Old Nov 19, 2012, 02:25 PM
Wingbreaker is offline
Find More Posts by Wingbreaker
Video Juggernaut
Wingbreaker's Avatar
United States, FL, Satellite Beach
Joined Nov 2003
Originally Posted by blade strike View Post
Not with color but with the lens correction or post stab.. Almost a jello but not really.. Just wonky
not seeing the jello, just in beginning when he bangs it. super wide angles always have a wrap on edges whether fisheye or not. He is panning back and forth way to fast, that will cause waves because cmos can't hang with it. we are looking at what a 4-7mm length here? I'm doing another with cropped image, more pushed in and a more standard cc.
** ahh, I see the bubbles from the stab. easily fixable.** Anyway, this just show how well the image stays sharp throughout the whole process. more sharp than an nex5n and rx100, hands down. a much more flexible platform for sure. put a system together like this with an apsc size sensor in a small point and shoot body with detachable lens. you have a winner, for sure.
**update** Got rid of the IS warps. I also played with some different cinematic looks. Looking better. got my go pro in the mail today. will play tomorrow.
http://www.rcgroups.com/forums/showthread.php?t=1773414
FYI GH2 will be on sale for 500 bucks on black friday at amazon.
Wingbreaker is offline Find More Posts by Wingbreaker
Old Nov 20, 2012, 12:45 AM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Setting up the AG600. In the picture below. The main tube is long enough that the Cross Bar could be move to were the red arrow is. This would center the Sony Nex 5 between the legs more. Should I leave it as it is in the picture & cut the tube shorter or move the Cross Bar to were the Red Arrow is?
gww528 is offline Find More Posts by gww528
Old Nov 20, 2012, 01:57 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
you can move it if you want. I left it long enough for other products on purpose, so if you want to save bit of weight, cut the tube down. or move the bar. .
askman is offline Find More Posts by askman
Old Nov 20, 2012, 02:06 PM
tigar is offline
Find More Posts by tigar
tigar's Avatar
Athens, Greece
Joined Sep 2001
When is the shrimp going to be available?
tigar is offline Find More Posts by tigar
Old Nov 20, 2012, 02:38 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
I'm trying to get it on the site today, but unfortunately with the holiday season here, my time is not my own these days.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Nov 20, 2012, 03:02 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Thanks I think I was looking for a more definitive answer. Since you guys are the designers & have more experience with your experimenting. This is being installed on a F550. To be more specific... how should this be installed for the best balance. Per the instructions or move it forward. Thanks again. BTW nice design & build.
Old Nov 20, 2012, 04:32 PM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I don't know if they can answer that for you because depending on the camera, accessories, battery placement, your CG could wildly vary. It's up to you to adjust the components to make sure the copter balances. But the ability to slide the gimbal forward or back on the tube gives you more adjustments that you can do to get the perfect CG. Get the copter and gimbal built and start experimenting. You can test your balance easily on a F550 by putting your fingers on the landing skids on the end of the arms and see how well it balances.
I have no idea how I'm going to try to balance the y-6 Lobster
One more thing, the ability to move the gimbal forward or back a bit will help center the camera if your using a longer lens like the NEX 5N kit lens vs a RX100 or Gopro.
Daloaf is offline Find More Posts by Daloaf
Old Nov 20, 2012, 06:05 PM
GGoodrum is offline
GGoodrum's Avatar
Joined Mar 2003
-- Gary
Shrimps are up.
Old Nov 20, 2012, 06:11 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
Those are all good points... it will be good to have the extra length of tubing.
Old Nov 20, 2012, 06:29 PM
Derek_S is offline
Find More Posts by Derek_S
Videopilot
Derek_S's Avatar
United States, NC, Charlotte
Joined May 2009
Shrimps are up.
Sweet, looks good. So do the older model landing gears fit into this frame as well?
Derek_S is offline Find More Posts by Derek_S
Old Nov 20, 2012, 07:16 PM
Video Juggernaut
Joined Nov 2003
some more on the go pro saga
http://www.rcgroups.com/forums/showt...4#post23320920
Gopro Hero 3 Black Test Drive V.2 High Res (0 min 53 sec)
Old Nov 20, 2012, 08:42 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
LG built into the frame. not needed. save bit of weight as well.
Old Nov 20, 2012, 10:15 PM
Derek_S is offline
Videopilot
Derek_S's Avatar
Joined May 2009
Two more questions, does it include this piece pictured on the page?
(not the gimbal board, but the gimbal adapter). I ask for those of us that have a AG550, etc. Looks like with that piece you can bolt the old gimbal right up to it.
And secondly, the description states
, the recommended SunnySky 2216 motors and a set of 10x4 (top) and 10x5 (bottom) Zinger wooden props, an all-up weight (AUW) of up to 9 pounds is possible
What KV are these recommended motors and on what voltage? If it helps, I am assuming 4s here for myself...
Old Nov 20, 2012, 11:39 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
the frame does not include the tube IMS,which is part of the gimbal. but there is a hole in the frame where you can mount the v1.x isolation plate from the LG can be mounted. (I know this is the case for lobster, I do need to make sure for shrimp. it will for sure on the next run of shrimp if it isnot on the first batch) but yes, you could bolt the v1.x gimbal onto this tube as well (just drill a few holes onto the gimbal plate) it can be made available. hmm, may be a special version for v1.x owners.
2216 -800kv sunnysky. on 4S
Old Nov 21, 2012, 01:28 AM
Banana Furikake is offline
Find More Posts by Banana Furikake
United States, OR, Keizer
Joined Jul 2012
Shrimp cocktail ordered earlier. Whoot!
Was I the first Gary?
Banana Furikake is offline Find More Posts by Banana Furikake
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 09:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 08:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 01:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 05:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 12:51 PM
