Old May 03, 2012, 11:21 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
yes, add it on send an invoice. no rush here. I'm still waiting on my WKM and other electronics. hex not built yet.
How should I position the bottom board for mounting on the f550 or does it not matter. the f450 has those two lengthier sides do wondering if f550 had specific holes or areas
Wingbreaker is offline Find More Posts by Wingbreaker
Old May 03, 2012, 11:55 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Sorry, I forgot to post a link to the instructions for the landing gear. I've attached a copy, plus the ones for the AG450-GP-IS F450 isolation mount and the leg extensions.
Anyway, there are two mounting tabs on the top of the LG's center section. These line up with the outer set of circular slots on the F550's lower plate. You use four rubber grommets that slide into the slots, and then four bolts holds everything together.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old May 03, 2012, 11:58 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
i like the names..... now I can actually call it something other than "askman's new gimbal, you know the guy who made heli gimbals a while ago..... well he is bacK"
Adidas4275 is offline Find More Posts by Adidas4275
Old May 03, 2012, 10:03 PM
Video Juggernaut
Joined Nov 2003
"Install the four M3x16 screws through the grommets, using the provided extra wide washers on each side of the rubber grommet."
Looks like you don't have washers there or are they small?.
Old May 03, 2012, 10:11 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I do it slightly differently. I bolt the screw onto the adapter plate on the LG from the bottom and tigten in down with a nut so bolt is standing up. place washer. put it though the grommet, another washer and second nut. that works for me as well . in his case, he is using the plastic spacer as washer.
askman is offline Find More Posts by askman
Old May 03, 2012, 10:24 PM
Video Juggernaut
Joined Nov 2003
so looking at his photos, it seems it doesn't matter how I put the bottom Flame wheel board. right? the f450 matters because you have the two extensions on the bottom.
Old May 03, 2012, 11:14 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
technically, you want it so that the slots are symmetrical left/right. this is true for both top and bottom. otherwise, you may have issue lining up the LG mounting.
Old May 04, 2012, 10:45 AM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Yesterday, during a break in the weather, I did another test fight with the F550 and the PJ710V. There were stronger wind gusts from what they were in the first test flight the other day, especially up high. Because of these, I noticed that the roll gains are slightly off, so you can see a very slight movement in the roll axis. I will try adjusting this out today. The movements are very slight, and not really noticeable unless you are looking for them. Nonetheless, what it more or less confirms is that the camera's BOSS function doesn't do anything for roll movements, so we will need to keep our current setup with the BLS950 and the 2.5:1 belt drive reduction.
AG550 PJ 2 Axis PJ710V Gimbal Test 02 (3 min 29 sec)
This was to be a "baseline" flight, before I start changing things in the tilt axis, but I will probably do one more this morning, after I get the roll gains tweaked a little closer. Right now, the tilt axis still has the 950 servo and it has a 2:1 reduction. I want to try different servos first, and then start playing with the ratio.
On the Naze32 front, I've tested the latest fix that was offered, and it was a lot better, but the twitches did not completely go away. We now feel the only true answer is to implement a Kalman filter for the accelerometer data, in floating point, and get away from the MultiWii-based code. People are working on this now, but it might take a week, or so, until I get something to test.
"Crabby" is coming together nicely. I'll post some more pics later today.I realized that I only had two spare Maytech 30A ESCs (the other four are on my F450...), so yesterday I order four DYS 30A ones from Ken, @QuadroUFO.com. Ken was able to re-flash all four with SimonK's firmware, and still get them shipped out yesterday. Great service. Since they are based somewhere in the LA area, I should get them today.
More later...
Old May 04, 2012, 10:48 AM
Adidas4275's Avatar
Joined Mar 2011
i find roll to be the most important axis to be stabilized... but i am sure they built the camera to be on a trip and they are just trying to smooth out tilt and pan
Old May 04, 2012, 11:10 AM
milo12 is offline
Find More Posts by milo12
Joined Feb 2011
Crazy idea coming...
Put one of these on the lens and mount the camera pointing straight up. Now you have tilt and roll stabilization but no yaw stabilization.
http://www.amazon.com/Opteka-Panason.../dp/B003WZ2T04
or http://www.edmundoptics.com/imaging/...ng-lenses/3211
This one fits the cameras 52mm thread. http://www.buy.com/pr/product.aspx?s...lerid=23152953
milo12 is offline Find More Posts by milo12
Old May 04, 2012, 11:26 AM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
lol, that is a crazy idea. I bet it might work, though. You wouldn't be able to use the sun shield, though, and I'm not sure about the quality of the mirror optics, but it is a clever idea.
-- Gary
Old May 04, 2012, 06:20 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
I did another test flight this morning, after tweaking the roll gains a bit more. Much better.
AG550-PJ 2-Axis PJ710V Gimbal Test-03.mov (3 min 40 sec)
Later I'll post another video I did today with Stephen (Steph280...), who maidened his new WK-M - equipped hex today. It is based on Rusty's kit, and uses TRex500 CF booms. Very cool looking.
-- Gary
Old May 04, 2012, 06:34 PM
Twister773 is offline
Find More Posts by Twister773
Private Pilot
Twister773's Avatar
United States, CA, San Luis Obispo
Joined Jul 2009
I dont know how, but you keep impressing me more and more haha Great work Gary. Will you guys be offering a mount specifically for the sony 710v with the existing gimbal/landing gear?
http://youtu.be/fM-ZMahvvgw
-- Gary
Twister773 is offline Find More Posts by Twister773
Old May 04, 2012, 06:42 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
yes, once all the testing is done. this is getting close to DLSR weight and we want to make sure everything is strong/stiff enough. we may need to make 1 part slightly thicker I sent some sample to gary already. the final rev of the yoke is already done, so easy to have it available.
this really helps us in developing the DSLR version. It really does look like everyone else is going to yoke type roll for their high end system. we have proven that it does work well.
Old May 04, 2012, 06:44 PM
Private Pilot
Twister773's Avatar
Joined Jul 2009
You too! I look forward to seeing the final product and will be ready to click buy when it is available
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
