modular concept. I really like this sized multi, and as technology improves, it will become even more capable.
Even the gimbal while designed for nex5 series, gh2 will fit just as well. I left lot of meat on the back of the tilt plate where you can drill mounting holes to fit most camera with stock lens and have it balance. Still, most of our optimization has been done with pancake lens, so you may need to do some tuning with other lens for max performance. In the future, I may even have some alternate pulley combo available for further tuning.
lot of ideas.
Old Feb 21, 2012, 09:38 PM
Steph280 is offline
1.21 Gigawatts!
Steph280's Avatar
Irvine, CA, USA
Joined Oct 2000
Here are the dimensions in case you are considering making them compatible with Mikrokopter. I'd definitely buy one!
Thanks!
Last edited by Steph280; Feb 21, 2012 at 11:13 PM. Reason: Added a couple example photos or MK's mount
Old Feb 21, 2012, 11:21 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
thanks. that should give me enough information to make a new plate. should be easy to make. I am assuming the holes are 3mm as is the standoff thread . have to figure out best way to do this that will be the lightest..
Old Feb 22, 2012, 12:46 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Yes, this should be fairly easy. I'll let you know when Andrey sends me the adapter, and we can meet up. I have a setup set aside for you now.
We are also looking to do adapters for CineStar and DroidWorx platforms, for the new full-sized DSLR gimbal that is on the "to-do" list. There will be 2-axis and 3-axis versions, the latter using the new setup shown above.
I should have servos tomorrow, or Friday, so the plan is to be able to start shipping then. For the NEX/GH2 gimbals, we are making a last minute change to the plate on the camera tray, to make it wider. This will allow better support for using the standard 18-55 kit lens with the NEX-5N/7, in addition to the shorter "pancake" lens. It allows the camera body to sit farther back in the yoke, so that everything balances. Originally the plan was to only allow use with the pancake lens, mainly because we were concerned about weight. This was because we were using the DH16 "mini"-size servo. After initial testing, we decided to go to the full size DH20x-GCD for both tilt and roll, so the extra weight/mass of the 18-55 kit lens is no longer an issue.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
