Old Dec 02, 2012, 09:38 PM
Endlesslag is offline
Find More Posts by Endlesslag
Fly it like you STOL it!
Endlesslag's Avatar
United States, FL, Daytona Beach
Joined Jan 2011
Does anyone know if the 550 hex at altitudehobbies is compatible with parts and such for the DJI 550?
To me it looks pretty identical, I'm thinking of picking one up as soon as they're back in stock.
I'm going to use a Crius AIOP which I have already, and a gopro hero 3 silver which I should be getting soon. Jumping into multirotors headfirst, and maybe FPV once I reach the limits of my LOS flying.
http://www.altitudehobbies.com/multi...bo-flight-pack
Endlesslag is offline Find More Posts by Endlesslag
Old Dec 02, 2012, 10:13 PM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
Originally Posted by GGoodrum View Post
The RX100 has a 28-100mm equivalent lens and the 35mm equivalent of the NEX-5N's 16mm pancake lens is 24mm, so they are close. The RX100 takes much better stills, and video, in my opinion, like I said, due to the softness of the 16mm pancake lens. With the RX100s extremely effective OIS function, it also takes much better video, in my opinion. No little micro bounces to deal with.
-- Gary
If you have access to the new 16-50 IS Nex lens perhaps that would be better than the 16 pancake and maybe better than the RX100 also. I have not used the RX100 or the Nex 16 pancake so I don't have a perspective on them. But the Nex 6 and 16-50 certainly produces results that my clients would be happy with.
AlanGold is offline Find More Posts by AlanGold
Old Dec 02, 2012, 10:34 PM
Daloaf is online now
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I was looking at the frame and it looks like nearly an exact ripoff of the DJI frame, so the AG gimbals should work. The DJI F550 with motors and escs is only $318, I'm not sure if it's worth the price difference to buy a knockoff, but if their motors and escs all work together, it might be.
Daloaf is online now Find More Posts by Daloaf
Old Dec 02, 2012, 10:49 PM
Endlesslag's Avatar
Joined Jan 2011
I've got a deal worked out with him since this is for a long term school project of mine, so it is only going to cost me roughly half of the dji version. I guess I'll go through with it and let you all know how it goes and if I have any issues.
Old Dec 03, 2012, 12:22 AM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
man, I've been very busy today at church.
concerning 3axis. adding 3rd axis is easy, but not to make it clean and integrated. we are talking about doing a version of lobster and king crab with integrated retract. probably the best solution. I can do rotating LG pretty easy, but it add height and weight. I have had simple solution on F550LG that attaches to it, but it adds 1.5" to the height and add weight. unless we can do a really clean solution, it won't happen quick.
today, I am finishing up some stuff, but also finishing up the s800 adapters and possibly test the 3508s (at least on the bench) I really want to get a batch, but not until I get them tested and figure out which firmware is the one to use.
askman is offline Find More Posts by askman
Old Dec 03, 2012, 01:11 AM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
HoverflyGIMBAL Setup Client - new upgrade
Name: HoverflyGIMBAL Setup Client
Version: 1.8.0.107
Publisher: Hoverfly Technologies, Inc.
http://www.hoverflyupdate.com/GimbalSetup/publish.htm
gww528 is offline Find More Posts by gww528
Old Dec 03, 2012, 01:37 AM
digitalCAM is offline
Find More Posts by digitalCAM
John
United States, WA, Mason
Joined Apr 2011
Originally Posted by MCrites View Post
I just lost the lens off my fpv cam. Lost orientation before I realized turning wouldn't bring back a signal loss. Managed to save it short of some power lines. Brought it back home and landed LOS. Another thing to check on occasion and a reminder for fpv pilots to keep Los skills sharp. I would have never found her without audio cues, wind was pushing and was in ATTI because of GPS drift. Failsafe is always last resort and I've never had to use yet.
