Old Feb 14, 2013, 02:23 PM
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Just tested and it worked fine... SOOOO hard to cancel it...
MCrites is offline Find More Posts by MCrites
Old Feb 14, 2013, 02:35 PM
United States, GA, Marietta
Joined Oct 2011
Different computer worked! Thanks.
Mcrites- just order it!
pcassociate is offline Find More Posts by pcassociate
Joined Dec 2007
Pitch / Roll coupling issue solved by HF with new fw 1.9 rev2 :
https://hoverflytech.zendesk.com/ent...Firmware-1-9r2
Regards,
Jim.
jimbril is offline Find More Posts by jimbril
Old Feb 14, 2013, 07:17 PM
Aerial Abstract Art
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Just did a few flights in the backyard to test out HF firmware 1.9 v2 and there is still some roll coupling going on. It's hard to tell because of my small flying space, but it seems to be less then before, but still there. I'll test it out more this weekend when I go out flying.
Daloaf is offline Find More Posts by Daloaf
Old Feb 15, 2013, 06:58 AM
Joined Dec 2007
Daloaf,
The fix was about the unwanted roll (aileron) movements during pitch (elevator) inputs and vice-versa (on some mounting positions). It's not about the older yaw coupling (horizon drift) . Are you sure you are getting unwanted roll movements when you go forth or back (elevator input), or unwanted pitch movements when you fly sideways (aileron input)? Also, you can test this on the bench (motors off). I've bench tested it and the pitch / roll coupling is definitely gone with fw 1.9 rev2.
Regards,
Jim.
Old Feb 15, 2013, 01:04 PM
Aerial Abstract Art
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Originally Posted by jimbril View Post
Daloaf,
Regards,
Jim.
Ahh ok. Well that's too bad. I never really had a issue with the roll coupling with pitch movement on 1.03 firmware. At least not that I noticed. I was thinking the horizon tilt when flying sideways (yaw) was fixed as that is the real problem I have been having. Oh well, hopefully you guys figure that issue out some day. Thanks.
Old Feb 15, 2013, 04:14 PM
North Central Positronics
badbill's Avatar
USA, GA, Centerville
Joined Dec 2002
What's the latest on the TAROT Gimbal Stabilization System ?
Bill Davenport
AMA 28141
badbill is offline Find More Posts by badbill
Old Feb 15, 2013, 05:22 PM
Video Juggernaut
Wingbreaker's Avatar
FL
Joined Nov 2003
Gary is always preaching smaller props with naza. he is right. I just tested out some stiff 9" props. Ive tried 11" and 10" before but the rig never felt this locked stable and locked in. I also got rid of the last bit of vibes/jello on my camera as I am using stiffer carbon fiber props. I was using the carbon mix SF before now I have SF carbon fiber. My gimbal was unpowered today as my HFG board was returned to HF for assessment. This is the best my video has looked. Who needs gimbal control?? Looks good to me. If I power the gimbal via some channels on my TX/RX will it stay just as still as it does off? I might just use it as is with some pot control for the tilt. Anyway here is the clip.
camquad (2 min 29 sec)
Wingbreaker is offline Find More Posts by Wingbreaker
Old Feb 15, 2013, 05:23 PM
Destroyer of G-10
askman's Avatar
Joined Jul 2004
I love smaller prop setup for AP/AV. stable platform makes for better video no matter what. and higher diskload helps with windy situation. why i still use 9" on my shrimp.
with gopro3, you can really tell the difference with prop sound. if you listen, the latest sounds very smooth and constant. earlier ones did not. that is clear sounds of prop issues.
askman is offline Find More Posts by askman
Old Feb 15, 2013, 06:53 PM
Canada, BC, Vancouver
Joined Mar 2012
Message removed, dealing with Andrey directly...
c3d76 is online now Find More Posts by c3d76
Old Feb 15, 2013, 07:14 PM
Destroyer of G-10
askman's Avatar
Joined Jul 2004
Let me check something and get back to you ced. something does not seem right.
Old Feb 15, 2013, 07:25 PM
Joined Mar 2012
Originally Posted by askman View Post
Let me check something and get back to you ced. something is not right.
Thanks Andrey!
Old Feb 15, 2013, 10:02 PM
Aerial Abstract Art
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I also agree on the smaller props and the Naza. With my Hengli HL44822's I can run 13x4 and 5 props without the motors even getting warm, but the copter feels much more smooth and stable with 11x5 carbon fiber props. Now I'm not pushing the motors at all and the lobster still has a ton of lifting power. Not quite the rocket ship it was with the 13" props, but it still climbs fast and is more stable coming down.
Old Feb 15, 2013, 10:17 PM
Pilot, Field Tech & Trainer
HighGainTuning's Avatar
United States, CO, Parker
Joined Jan 2013
Hub Cap for the F550 and F450
Are there any US re-sellers for the Hub Cap and is DJI really the mfg. of this? I did a search here and Google and can find only the 1 Canadian re-seller .
A Carbon Fiber Hydro-dip would make one of these look very nice.
http://bradatech.com/xPedRobo/shop/i...products_id=93
HighGainTuning is offline Find More Posts by HighGainTuning
Old Feb 15, 2013, 10:21 PM
Destroyer of G-10
askman's Avatar
Joined Jul 2004
supposedly BT-HUBCAP550 is bradatech exclusive. I doubt it is DJI made. if you google it, only one that comes up with that part number is bradatech. someone is vacuforming it.
with 13" prop, you could lift another 3-4lb load matt
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 860 Yesterday 05:49 AM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
