Old Nov 15, 2012, 03:01 PM
c3d76 is offline
Find More Posts by c3d76
Joined Mar 2012
Originally Posted by blade strike View Post
All I can say is WoW Just received my new AG600 and lobster, What a work of art
I'm thinking about doing a build thread.. You guys think I should?
Yes please, build thread would be great!
Andrey or Gary, Lobster page says that AG600 and AG700 are bolt-on ready.
I'm guessing the AG550v2 (upgraded) will work too?
c3d76 is offline Find More Posts by c3d76
Old Nov 15, 2012, 05:02 PM
kokla55 is offline
Find More Posts by kokla55
Joined May 2012
Originally Posted by GGoodrum View Post
The 3508s that I'm getting will be for my "King Crab" X8 setup, which I hope to get to soon. I got these witha low kV (380, I think...), because I want to run them on 6s. For the Lobster, I still really like the 2814s. Anyway, I won't be able to test these for awhile yet. It is a little busy around here, at the moment.
Among other things, like shipping out all remaining orders (some were waiting on parts, which should be here this morning...), I need to finish up the Lobster and Shrimp instructions. Ken (Blade Strike...) is going to help by taking some pictures for me tonight, so I hope to get the Lobster instructions up tomorrow. Time permitting later, I will try doing the same with the new Shrimp instructions.
As soon as I have Andrey's shipment in hand, I will put up the Shrimp kits, and re-enable the other items that are out-of-stock, on the site.
-- Gary
I know you guys are really busy, but is it possible to get any info on the King Crab?
kokla55 is offline Find More Posts by kokla55
Old Nov 15, 2012, 05:13 PM
manvsuav is offline
Find More Posts by manvsuav
Closed Account
Joined Mar 2012
hey guys, quick stupid question but which i dont really know the answer to.
how do you guys operate your gimbal (tilt) with a controller like, lets say hoverfly, whilst using DJIWKM which is using the receiver. im just a little confused.
manvsuav is offline Find More Posts by manvsuav
Old Nov 15, 2012, 05:23 PM
MCrites is offline
Find More Posts by MCrites
I never finish anyth
United States, TX, Houston
Joined Jan 2012
Connect hoverfly gimbal controller to a free slot on your RX. Then program that channel to a slider/knob on the TX
MCrites is offline Find More Posts by MCrites
Old Nov 15, 2012, 05:32 PM
manvsuav is offline
Closed Account
Joined Mar 2012
ok sounds easy. so i take off the current servo leads going to WKM and put them to hoverfly, then on output of hoverfly to RX?
i dont have a gimbal controller yet, however thinking of getting a hoverfly.
Old Nov 15, 2012, 05:38 PM
MCrites is offline
Joined Jan 2012
Servos to HFG to RX.
Download the HFG manual, it helped me. Gary had some in the AG550s instructions too that I bet are in the AG600 manual
Old Nov 15, 2012, 05:39 PM
gww528 is offline
Find More Posts by gww528
gww528's Avatar
United States, FL, Jacksonville
Joined Mar 2008
To work the tilt...
Battery => BEC => to HoverFly
RX lead to => HoverFly (remove the red wire (+ voltage) from the lead)
The Naza or WKM are not even in the loop.
gww528 is offline Find More Posts by gww528
manvsuav is offline
Closed Account
Joined Mar 2012
ok thanks mc!
Old Nov 15, 2012, 05:41 PM
manvsuav is offline
Closed Account
Joined Mar 2012
Originally Posted by gww528 View Post
To work the tilt...
ok make sense, can i power the hoverfly off WKM or needs its own BEC, if so, can i grab the power from the main PCB to a BEC which goes to the hoverfly?
Old Nov 15, 2012, 06:14 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
My thinking is... the Naza (do not know the WKM) runs on 5v & I do not want to pull additional amps running the servos. Also do not want to take a chance of blowing the Naza Bec. For that same reason I may just run a separate battery & BEC to run the gimbal servos or at least a separate BEC off the PCB board. This way you can set the Bec to 6v for the servos. It will make them slightly faster with more torque.
Old Nov 15, 2012, 06:20 PM
manvsuav is offline
Closed Account
Joined Mar 2012
great! so which bec could i get to make them 6v.
Old Nov 15, 2012, 06:27 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
I am using the Castle Creations CC Bec which is programmable. You need a usb programming cable to connect to a PC (already had one).
http://www.castlecreations.com/products/ccbec.html
Old Nov 15, 2012, 06:29 PM
manvsuav is offline
Closed Account
Joined Mar 2012
ok well if i can avoid spending more money, could i use the black bec that i have which is OUT at 7.2v?
Old Nov 15, 2012, 06:33 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
This looks good on TPpacks.com site
Specs:
Input: 6V-23V (2-5S Lipoly, 2-6S Li-Fe or 5-15S NiXX Battery Pack)
Output: 6V/3A (Less than 50mV peak to peak voltage @ 2A)
Dimension: 22.9mm x 20.3mm x 7.6mm (LxWxH)
Weight: 9.1g (wires included)
http://tppacks.com/store/index.php?r...&product_id=58
Old Nov 15, 2012, 06:36 PM
gww528 is offline
gww528's Avatar
Joined Mar 2008
are you using High Voltage servos? otherwise no.
Discussion Sony Nex 5n aerial samples. jeffscholl Aerial Photography 1509 Dec 07, 2015 08:05 PM
Discussion DJI WK-M - Droidworx Hex Build Huddo Multirotor Talk 41 Dec 31, 2011 07:58 AM
Discussion Sony NEX 5N raw video footage SeismicCWave Multirotor Talk 5 Nov 17, 2011 12:10 AM
Discussion Which is best: "Sony Nex 5" or "Panasonic GH2"? babanan Aerial Photography 6 Sep 08, 2011 04:27 PM
Discussion What gyros to use on a 2 Axis camera gimbal? Voguna Aerial Photography 0 Mar 13, 2011 11:51 AM
