Canada, BC, Vancouver
Joined Mar 2012
![]() I am struggling with my pitch settings on the AG600 and I'm not sure if it is because of HFG 1.8 or the fact that my Nex is so far back on the Gimbal. I had to move it back to have access to the HDMI port, and waiting for the upgraded larger tray. Rolling back to v1.03 now to eliminate that possibility... Any chance you could share your settings here? https://docs.google.com/spreadsheet/...VakE2OUE#gid=0 Thanks, Cedric |
United States, OR, Keizer
Joined Jul 2012
St. Louis, MO
Joined Oct 2005
I haven't reamed out the props yet, I figure they should be a snug fit to the outside of the prop adapter. My issue is that the inner diameter is a bit too big on the Avroto 6mm shaft. I measured the motor shaft with calipers, it's 5.97-5.98mm, but the play is more than that. I'm chasing a high-frequency vibe so just trying to get everything as close to perfect as possible. Sounds like this play may not be the issue as some appear to be using the Zinger props straight on the shaft. Back to (re)balancing the props and I'm also checking on balancing the motors. A small bit of tape is helping on some of them (as measured by the iPhone vibration app method). Thanks! Chris |
| Thread Tools | |
| Discussion Sony Nex 5n aerial samples. | jeffscholl | Aerial Photography | 866 | Today 07:45 AM |
| Discussion DJI WK-M - Droidworx Hex Build | Huddo | Multirotor Talk | 41 | Dec 31, 2011 07:58 AM |
| Discussion Sony NEX 5N raw video footage | SeismicCWave | Multirotor Talk | 5 | Nov 17, 2011 12:10 AM |
| Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? | babanan | Aerial Photography | 6 | Sep 08, 2011 04:27 PM |
| Discussion What gyros to use on a 2 Axis camera gimbal? | Voguna | Aerial Photography | 0 | Mar 13, 2011 11:51 AM |
