Old May 02, 2012, 12:11 AM
Adidas4275 is offline
Find More Posts by Adidas4275
manual flying apologist
Adidas4275's Avatar
United States, CA, Fresno
Joined Mar 2011
who uses the 12v line off a ESC for power
perhaps for a really light weight rig..... No offense but you gimbal/landing gear arent really for a light weight setup....
I use BECs in all my rigs, planes, multirotors........
it is nice to know that if you burn up a ESC from overpropping (airplane) that you can still dead stick the landing....
Adidas4275 is offline Find More Posts by Adidas4275
Old May 02, 2012, 12:17 AM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
most esc has linear 5v reg , but not good for much if you run 4S packs lol. some have switching reg and they do pretty well. I used to run kontroniks Jazz 40 on 5S on my smaller heli without issues (eolo/eco8 sized)
askman is offline Find More Posts by askman
Old May 02, 2012, 06:26 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
LIke this?
Wingbreaker is offline Find More Posts by Wingbreaker
Old May 02, 2012, 09:56 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
In case of F550 ARF, the esc are OPTO, so you don't need to worry about esc. but in our case, we are doing somthing similar with gimbal servo wire.
here is a simple schematic I just drew up with servo wiring to bec and fcb with 5v reg to power the ecb from 6v bec. (in this case if you are using naze32 . naza has its own regulator. )
I believe pin1 is signal, pin 2 is power and pin3 is ground. which is what I used
Old May 02, 2012, 10:06 AM
Video Juggernaut
Joined Nov 2003
Yeah these diagrams are tough for me to look at. no i wont have any other controller beside WK-M maybe in future when i understand this more. So what do you mean I don't need to worry about the esc? do I just wire from the battery lead?
Old May 02, 2012, 10:18 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
on f550, there is distribution board. wire the UBEC to the distribution board. which will give you 6v out of the ubec.
if I get this small board turned and available, it will really simplify this. if I submit it this week, it will be couple weeks before I get though.
lets get you setup and flying with your multi before worrying about this. I may get the board done by then and it would be plug and play by then.
Old May 02, 2012, 10:30 AM
Video Juggernaut
Joined Nov 2003
cool. in the meantime all I have to do is solder the bec to the board and then send the servo wire from the bed to my rx?
Old May 02, 2012, 10:33 AM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
BEC is soldered to the distribution board. you want to take red and black wire from roll and tilt servo and connect to the BEC (red and black) The white(sometimes orange) signal wire from servo goes to the WMK . this is best done using servo extension, so you don't mess up the servo wire .
Old May 02, 2012, 10:45 AM
Video Juggernaut
Joined Nov 2003
ok i think i got it now. so bec servo lead does not go to anything besides a Y to the two servos red and black wires.
Old May 02, 2012, 01:14 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Since the demand for these is fairly strong, I went ahead and ordered a bunch of adapter boards made. Electrically, it matches Andrey's schematic. It will have three 3-pin headers that will be used to plug in the two servos and the BEC. There will then be two male servo leads coming off this board that will plug into the FCB or the gimbal controller. If something like the Naze32 is used for both functions, 5V can be supplied via the onboard 5V regulator. If a separate FCB is used, like a Naza or a WK-M, which come with their own 5V BECs, these regulator parts can be omitted. In that case, only the signal and ground leads will go to the FCB/gimbal controller.
These should be available early next week.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old May 02, 2012, 01:18 PM
Adidas4275's Avatar
Joined Mar 2011
cool. looks good.
madlabs is making some great cases for HoverFly boards... and they are cheap. When i buy/get one i might see if they can make a little case for it
since we are using the Naza32 for gimbal control, in the future, can it output 6v if it is running of 6v?
I would bet this little board would be great so sell at the MK, Photohigher and Cinestar dealers... since those use HV servos as well....
Old May 02, 2012, 01:29 PM
Video Juggernaut
Joined Nov 2003
-- Gary
Right on! I'm more confused than ever.
Old May 02, 2012, 01:43 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Originally Posted by Adidas4275 View Post
cool. looks good.
The Naze32 can only run on 5V, so it needs to get it from this regulator, or from the Naza/WKM.
-- Gary
Old May 02, 2012, 01:44 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
Don't worry, this solution is pretty much plug'n play, and it will come with instructions.
Old May 02, 2012, 02:07 PM
Adidas4275's Avatar
Joined Mar 2011
-- Gary
boo..... too bad it cannot run on 6v
I was liking how the HF board will pass through 5v or 6v from the BEC to the servos... it is so clean, no servo Ys or anything.
thats okay
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
