Old Nov 21, 2012, 12:41 AM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Originally Posted by Banana Furikake View Post
Shrimp cocktail ordered earlier. Whoot!
Was I the first Gary?
Yes.
GGoodrum is offline Find More Posts by GGoodrum
Old Nov 21, 2012, 01:13 AM
Banana Furikake is offline
Find More Posts by Banana Furikake
United States, OR, Keizer
Joined Jul 2012
Originally Posted by GGoodrum View Post
Yes.
Looking forward to it.
Banana Furikake is offline Find More Posts by Banana Furikake
Old Nov 21, 2012, 01:32 AM
red1one is offline
Find More Posts by red1one
red1one's Avatar
United States, MI, Ann Arbor
Joined Mar 2012
Originally Posted by Wingbreaker View Post
Got a couple Black's on order....... Looks like a good add to the collection. Selling my entire GoPro V1 gear set-up. Posting tomorrow on rcgroups.
red1one is offline Find More Posts by red1one
Old Nov 21, 2012, 07:26 AM
Velociraptor73 is offline
Find More Posts by Velociraptor73
SMILE you're being recorded :)
Velociraptor73's Avatar
Joined Apr 2010
...I think I could use some advices for new Zinger propellers.
I have tried Zingers 9x4 on DJI F550 frame with original 2212 920KV motors, 2x 4S 3300mah and it were too close to overheating, even without any camera on AG550 at around 1000m (3280ft) from sea level and considering an average temperature of 30*C (86*F).
I would like to try the Zingers again as carbon props can be a bit dangerous.
I'm now with Sunnysky's 2216 800KV motors instead of DJI's and 30A Simon flashed ESCs.
I went for eCalc but they don't have Sunnysky's motors on list neither Zinger's on props options. I'm considering 9X4 again on Hexa-V and 9X5 pusher for bottom motors when on Y6 configuration, but would be nice to have some opinions before placing the order.
I don't have a scale but probably my final weight should be around 3.6kg (8pounds) when I have the Ag550, camera and FPV stuff onboard.
Velociraptor73 is offline Find More Posts by Velociraptor73
Old Nov 21, 2012, 07:27 AM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
why sell, keep for a separate copter or backup. The V1 is still a great camera. Tppacks will have a crab soon, perfect for a v1 flip and crash cam.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Nov 21, 2012, 08:00 AM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Originally Posted by askman View Post
the frame does not include the tube IMS,which is part of the gimbal. but there is a hole in the frame where you can mount the v1.x isolation plate from the LG can be mounted. (I know this is the case for lobster, I do need to make sure for shrimp. it will for sure on the next run of shrimp if it isnot on the first batch) but yes, you could bolt the v1.x gimbal onto this tube as well (just drill a few holes onto the gimbal plate) it can be made available. hmm, may be a special version for v1.x owners.
2216 -800kv sunnysky. on 4S
I dont have one in hand to be sure, but it looks like if we could order that piece, or a slightly modified one, we could use the AG550 main carriage and lose the bulky upper plate. I think it is a great idea, assuming it can be implemented pretty easily.
Thanks for all the knowledge, by the way.
Derek_S is offline Find More Posts by Derek_S
Old Nov 21, 2012, 08:54 AM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
well,for v1.x, /tube, it can be done with a different plate, I will make one up and do a test piece. it would make it easier to adapt to the frames. probably bit lighter but the best thing is taht it would allow you to take adavantage of the isolation system in the frame.
askman is offline Find More Posts by askman
Old Nov 22, 2012, 12:33 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Just got my lobster in the mail
I'll try to take a few pics along the way... First step is to extend the avroto cables I had shortened for the 550 . I'll use female bullets to make the bridge...
c3d76 is offline Find More Posts by c3d76
Old Nov 22, 2012, 12:59 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
FYI, make sure you shrink wrap each bullet connection together.
gww528 is offline Find More Posts by gww528
Old Nov 22, 2012, 02:50 PM
isaacintheclouds is offline
Find More Posts by isaacintheclouds
Nevermind...
isaacintheclouds's Avatar
United States, CA, Carnelian Bay
Joined May 2011
HFG V1,03 vs 1.7r2
I finally got a chance to fly with v 1.03 today and I can positively say that it is FAR FAR smoother than it was on V 1.7r2 Thanks Askman and Gary for the excellent product you have made available to us. Everything seems to be working as advertised, it took a little patience and head scratching but Im finally getting it to where it should be. I will make a video showing my (slow) progress from the first to last testing flights with my F550/AG550/Hoverfly gimbal/ sony Nex5n w/16mm pancake lens and post it both here and on the HFG settings thread as long as no-one objects!
Cheers and thanks! Happy Thanksgiving!
Isaac
isaacintheclouds is offline Find More Posts by isaacintheclouds
Old Nov 22, 2012, 03:01 PM
c3d76 is offline
Joined Mar 2012
Cheers, but I'm only using the female side of the bullet and soldering the cables into each hollow end
Old Nov 22, 2012, 03:10 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Isaac
When you load different firmware, does it wipe out your settings?
Old Nov 22, 2012, 03:12 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
good idea
Old Nov 22, 2012, 04:08 PM
Mike SF is online now
Find More Posts by Mike SF
Mike SF's Avatar
United States, CA, SF
Joined Sep 2011
What is the white material below the RX100?
The new AG500 baseplate is going to support both the Hero3 and the RX100. For the latter, there is a second plate that will sit on top of six EAR rubber isolators, that are then mounting to the main camera tray baseplate. There will be an access hole in both plates in order to pass an HDMI cable in to the RX100's oddly positioned HDMI connector.
-- Gary
Mike SF is online now Find More Posts by Mike SF
Old Nov 22, 2012, 04:11 PM
Nevermind...
Joined May 2011
It didnt with mine. I had to do a little messing with my center points and scaling factor. I think I am going to factory reset anyways soon just to make sure everything is as tight as it can be. I did notice though that all the readouts in the diagnostics screen were more stable than they were on V1.7.
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