Mark, If you lose orientation, don't forget about the option of putting it into "Home Lock". Then you can just fly it home, no matter what way it is oriented. I wouldn't ever put it into failsafe. Glad you got it back safely. -- JOHN
digitalCAM is offline Find More Posts by digitalCAM
Old Dec 03, 2012, 01:50 AM
tritan is offline
Find More Posts by tritan
Joined Apr 2007
-- Gary
Ok thanks for info.
Have you tried stills and video with the 0,75x adapter for the 16mm?
MUCH better than 16mm only. No softness or blurry corners, really sharp photos! This 0,75x means everything to me and my customers are really happy with the pictures and videos they buy. A 28mm is way too narrow for working in small ot tight areas and doesn't fill the frame good enough when fx taking pictures of a house. 12mm vs. 28mm is a huge difference and with proper balanced prop and motor there are no vibrations at all.
BTW, when I went from Graupners to wooden props (Xoars) it made a biff diff about vibs, sound (lower) and stability although both were balanced. IMHO if you have vibs without IOS there is something wrong in the setup even though it may dissapear some when using IOS. Also check the weight of different wooden props as a weight diff is rather important: the heavier props tend to vibrate more and I am very happy with my Xoars. They may cost some but if you are in it for satisfieng customers it is a very small fee to pay and very cheap compared to CF props.
As my Y6 is really small and on the limit for a Nex5so the Lobster is really interesting and I will follow the discussions about it for a while before I buy.
tritan is offline Find More Posts by tritan
Old Dec 03, 2012, 04:44 PM
kokla55 is offline
Find More Posts by kokla55
Joined May 2012
ext pot
I am finally putting the ext. pot mot on my AG550.
When i pulled the back cover off I maybe destroyed my servo
What can I do?
kokla55 is offline Find More Posts by kokla55
Old Dec 03, 2012, 04:51 PM
jbdww is offline
Find More Posts by jbdww
3D Heli and Planes
jbdww's Avatar
United States, TX, Round Rock
Joined Nov 2009
What can I do?
I did the same, even after reading the warning that this can happen. You could try soldering the small wires back with very small wire wrap wires, or your just going to have to get a new servo.
jbdww is offline Find More Posts by jbdww
Old Dec 03, 2012, 04:55 PM
kokla55 is offline
Joined May 2012
Not good! There are no MKS servos available here in Norway, and I have a photo shoot next weekend
Old Dec 03, 2012, 04:59 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
PM Andrey and be ready to pay through the nose for shipping. I bet he could get one in the mail tomorrow with some crazy $80+ 3-5 day shipping option. Sure you'll pay double for the servo but you'll have it next week before the weekend hits. He might even do the pot mod for you
MCrites is offline Find More Posts by MCrites
Old Dec 03, 2012, 05:51 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
I am modifying bunch of servos tonight, so doing extra is not a problem. I can ship tomorrow at the latest. (may be even today if I get on it) but need shipping information.
Old Dec 03, 2012, 06:15 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Cedric, I agree with Michael. Throw that H3B on there already!
Try using the H3B's 2.7K mode, with the WB set to "Raw". Then use Mercalli in your favorite editor (Unless it is FCP X...) to remove the platform motion and then zoom in the picture a bit, to eliminate the Mercalli black borders. Finally, use something like MB Looks to fix the fisheye effect and to punch up the color a bit. You will be amazed at the results.
-- Gary
Are you using the Mercalli plugin or Stand Alone version?
Old Dec 03, 2012, 06:20 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
-- Gary
Haha Will do!
I was actually just drilling a hole in the waterproof case () to access the USB port for FPV. I already modded the cable so it's almost ready to go
I'll try WB set to Raw, thanks for the tip!
And I installed Mercalli and MB looks a few days ago... It looks like I am all set
I'll post a vid here with the results. Cheers!
Cedric.
c3d76 is offline Find More Posts by c3d76
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 09:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 08:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 01:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 05:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 12:51 PM
