Old Nov 23, 2012, 09:27 PM
jbdww is offline
Find More Posts by jbdww
3D Heli and Planes
jbdww's Avatar
United States, TX, Round Rock
Joined Nov 2009
Test flight went very well! It is very stable and surprisingly quiet.
I also get around the same flight time (7min with 5000mah 4S) as on my 550 although I am now using 11x5 Gaupner props on the Avrotos...
Gary, I have a question about the gains.
I played around during the flight and ended up with 140-140-140-140 / 100-100
I noticed the Lobster wants to yaw to the right. If I yaw right and recenter the stick, it will keep going right for a second....
Do I just increase the Yaw gain? Do I need to rotate one of my arms a bit?
Maybe you could share your gains and any info on this?
Cheers,
Cedric
What size props are you using?
jbdww is offline Find More Posts by jbdww
Old Nov 23, 2012, 09:43 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
he is using 11" graupners
askman is offline Find More Posts by askman
Old Nov 23, 2012, 11:19 PM
Daloaf is online now
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I went and flew the Pigeon Point lighthouse today between Santa Cruz and Half Moon Bay, CA. The winds were blowing about 10mph, but I was getting really bad bouncing on the gimbal, enough so that the video, with a few exceptions was unusable. I loosened up the iso mount, just a turn or so, now I'm not sure if it needs to be looser or tighter or if that is the issue at all. I know the gopro I had directly mounted to the frame didn't bounce nearly as much as the NEX 5N on the gimbal. I might just wait to move everything over to the lobster to try to fix the problem as the parts should be coming any day now. I got the lobster just sitting here, but I want to build it once the motors and esc's come. I also ordered a 16mm pancake lens, just in case the bouncing is due to the heavy kit lens or maybe even the wind catching the lens hood. I'll have lots of stuff to experiment with in a few days.
Daloaf is online now Find More Posts by Daloaf
Old Nov 23, 2012, 11:53 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
I really like the first and last pic!
I'm sure the 16mm will help with the bouncing... Lobster is very rigid, I'm sure that will also help a lot vs the "flexy" 550.
By the way I got rid of some random jerkiness by tightening the HF controller board screws a few days ago. They say "loose", I guess mine were too loose...
c3d76 is offline Find More Posts by c3d76
Old Nov 24, 2012, 12:47 PM
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
Ya, I'm hoping that the new frame will fix some of my problems. I'll go check my HFG mount, that could be it. The problem has been getting worse over the last 20 flights or so, so I kept adjusting the gimbal, never checked the HFG board.
Old Nov 24, 2012, 08:40 PM
jbdww is offline
3D Heli and Planes
jbdww's Avatar
Joined Nov 2009
LOL. I did not read that part for some reason.
Cedric, the issue is you need to have 11x5 on top and 11x6 on the bottom. You have to have a higher pitch on the bottom because the air is already blowing from the top prop, so the bottom prop needs to bit more air to keep the motor rotating about the same speed to keep it from yawing.
Now the next problem is finding props like this. I wound up using the xinger props, but you will need to balance them in my horizontal and vertical.
Old Nov 24, 2012, 09:09 PM
c3d76 is offline
Joined Mar 2012
Thanks a lot for the explanation!
I guess I will have to go shopping for props again, and Graupner does not have 11x6... I almost tried 11' on the bottom and 10' on top just to see how that would go. If that works I guess I could just get some Graupner 12's for the bottom and use my 11's on top?
I did find a thread where someone fixed their Yaw problem on a Y6 by rotating one of the arms a bit:
http://fpvlab.com/forums/showthread....iate-some-help
After reading this I checked if the motor mounts were level, and a couple were very slightly rotated to the left (ccw) which would create right Yaw. So I now have them perfectly level and will see if that helps.
If not I can try rotating the mounts clockwise slightly, although the prop solution would be ideal... I also think/don't like that rotating the arms might affect Yaw differently through the throttle range. We'll see
Thanks again for your input!
Cedric.
Old Nov 24, 2012, 10:41 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
well, having slightly higher pitch on the bottom helps with efficiency and bit more lift. if you are flying fine with 11x5, i would not worry too much. twist will cause yaw issue.
Old Nov 25, 2012, 05:03 AM
c3d76 is offline
Joined Mar 2012
Hey Andrey
I see, well it flew great with the 11's but I did not have the camera on the gimbal.
I'm sure fixing the twist will help a lot, but even with the minor Yaw "issue" it was a real pleasure to fly
Here is a short vid of the maiden filmed from my friend's 550. He did not catch any flying, just hovering and testing gains...
AGY700 Y6 "Lobster" Maiden flight (1 min 22 sec)
Old Nov 25, 2012, 10:16 AM
blade strike is online now
Find More Posts by blade strike
DJI Testing / US Support
blade strike's Avatar
United States, CA, Big Bear
Joined Jan 2006
Like Gary said you will need to run a higher gain for yaw.. I don't have my lobster in the air yet but I have had to run about a 20% higher yaw gain than roll / pitch.
blade strike is online now Find More Posts by blade strike
Site Sponsor
Latest blog entry: Dji m600
Old Nov 25, 2012, 06:54 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Finally got my Shrimp finished. I would've got a test flight in, but I remembered that I forgot to do the Naza/GPS compass calibration. I'll do that in the morning, and give it a "whirl".
AUW with the AG500/Hero3, the "extra" GoPro and a 4s-5800 Zippy is 6lb 10.5oz/3020g.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Nov 25, 2012, 07:46 PM
c3d76 is offline
Joined Mar 2012
-- Gary
Looking good Gary!
A friend of mine might buy one from you.
I had a few test flights with the Lobster and camera today. All I can say is WOW. What a difference with the DJI550... Same motors, same Gimbal, Same HF board settings and the footage is amazing .
I still have to tweak a few settings but I am really happy with the results.
I'll post a vid later today or tomorrow.
Thanks Gary and Andrey, no regrets at all going with your product
Cedric
P.s. Gary, do you mind sharing your WKM/Naza gain settings? And where is the CG supposed to be, seems I have to put my LIPO way up front to get CG on center of battery tray/LG axis...
Thanks, I tried that today and it worked well. I still have right Yaw issue though, but I can get rid of it with 6 clicks left "rudder" trim...
Old Nov 25, 2012, 10:07 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Looking good Gary!
Cedric
Cedric, did you have extended arms on your DJI F550?
gww528 is offline Find More Posts by gww528
Old Nov 25, 2012, 11:06 PM
AlanGold is offline
Find More Posts by AlanGold
AlanGold's Avatar
Joined Oct 2012
Finally got my Shrimp finished. ..
The Shrimp and the Lobster both interest me. (Although I'm not ready for one yet.) For flying a Nex or GoPro is there any advantage to using the larger Lobster?
AlanGold is offline Find More Posts by AlanGold
Old Nov 25, 2012, 11:07 PM
c3d76 is offline
Joined Mar 2012
I tried the extended arms for a short while and got rid of them.
I think the DJI arms are just too flexible and didn't play well with the extensions..
Here is my experience with them: http://www.rcgroups.com/forums/showp...postcount=5289
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
