Old Nov 15, 2012, 06:56 PM
manvsuav is offline
Find More Posts by manvsuav
Closed Account
Joined Mar 2012
awesome thanks for the info dude. hopefully i got this right.
2x BATT to PCB
PCB to BEC
BEC (red and black) to servo's with a harness for both servo's
SERVO's (white signal cable only) to controller
is this right?
manvsuav is offline Find More Posts by manvsuav
Old Nov 15, 2012, 07:13 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
Originally Posted by MCrites View Post
Servos to HFG to RX.
Download the HFG manual, it helped me. Gary had some in the AG550s instructions too that I bet are in the AG600 manual
2x BATT to PCB
PCB to BEC
is this right?
Almost right, you left out the Hoverfly Controller. Do not understand why you have "2x Batt to PCB".
I have to agree with MCrites... download the Instructions. Its very detailed with diagrams.
http://www.tppacks.com/store/downloa...structions.pdf
gww528 is offline Find More Posts by gww528
Old Nov 15, 2012, 07:23 PM
askman is offline
Find More Posts by askman
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
Originally Posted by c3d76 View Post
Yes please, build thread would be great!
Andrey or Gary, Lobster page says that AG600 and AG700 are bolt-on ready.
I'm guessing the AG550v2 (upgraded) will work too?
there are few option. you can buy the shrimp/lobster without the IMS and use the ag550 IMS . (including the grommette mounting plate) that wouild be the cheaper option. the other is to drill holes on the cf plate and mount the new crossbar. third is move to ag600 ims.
king crab is x8 version of lobster. gary want go with 13" prop on the 3508 on 6S
askman is offline Find More Posts by askman
Old Nov 15, 2012, 07:37 PM
c3d76 is online now
Find More Posts by c3d76
Joined Mar 2012
Thanks Andrey,
I've already ordered the Lobster yesterday.
It says it comes with "integrated landing gear and Isolated Mounting System (IMS)". Is this the one with 6 silicone grommets by the way (instead of 4)?
So you are saying I will have to drill holes into the cf plate of the ag550v2 to mount to Lobster IMS?
I wonder if Gary can add the parts to convert my AG550v2 (upgraded) to AG600 before shipping the Lobster. It would depend on the cost ofcourse, but I think all that is needed is the tube and a couple of adapters? That should be pretty cheap...
c3d76 is online now Find More Posts by c3d76
Old Nov 15, 2012, 08:03 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
yes, just drill, but well, I will send you the IMS part. just email me the address.
Old Nov 15, 2012, 08:04 PM
c3d76 is online now
Joined Mar 2012
Oh, nevermind my package has already shipped
Edit: Really? You guys are awesome
I'll pm you the address
Old Nov 15, 2012, 08:14 PM
c3d76 is online now
Joined Mar 2012
email sent to askman@askmanproducts.
Thanks man
Old Nov 15, 2012, 08:48 PM
GGoodrum is offline
Find More Posts by GGoodrum
GGoodrum's Avatar
South Orange County, CA
Joined Mar 2003
Actually, Cedric, I read your email while I was leaving today's shipments at our postal annex, so I pulled yours back, and didn't send it. I'll open it up and add in the AG600 IMS tube/clamp setup. I just happen to have one extra, in all the bits Andrey has been sending me.
-- Gary
GGoodrum is offline Find More Posts by GGoodrum
Old Nov 15, 2012, 08:54 PM
c3d76 is online now
Joined Mar 2012
-- Gary
That was some great timing right there Gary
This is perfect, thanks a lot! You (and Andrey) are the best
Cedric
Old Nov 15, 2012, 09:53 PM
jbdww is offline
Find More Posts by jbdww
3D Heli and Planes
jbdww's Avatar
United States, TX, Round Rock
Joined Nov 2009
Almost there. Just need to figure out the last mile. I get these very small jitters in my video. I am using the AG550 V2 gimbal on this with the HFG. Any thoughts on what I can tweak. Ignore the horizon being off as that is my fault. I made sure all bolts, belts and pulleys are all tight.
Over Looking the neighborhood. (6 min 18 sec)
jbdww is offline Find More Posts by jbdww
Old Nov 15, 2012, 11:14 PM
askman is offline
Destroyer of G-10
askman's Avatar
United States, OR
Joined Jul 2004
did you calibrated the hfg by the manual? i've had issue like that when it was not calibrated. I used heat gun to calibrate. and make sure camera itself is firm on the plate.
Old Nov 15, 2012, 11:31 PM
Daloaf is offline
Find More Posts by Daloaf
SkyHi Aerial
Daloaf's Avatar
San Francisco, CA
Joined Nov 2005
I think you need to up your roll and tilt accl a little bit. Do it in small increments, but it looks like the roll needs a bit more then the tilt, just guessing here. As for the jitter when your hovering, I have no idea, but it couldn't hurt to do the calibration over again as Andrey suggests.
Daloaf is offline Find More Posts by Daloaf
Old Nov 16, 2012, 02:32 AM
M4rkus is offline
Find More Posts by M4rkus
M4rkus's Avatar
Germany, NRW, Oberhausen
Joined Nov 2012
well, m4rkus, with lightest camera, you may be able to get usable performance with that gimbal, but it is tough to say. we know what works for us and we designed around that criteria. you really need to contact the manufacturere/dealer to get good suggestion in my opinion. while better servo will help, I really don't know what the result will be.
Thanks for your answer askman !
I think about to use a seperate gimbalcontroller like HFG and two MKS 950 Servos to push up performance and smoother running of the gimbal.
Here is an actual RAW video from me. I'm not satisfied with the performance.
Specs:
X-Quad 460
Suppo 2212/13
SimonK's 20A
9 x 4.7 Props
2-Axis GF Gimbal V3.0 XL with 2 x Futaba 3152
Gimbal controlled by Naza
Testflight with gimbal controlled by naza (5 min 31 sec)
M4rkus is offline Find More Posts by M4rkus
Old Nov 16, 2012, 02:49 AM
WonderKing is offline
Find More Posts by WonderKing
WonderKing's Avatar
Indonesia, Jakarta
Joined Sep 2012
will the AG700 lift 5D DSLR? i know it sounds silly, but one of my client need me to lift his 5D on air
WonderKing is offline Find More Posts by WonderKing
Old Nov 16, 2012, 02:57 AM
c3d76 is online now
Joined Mar 2012
Here is an actual video from me. I'm not satisfied with the performance.
Specs:
X-Quad 460
Suppo 2212/13
SimonK's 20A
9 x 4.7 Props
https://vimeo.com/53658518
Hey Markus, if you go with this setup don't forget to also get a 6v BEC to power the HFG/servos.
Wiring diagram and info page 3 here: http://www.tppacks.com/store/downloa...structions.pdf
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
